brandalf_the_semiGray
Boolean logic to change color of objects?
Is it possible to use an if statement of some sort to alter the color of an object in a block? A block I'm making has a bunch of slope data, and based on that slope data I want to change the color of an object to symbolize a pass/fail of sorts.
Thanks in advance for any input.
Share this post
Link to post
I'm leaning towards using vla objects at this point.
Share this post
Link to post
ronjonp
Your post is very vague. Perhaps post a sample drawing of before and after of what you're looking for.
Short answer is yes .. if statements are very common. The part we're missing about your post is the actual logic required to determine what a pass fail is.
Share this post
Link to post
Sorry about that. I'm not at a place where I have a drawing completed just yet, but I can post one when I have something like what I'm aiming for
I want to supply a routine with upper and lower bounds for slope values. Then, based on the slope values of individual blocks, change the color of a circle in the middle of each block.
For example:
if(all slopes are in bounds) turn circle green, else turn circle red
Share this post
Link to post
ronjonp
Here is a simple example of checking if a number is within a range:
(defun _inrange (n ln un) (<= ln n un))
(vla-put-color
  o
  (if (_inrange 2 1 2)
    3
    1
Share this post
Link to post
(vla-put-color
  o
    3
    1
Would you be willing to explain the function argument syntax for me? I'm very new to this and not familiar. Thank you
EDIT: wait i think i figured it out. The (<= ln n un) could be the one line of the code for the function while the (n ln un) are the arguments correct?
Edited by brandalf_the_semiGray
Share this post
Link to post
ronjonp
That is correct :)
n = number to check
ln = low range number
un = upper range number
  • Thanks 1
Share this post
Link to post
dlanorh
If you make the circle color by block and everything else bylayer the changing the color of the block will change the color of the circle whilst everything else remains the same
Share this post
Link to post
Grrr
(vla-put-color
  o
    3
    1
(setq _inrange <=)
(_inrange 2 1 2) >> nil
(_inrange 1 2 3) >> T
:lol:
Share this post
Link to post
ronjonp
On 12/7/2019 at 2:24 PM, Grrr said:
(setq _inrange <=)
:lol:
:) .. there is also that!
Share this post
Link to post
Grrr
duh, apologies - I didn't realised that you changed the position of the arguments, due my setq is not the same as your defun.
:facepalm:
Share this post
Link to post
