alijahed Posted October 31, 2019 Share Posted October 31, 2019 (edited) Hi All, Let me put it in a very simple example. I have an assembly contains: Pan screw CSK Screw Then I have Level of details (LOD) as: Master - contains both Pan - the CSK screw suppressed CSK - the Pan screw suppressed Now: I double click on LOD "Pan" to make it active and what I see on the screen will be my Pan head screw; however, when I go to BOM I see both of them listed! Is there any way to have the associated BOM to LOD? Next level question: in my ilogic rule when I am in "Master" LOD the following code: ThisBOM.Export("Parts Only", "Test.xls", kMicrosoftExcelFormat) generate the BOM having both screws listed in excel file; however, by changing the LOD to Pan (or CSK) it comes back with the following error: Error in rule: Rule0, in document: Test.iam ThisBOM: Could not find a BOM view named "Parts Only". If the name is correct, then please enable this BOM view, and save the assembly. (my comment: The name is correct and it is enable) Please advise... p.s. the more I investigate the more I think iAssembly is the correct choice for creating configurations. Through this way I could manage the asembly BOM right but I still cannot create the correct BOM out of iLogic rule. Cheers Ali Edited October 31, 2019 by alijahed Quote Link to comment Share on other sites More sharing options...
