prodromosm
Help with multy area lisp
prodromosm
Hi am using this code to calculate and insert area text in multyple polygons. I have a problem with the annotation text size.
1) I want in paper space the text size 2.5 and in model space if tor example the  annotation scale set to 1:200 the size of the text be 0.5.
2) I want the insert text justify center
Can any one help ?
;;; Calculate area of closed polyline and place text in Sq.m in center of closed area
;;; Modified by Igal Aberbuh 2016
(defun C:at (/ acsp adoc ar axss hgt maxp minp obj p1 p2 pc ss txt)
(COMMAND "_layer" "_m" "_Area" "_c" "41""" "")
(command "_.-style" "_Multy Area" "arial.ttf" "_annotative" "_yes" "_no" 2.5 1.0 0.0 "_no" "_no" "_no")
(vl-load-com)
(setq adoc (vla-get-activedocument
(vlax-get-acad-object)
(if (and
(= (getvar "tilemode") 0)
(= (getvar "cvport") 1)
(setq acsp (vla-get-paperspace adoc))
(setq acsp (vla-get-modelspace adoc))
(vla-startundomark (vla-get-activedocument
(vlax-get-acad-object)))
(initget 7)
(setq textsize 1)
;(setvar 'textsize
;(cond ((getdist (strcat "\nSpecify Area text height by two points on screen : ")))
;((getvar 'textsize))
(prompt "\nSelect objects on screen to add area label")
(if (setq ss (ssget))
(setq axss (vla-get-activeselectionset adoc))
(vlax-for obj axss
(if (not
(vl-catch-all-error-p
(setq
ar (vl-catch-all-apply
(function (lambda()
(vlax-curve-getarea obj)))))))
(setq txt (strcat "Area = " (rtos ar 2 2)"m²"))
(vla-getboundingbox obj 'minp 'maxp)
(setq p1 (vlax-safearray->list minp)
p2 (vlax-safearray->list maxp)
pc (mapcar (function (lambda(a b)(/ (+ a b) 2))) p1 p2)
(vlax-invoke acsp 'Addtext txt pc (getvar 'textsize))
(vla-endundomark (vla-get-activedocument
;change layer to 0
(mapcar 'setvar '(clayer cecolor celtype celweight) (list "0" "BYLAYER" "BYLAYER" -1))
Thanks
Share this post
Link to post
prodromosm
Any ideas?
Share this post
Link to post
devitg
Please upload your-real-sample.dwg with such sample , as in in Model as in Paper
Share this post
Link to post
BIGAL
A couple of suggestions
(setq ss (ssget)) add a filter to select only "LWPOLYLINE"
Set your text style to one which is annotative (getvar 'textstyle) check if what you want
Some one will correct me but not sure if using VL can add "center" rather have to amend the text object after creation. If use (command yes "c" is an option.
;not tested
(setq obj (vlax-invoke acsp 'Addtext txt pc (getvar 'textsize)))
(vla-put-alignment obj 1)
Share this post
Link to post
prodromosm
Hi BiGAL. I cant figure it out. The problem is in  text size and
Quote
Edited by prodromosm
Share this post
Link to post
prodromosm
I add the filter to select polylines and automatic insert the Area text. Now i need help with the text size and the justification center
(vl-load-com)
(if (and
(initget 7)
(setq textsize 1)
;(setvar 'textsize
(if (setq ss (ssget "X" (list (cons 0 "*POLYLINE"))))
(vlax-for obj axss
(if (not
(setq
(function (lambda()
;change layer to 0
Thanks
Share this post
Link to post
dlanorh
Try the attached. I've adapted one of my older routines to work as required, but it inserts MText not text.
PolyArea.LSP
Share this post
Link to post
prodromosm
Thank you dlanorh
Share this post
Link to post
BIGAL
I posted the answer for "center" (vla-put-alignment obj x) the x changes the alignment I would have to figure out the "Center" value.
Share this post
Link to post
prodromosm
Thanks BIGAL
Share this post
Link to post
