Jim Clayton Posted November 11, 2019 Posted November 11, 2019 Hello. I'm in the process of building a Lisp/DCL. I want to add a few steps where you can select an insertion point and insert a Dynamic Block at that point. Is there a quick and easy way of going about this? The Lisp/DCL are both still in the beginning stages and VERY much under construction. The end product that I'm trying to build though looks like a vertical piece of pipe with a Dynamic Block on Top and Bottom and two Dynamic Blocks coming off of the side (spaced an equal distance apart). Would greatly appreciate any help. Tks. Quote
jonathann3891 Posted November 11, 2019 Posted November 11, 2019 (edited) There are multiple ways to accomplish this. (defun c:somefunc (/ ds) (setq ds (getvar 'dimscale)) (command "insert" "block_name" "_scale" ds "_rotate" 0 pause) (princ) ) Edited November 11, 2019 by jonathann3891 Quote
Jonathan Handojo Posted November 12, 2019 Posted November 12, 2019 As jonathann3891 says, there are many ways to insert a block. I normally do it by ActiveX ways, since "command" normally takes time to execute. For example: (setq acadobj (vlax-get-acad-object) adoc (vla-get-ActiveDocument acadobj) msp (vla-get-ModelSpace adoc) block_name (getstring T "\nSpecify block name: ") insertpt (getpoint "\nSpecify insertion point: ") scale_x 1 scale_y 1 scale_z 1 rotation 0 ; in radians your_block (vla-InsertBlock msp (apply 'vlax-3D-Point insertpt) block_name scale_x scale_y scale_z rotation)) but will fail if insertpt returns nil (happens when you press Enter on prompt) If you have a list of hundreds of blocks and points for each block, you can always do: (setq blocks (mapcar '(lambda (x y) (vla-InsertBlock msp (apply 'vlax-3D-point y) x scale_x scale_y scale_z rotation)) block_name insertpt)) My preference of style is constructing a dotted pair for each block and point, them put them in a list. Quote
BIGAL Posted November 12, 2019 Posted November 12, 2019 (edited) Have a look on Lee-mac.com for dynamic block routines for updating from a lisp. Just insert as per other post. Your welcome to use Multi getvals.lsp its a library routine for multiple input via a dcl. You can have from 1 to say around 15 entries. Multi GETVALS.lsp Edited November 12, 2019 by BIGAL Quote
Jim Clayton Posted November 12, 2019 Author Posted November 12, 2019 Thank you both. I'll give these a shot. I feel like I might be over-complicating this and making it more difficult than it needs to be so i'm going to step back and re-organize this first. Thanks again for the help. Quote
