techjunkie09 Posted July 21, 2009 Share Posted July 21, 2009 not sure if this will work or not, but u could give it a try while waiting on lee mac lol replace in2ft in the code he gave you with this and let me know how that outputs (defun in2ft (num / ft in) (setq ft (fix (/ num 12.0)) in (rem num 12.0)) (strcat (if (= (substr (rtos ft 2 2) ((strlen (rtos ft 2 2))-3)) ".00") (rtos ft 2 0) (rtos ft 2 2) ) (chr 39) (chr 45) (if (= (substr (rtos in 2 2) ((strlen (rtos in 2 2))-3)) ".00") (rtos in 2 0) (rtos in 2 2) ) (chr 34))) edit: nevermind lol, lee is on the job:wink: Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 21, 2009 Share Posted July 21, 2009 Thanks for the input, but there is a much simpler alternative junkie I created that sub-function before I figured out that the rtos function, if provided with an argument of 3, will return the result I needed. The trailing zeros are controlled by the DIMZIN sys var I believe Lee Quote Link to comment Share on other sites More sharing options...
cabltv1 Posted July 22, 2009 Author Share Posted July 22, 2009 Lee, I got it to work by changing the DIMZIN Variable to 8 or 12. Anything lower and there was no change. The "Z" coords are missing 1 zero but I can live with that. Thanks for the suggestion and the original code! Techjunkie09, Thanks for your suggestion but made no difference without changing the DIMZIN Variable. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 22, 2009 Share Posted July 22, 2009 Glad you got it sorted to how you wanted Lee Quote Link to comment Share on other sites More sharing options...
