So, we got new backgrounds for this job and i cant get it to flatten into 2d from 3d. Ive tried using the flatten.lsp and another lisp i found called flat.lsp and neither worked. i tried exploding the entire dwg and then trying both of those and still it didnt work. Im trying to make the file smaller so i can upload it but if you have any suggestions in the mean time on how to do it let me know
i tried the zerolisp it didnt work. I just registered for theswamp and will try that out as soon as it lets me
What about selecting all objects and changing the Z elevation property to 0?
Change - Properties - Elevation - 0
Perhaps I'm way off with what you're actually doing...
What does it say in the command bar after you run the flatter comand or flat lisp?
did you try this...?
; Flatten a 3D drawing
; Written by Eduard
; This command will set all elevations and points to zero, effectively flattening any 3D drawing.
(defun c:flat (/ total-nabor)
(vl-load-com)
(if
(setq total-nabor (ssget "x" '((410 . "model"))))
(setq total-nabor
(mapcar 'vlax-ename->vla-object
(mapcar 'cadr
(ssnamex total-nabor)
) ;_ end of mapcar
) ;_ end of mapcar
) ;_ end of setq
(foreach i '(1e99 -1e99)
(mapcar (function (lambda (x)
(vla-move x
(vlax-3d-point (list 0 0 0))
(vlax-3d-point (list 0 0 i))
) ;_ end of vla-move
) ;_ end of lambda
) ;_ end of function
total-nabor
) ;_ end of mapcar
) ;_ end of foreach
) ;_ end of progn
) ;_ end of if
) ;_ end of defun
