Lem Posted November 11, 2019 Posted November 11, 2019 (defun c:superstr() (setq p (ssget)) (if p (progn (setq osl (strlen (setq os (getstring "\nOld string: " t)))) (setq nsl (strlen (setq ns (getstring "\nNew string: " t)))) (setq l 0 chm 0 n (sslength p)) (setq adj (cond ((/= osl nsl) (- nsl osl)) (T nsl) ) ) (while (< l n) (setq d (entget (setq e (ssname p l)))) (if (and (= (atext 0) "INSERT")(= (atext 66) 1)) (progn (setq e (entnext e)) (while e (setq d (entget e)) (cond ((= (atext 0) "ATTRIB") (setq chf nil si 1) (setq s (cdr (setq as (assoc 1 d)))) (while (= osl (setq sl (strlen (setq st (substr s si osl))))) (cond ((= st os) (setq s (strcat (substr s 1 (1- si)) ns (substr s (+ si osl)))) (setq chf t) (setq si (+ si adj)) ) ) (setq si (1+ si)) ) (if chf (progn (setq d (subst (cons 1 s) as d)) (entmod d) (entupd e) (setq chm (1+ chm)) ) ) (setq e (entnext e)) ) ((= (atext 0) "SEQEND") (setq e nil)) (T (setq e (entnext e))) ) ) ) ) (if (= "MTEXT" ; Look for MTEXT entity type (group 0) (cdr (assoc 0 (setq e (entget (ssname p l)))))) (progn (setq chf nil si 1) (setq s (cdr (setq as (assoc 1 e)))) (while (= osl (setq sl (strlen (setq st (substr s si osl))))) (if (= st os) (progn (setq s (strcat (substr s 1 (1- si)) ns (substr s (+ si osl)))) (setq chf t) ; Found old string (setq si (+ si nsl)) ) (setq si (1+ si)) ) ) (if chf (progn ; Substitute new string for old (setq e (subst (cons 1 s) as e)) (entmod e) ; Modify the TEXT entity (setq chm (1+ chm)) )) ) ) (if (= "DIMENSION" ; Look for DIMENSION entity type (group 0) (cdr (assoc 0 (setq e (entget (ssname p l)))))) (progn (setq chf nil si 1) (setq s (cdr (setq as (assoc 1 e)))) (while (= osl (setq sl (strlen (setq st (substr s si osl))))) (if (= st os) (progn (setq s (strcat (substr s 1 (1- si)) ns (substr s (+ si osl)))) (setq chf t) ; Found old string (setq si (+ si nsl)) ) (setq si (1+ si)) ) ) (if chf (progn ; Substitute new string for old (setq e (subst (cons 1 s) as e)) (entmod e) ; Modify the TEXT entity (setq chm (1+ chm)) )) ) ) (if (= "TEXT" ; Look for TEXT entity type (group 0) (cdr (assoc 0 (setq e (entget (ssname p l)))))) (progn (setq chf nil si 1) (setq s (cdr (setq as (assoc 1 e)))) (while (= osl (setq sl (strlen (setq st (substr s si osl))))) (if (= st os) (progn (setq s (strcat (substr s 1 (1- si)) ns (substr s (+ si osl)))) (setq chf t) ; Found old string (setq si (+ si nsl)) ) (setq si (1+ si)) ) ) (if chf (progn ; Substitute new string for old (setq e (subst (cons 1 s) as e)) (entmod e) ; Modify the TEXT entity (setq chm (1+ chm)) )) ) ) (setq l (1+ l)) ) ) ) (if (> chm 1) (princ (strcat "\nUpdated " (itoa chm) " text strings")) (princ (strcat "\nUpdated " (itoa chm) " text string")) ) (terpri) ) ; (defun atext (num) (cdr (assoc num d)) ) I am using this lisp to replace text. it works great except when the mtext has a field expression inserted. The same thing happens when i use the "find" command , if i search the value "x" to be replaced with "y", hit find, zoom to highlighted result, and press replace, the "x" value won't be replaced if the mtext has a field expression. Can anyone give some help to make this lisp work even when the mtext have a field expression. Quote
BIGAL Posted November 12, 2019 Posted November 12, 2019 if using vlisp it will return the full textstring including all the hidden mtext codes, you can even add codes. Use Vl-sting-subst to change the string. Vla-get-textstring Vl-string-subst Vla-put-textstring Quote
pkenewell Posted November 15, 2019 Posted November 15, 2019 @Lem It appears to me that this has to do with the fact that when you are searching for strings, you looking for the literal value in the text string of the object. Fields don't actually store the literal value within the string, but only a set of codes pointing to where the field is referencing the information from. Using a simple string compare would not work in this case. That begs the question - "Why would you want to change a Field value in a Text?" If you want to change a field - you have to change what the field is referencing. Example - if the field is pointing to a Drawing property, you would have to parse the field code to determine what property it is referencing, then get the property itself and update it. BTW - that also goes the same for Dimension values as well - the measured part of the dimension just reads "<>" when looking at the text string value of the dimension. Quote
Lem Posted November 16, 2019 Author Posted November 16, 2019 @pkenewell I attached a drawing with X representing a text then "L= field that tells the lenght of polyline. If i wanna replace "X" with "Y" with the lisp, it wont work if the object is a Mtext. it will work with text though. Test.dwg Quote
