Faiz Izzuddin Posted December 25, 2019 Posted December 25, 2019 Hello guys, Im faiz and i need help from those already expert in solidwork. I want create bend cone for my bike pipe. The aims here is to create drawing in “.dxf” but i stuck at flatten the cone. My steps to create bend cone is create two different diameter at different face then i lofting it by using centreline parameter. But i cant flatten the cone. Tq in advance Quote
stevsmith Posted January 27, 2020 Posted January 27, 2020 On 12/25/2019 at 12:33 PM, Faiz Izzuddin said: Hi Faiz, It depends on how you are modelling the part. Either as a solid part or using sheet metal. If created using solid. Create your loft as described previously. Once the solid is created, you then need to use the shell command to remove the open ends and also create the thickness of the "pipe" section. As a revolved object, you need to remove a section of material. (imagine the two edges of a cylinder coming together for welding. Create a gap equal to the material thickness from one open end to the other. Convert the object to sheet metal and follow the instructions. (e.g. thickness, k-factor etc.) You should then be able to flatten the pipe/sheet metal. I have not had access to solidworks for several years, so I'm tring to do this from memory. Quote
