jim78b Posted January 9, 2020 Posted January 9, 2020 i saw that when i use hatch and autocad must work a lot, the antialiasing (smooth display) will disable, i go in graphics settings but it is enable, must i check uncheck for reanble the smooth display. why? Quote
BIGAL Posted January 10, 2020 Posted January 10, 2020 (edited) A regen should fix and there are regen settings look at help. Its about speeding up in between. Edited January 10, 2020 by BIGAL Quote
jim78b Posted January 10, 2020 Author Posted January 10, 2020 No Regen not fix because depend on smooth display in 3dconfig settings. Quote
SLW210 Posted January 10, 2020 Posted January 10, 2020 What are the Computer and Graphics Specifications? Quote
jim78b Posted January 10, 2020 Author Posted January 10, 2020 Intel core i7 64 bit 16 giga Ram nvidia quadro k600 win7. Quote
SLW210 Posted January 13, 2020 Posted January 13, 2020 Which Driver? You may need to use the 3D setup in the Nvidia Control Panel (right-click on Desktop). https://www.nvidia.com/content/Control-Panel-Help/vLatest/en-us/mergedProjects/nv3d/Tips_for_Setting_Antialiasing.htm Is there an onboard Intel graphics card also? Sometimes that can cause problems. https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCAD-uses-the-wrong-graphics-card.html Quote
Lauwen Posted March 3, 2020 Posted March 3, 2020 Disable Smooth Line Display. On the command line in AutoCAD, type LINESMOOTHING and set it to Off or 0 (zero). Notes: Smooth Line Display can also be turned off in the Graphics Performance window Quote
