Hednei carlos Marangoni Posted November 28, 2019 Posted November 28, 2019 Ola pessoal, sou desenvolvedor AutoLISP e gostaria de saber se tem como usar o AutoLISP num AutoCAD LT, pois um Cliente meu adquiriu um LT. Obrigado, Hednei Marangoni Quote
Cad64 Posted November 29, 2019 Posted November 29, 2019 Translation: Quote Hello everyone, I am an AutoLISP developer and would like to know if you can use AutoLISP on an AutoCAD LT, because a Client of mine has purchased an LT. The answer is no. If your client is using Autocad LT then they cannot use Lisp routines. It's one of the limitations of LT. Quote
steven-g Posted November 29, 2019 Posted November 29, 2019 With LT the only automation available are command scripts or macro's. You will be out of luck with Lisp. Quote
BIGAL Posted November 30, 2019 Posted November 30, 2019 Excel can be used to do the calcs using VBA but must use scripts to load the commands to draw. Better approach look at clones Briscad, Intellicad, Karelcad Quote
