Rotated dimension keeps moving off snap points in paperspace
G'day,
Does anyone know why my rotated dimension keeps moving from it's current postion? I'm dimensioning (in paper space) a 3d pipe drawing and everytime i go into model space or into another layout, some of the dimension move to the right of screen. The whole dimension is increased too. I'm not moving or adjusting any pipes in model space only adding lines to show sections or planner group.....:x
It happen again when i was stretching the viewport by it grip points. Its obviously to me that this is the coarse. Any ideas why this happens?
I just checked the associative setting using DIMASSOC and their set on (2). So the answer is yes.
Try turning your dim 'association' off as an experiment. If your dims are still moving then you will have ruled out 'association' as a problem.
3D AutoCAD Pipework – http://www.HerculeDesign.com
  • 2 weeks later...
yes thats the problem, dim association set on 2 and when the geometry is moved, so does the dim. Thanks
