JoeyG_77
If Then Statement ... ?
JoeyG_77
I have a block that is used multiple times in a dwg & it needs to show text w/ an "HD" when another certain attribute is larger than 9, but not show when its less than 9.  I've looked at diesel & a field but reading up they seem not to work well together.  All help would be much appreciated.
Thanks
Joey G
Share this post
Link to post
Lee Mac
The difficulty is that Formula Field expressions can reference nested Object Property Fields (such as Attribute Values), but do not support conditional statements, and DIESEL Field expressions support conditional statements but cannot reference nested Object Property Fields... Whilst it is certainly possible (and relatively easy) to populate the attribute values using a program, I don't think this is possible to achieve using out-of-the-box functionality.
Edited by Lee Mac
Share this post
Link to post
JoeyG_77
Lee ,
Thanks for the response !  What would you do in this situation ? Would it be more of a lisp that would have to be run after all the blocks are in place and then run and it would analyze all the blocks and add what was needed or not.
Thanks
Joey G
Share this post
Link to post
Lee Mac
Personally, I would develop a program to operate on all such blocks in your drawing automatically (without any user input), and then configure the program to run either on drawing startup, or before the SAVE/PLOT commands using a basic VL Reactor.
Such a program might look like this:
(defun c:updateblocks ( / at1 at2 blk dst idx lst num sel src vl1 vl2 )
    (setq
        blk "myblock" ;; Block Name
        src "tag1"    ;; Source Attribute Tag
        dst "tag2"    ;; Destination Attribute Tag
        vl1 "HD"      ;; Value 1
        vl2 ""        ;; Value 2
    (if (setq sel (ssget "_X" (list '(0 . "INSERT") '(66 . 1) (cons 2 blk))))
        (repeat (setq idx (sslength sel))
            (setq lst
                (mapcar '(lambda ( a ) (cons (strcase (vla-get-tagstring a)) a))
                    (vlax-invoke
                        (vlax-ename->vla-object (ssname sel (setq idx (1- idx))))
                        'getattributes
            (if (and (setq at1 (cdr (assoc (strcase src) lst)))
                     (setq at2 (cdr (assoc (strcase dst) lst)))
                     (setq num (distof (vla-get-textstring at1) 2))
                     (vlax-write-enabled-p at2)
                (vla-put-textstring at2 (if (< 9 num) vl1 vl2))
(vl-load-com) (princ)
The above is designed for standard (i.e. non-dynamic) blocks only.
Edited by Lee Mac
Share this post
Link to post
JoeyG_77
Lee thanks for always helping out.  Im having some issue with the lisp . Im attaching the lisp filled out and the block itself to see.
    (setq
        blk "Blum Motion" 	;; Block Name
        src "Drawer_Depth_HD"   ;; Source Attribute Tag
        dst "HD1"    		;; Destination Attribute Tag
        vl1 "Heavy"    		;; Value 1
        vl2 ""     		;; Value 2
            (setq lst
                    (vlax-invoke
                        'getattributes
                (vla-put-textstring at2 (if (> 17 num) vl1 vl2))
DRW.dwg
Share this post
Link to post
Lee Mac
The issues are twofold:
  • As stated, the program I posted was only compatible with standard (non-dynamic) blocks.
  • "Drawer_Depth_HD" is a dynamic block parameter, not an attribute - perhaps you meant to reference the attribute "D"?
I'll see if I can find some time to update the program for dynamic blocks.
Share this post
Link to post
Lee Mac
Try the following:
    (setq
        blk "BLUM MOTION" ;; Block Name
        src "D"           ;; Source Attribute Tag
        vl1 "HD"          ;; Value 1
        vl2 ""            ;; Value 2
    (if (setq sel (ssget "_X" (list '(0 . "INSERT") '(66 . 1) (cons 2 (strcat "`*U*," blk)))))
            (setq idx (1- idx)
                  obj (vlax-ename->vla-object (ssname sel idx))
            (if (or (and (vlax-property-available-p obj 'effectivename)
                         (wcmatch (strcase (vla-get-effectivename obj)) blk)
                    (wcmatch (strcase (vla-get-name obj)) blk)
                    (setq lst
                            (vlax-invoke obj 'getattributes)
Share this post
Link to post
JoeyG_77
Lee, I cant thank you enough man! Im sorry btw you did say that the first one you wrote was for non dynamic. I didnt see it until this morning =/ . The only thing is that I do need it to read the D1 & the issue is that it cant read the HD suffix that is attached to the number.  I tested it and if I remove the HD suffix the lisp runs perfect, but the HD needs to stay.  Thanks for all your help
Joe
Share this post
Link to post
Lee Mac
You're welcome Joey - rather than going backwards & forwards on the forum, I'll continue to refine this with you offline.
Share this post
Link to post
