Robmercury Posted January 29, 2009 Posted January 29, 2009 Hi all, Can you copy from paper space and paste it on to the same drawing which is on Model space. i.e if I have a drawing on model space and dimension on paper space can the dimension be moved over on to model space. Many thanks RM Quote
Tiger Posted January 29, 2009 Posted January 29, 2009 yes. Copy and Paste works just fine. But the dimensions are probably not the same scale, so you'll need to scale it up. Quote
Tiger Posted January 29, 2009 Posted January 29, 2009 Try the Chspace command ah yes. CHSPACE does the scaleing for you right? Quote
Attila The Gel Posted January 29, 2009 Posted January 29, 2009 If by any chance yous viewports where at scale 1:1 you can just copy with base point on your paper space and past it on the model space! If your scale is set differently you can also copy/past and then use scale to reference! Quote
Attila The Gel Posted January 29, 2009 Posted January 29, 2009 Try the Chspace command nice and easy! thx, I'll put this in the 'Must not forget cmd's'. Quote
Robmercury Posted January 29, 2009 Author Posted January 29, 2009 Thank you all So Much. CS Worked great. RM Quote
