bruce13557
Naming solids
bruce13557
Is it possible to name a solid object without making it a block? eg. TOP PLATE 3.
Share this post
Link to post
Cad64
As far as I know, it's not possible to name a solid object, but you could create a layer called TOP PLATE 3 and put your object on that layer.
You could also create a material called TOP PLATE 3 and then apply it to the object.
Both of these options would allow you to then select the object by either its material type or by the layer it's sitting on.
Share this post
Link to post
ReMark
Could you not make it a GROUP of one?  The GROUP command does allow for naming.
Share this post
Link to post
ReMark
"Groups suck."
Yes and so does gravity.  Try being a little more courteous.  It was merely a suggestion not an order.  Thank you and have a sparkling day.
Share this post
Link to post
Cad64
I think it's strange that Autocad doesn't allow the naming of solids. Every other 3D program I've used allows you to name the various parts of your model, which is actually kind of important when working on large projects.
Share this post
Link to post
43st
Confirmed! groups indeed suck. 😛
I've put part numbers in the hyperlink field before, more as a mental note for later than anything else. If you are doing 3D this can sometimes interfere with editing. (CTRL + click will try to launch the hyperlink, and not select the solid face).
Share this post
Link to post
bruce13557
That AVC plugin seems to work quite well
Share this post
Link to post
BIGAL
2 ideas use Xdata and second which is I think what AVC is doing "Property sets".
Re the property sets having problems creating/extracting info anybody out there know how, for a different request. Found some info using VBA.
Share this post
Link to post
