[SOLVED] ssget: How to filter dimension text height?
haisagiviz
Hi All,
I am using ssget to filter select some of properties to modify. I searched and tried many way to filter text height of dimensions but I cannot.
(ssget '( (0 . "DIMENSION") (what dxf group code?) ))
Please help me.
Thanks in advance.
HAI
5 minutes ago, haisagiviz said:
Hi All,
Please help me.
Thanks in advance.
HAI
Look Here and bookmark it
  • Thanks 1
Thank @dlanorh so much.
I will read until have a solution. :D
Result: Sorry but I saw in all of Dimension have no any dxf reference for Text height.
Edited by haisagiviz
Use the code given on Autodesk Forum and try substituting
(not (< 120 (getpropertyvalue en "Dimtxt") 160))
for
(not (equal (getpropertyvalue en "Dimtxt") th 1e-6)
  • Thanks 1
for
Thank you very much @dlanorh
I can filter and do something with your support.
For newbie want to filter Dimension Text Height like me.
From BeekeeCZ (Autodesk Forum)
(defun c:test (/ ss th i en)
  (if (and (setq th (getreal "\nText height you search for: "))
	   (setq ss (ssget '((0 . "DIMENSION"))))
      (setq en (ssname ss (setq i (1- i))))
      (if (not (equal (getpropertyvalue en "Dimtxt") th 1e-6))
	(ssdel en ss))))
  (sssetfirst nil ss)
  • haisagiviz changed the title to [SOLVED] ssget: How to filter dimension text height?
