Jim Clayton
Change Units of Existing Lisp
Jim Clayton
Hello.  I have the attached Lisp.  I got it somewhere at some point in time...not sure when.  I have my drawing units set to inches.  When I run the Lisp it's reading the millimeters that are listed and drawing them in inches; example: Lisp reads 254 mm, it will draw 254 inches.  I don't want to change the drawing units in cad because everything else non-lisp related is still in inches.  So how can I modify the Lisp to write in inches as well?  Let me know if there are any questions because I realize I made that a little confusing.  Thanks for the help.
Pipe V3.0.lsp
Share this post
Link to post
Roy_043
Judging by the avatar in the dialog the code is by ymg.
The code uses the LUNITS variable to determine the scale factor:
(if (= (getvar "LUNITS") 2) (setq fac 25.4) (setq fac 1.0))
Changing this line (923) to:
(setq fac 1.0)
Should fix your issue.
Share this post
Link to post
Jim Clayton
That's the line I was looking for.  Thank You.  Tried tracking it down earlier but wasn't able to.  I appreciate the help.  Thanks again.
Share this post
Link to post
pkenewell
Change the following line:
to
(setq fac 1.0)
or (if using MEASUREMENT system variable to define metric units):
(if (= (getvar "MEASUREMENT") 1) (setq fac 25.4) (setq fac 1.0))
Share this post
Link to post
Jim Clayton
Share this post
Link to post
tanbqtb03
Please insert more fitting, such as: Elbow 45 short, Elbow 45 long, Y strainer...in your program
Thanks a lot
Share this post
Link to post
