DavidGraham
CIRCLE not drawn in the correct location
DavidGraham
I have created a small DXF file to draw a line and a circle. The line is the unit normal vector (i.e. length 1 and perpendicular to the circle).
The line is drawn correctly but the circle is being drawn in the wrong location (the orientation is correct).
You can see below the 10, 20 & 30 codes for the line are the same as the 10, 20 & 30 codes for the circle.
When I report on the circle I get the following - center point, X=  -5.0552  Y=   1.3996  Z=   1.5996
I expect it to be center point, X=  -5.2394  Y=   1.5870  Z=   0.4437
I'm sure it's because I don't understand fully the DXF reference documentation - can anyone suggest what I'm doing wrong.
0
SECTION
  2
ENTITIES
  0
LINE
  8
L_VCL
 10
-5.2304
 20
1.5870
 30
0.4437
 11
-5.5690
 21
0.6466
 31
0.4738
  0
CIRCLE
  8
CL_BFC
 10
-5.2304
 20
1.5870
 30
0.4437
 40
0.2275
210
-0.3386
220
-0.9404
230
0.0301
  0
ENDSEC
  0
EOF
Share this post
Link to post
kpblc
Object coordinate system is not equal World Coordinate System. Check 210, 220 and 230 DXF groups
Edited by kpblc
Share this post
Link to post
lrm
The following will convert the a point's WCS to an OCS if all you know is the Z axis of the Object's OCS.  Use the OCS coordinate for defining the circle's center in DXF.
(defun c:wcs2ocs (/)
; convert a WCS point to a OCS coordinate by defining an axis normal
; L. Minardi 11/8/2019
  (command "ucs" "") ; set to WCS
  (setq	p1    (getpoint "\npick start of normal vector")
	p2    (getpoint p1 "\npick end of normal vector")
	ptWCS (getpoint "\npick point to transform to OCS")
	Az    (normalize (mapcar '- p2 p1))
  ; define OCS with Arbitrary Axis Alogorithm
  (if (< (abs (nth 0 Az)) (/ 1.0 64.0))
    (setq Ax (cross '(0 1 0) Az))
    (setq Ax (cross '(0 0 1) Az))
  (setq Ay (cross Az Ax))
  (command "_.ucs"
	   "_non"
	   '(0 0 0)
	   "_non"
	   (trans Ax 0 1)
	   "_non"
	   (trans Ay 0 1)
  (setq ptOCS (trans ptWCS 0 1))
  (princ "\nWCS point: ")
  (princ ptWCS)
  (princ " = OCS point: ")
  (princ ptOCS)
)					; end defun
; normalize a vector
(defun normalize (v / d)
  (setq	d (distance '(0 0 0) v)
	v (mapcar '/ v (list d d d))
;;; cross product of 2 vectors a and b
(defun cross (a b / crs)
  (setq	crs (list
	      (- (* (nth 1 a) (nth 2 b))
		 (* (nth 1 b) (nth 2 a))
	      (- (* (nth 0 b) (nth 2 a))
		 (* (nth 0 a) (nth 2 b))
	      (- (* (nth 0 a) (nth 1 b))
		 (* (nth 0 b) (nth 1 a))
	    )				;end list
  )					;end setq crs
)					;end cross
Share this post
Link to post
Lee Mac
The difference in the resulting position between the LINE & CIRCLE entities arises because the coordinates defining the LINE entity start & end points are defined relative to the World Coordinate System (WCS), and those defining the centre of a CIRCLE entity (and indeed, other planar entities) are defined relative to the Object Coordinate System (OCS) - such coordinate systems will only be equal for OCS planes parallel to the WCS plane.
You can transform coordinates from the WCS to the OCS using the Arbitrary Axis Algorithm, which is more conveniently implemented in the trans function:
_$ (trans '(-5.2304 1.5870 0.4437) 0 '(-0.3386 -0.9404 0.0301))
(-5.45875 0.435109 0.291967)
Hence, your DXF data would become:
0
SECTION
  2
ENTITIES
  0
LINE
  8
L_VCL
 10
-5.2304
 20
1.5870
 30
0.4437
 11
-5.5690
 21
0.6466
 31
0.4738
  0
CIRCLE
  8
CL_BFC
 10
-5.45875
 20
0.435109
 30
0.291967
 40
0.2275
210
-0.3386
220
-0.9404
230
0.0301
  0
ENDSEC
  0
EOF
Share this post
Link to post
BIGAL
Just a dumb question why write the dxf do you have some program that you want to be able to make a Autocad dwg ?
Look at writing a script can be easier.
Is it for CNC but from say excel ?
Lastly there is open source to write a DWG.
Edited by BIGAL
Share this post
Link to post
DavidGraham
Thank your for your help.
I'm writing a program in VB.net to create a simple DXF file. I have been able to write lines, polylines, text, blocks etc. but am having trouble with Circle.
Is there open source available to do this?
In the past I have used Open Design Alliance to write a DWG file but their examples were for C++ and their support was either very good or erratic.
I could try to recreate the trans function in VB.net - it looks difficult.
Share this post
Link to post
