Colm Gogan Posted February 5, 2020 Posted February 5, 2020 I and a few of my colleagues have noticed that when publishing a number of sheets (Approx 10 or more) in AutoCAD 2019 the programme regularly crashes to an extent that it is completely unreliable. We therefore generally publish in AutoCAD 2016 which doesn’t seem to have the same issue. This workaround however creates its own set of problems and is not an ideal solution. The PC’s seems to run low on Virtual memory before the programme crashes, even though they are very hi spec laptops. We would ideally like to be able to publish using AutoCAD 2019 as designed. Has anybody else had the same issues? When looking on various forums it doesn’t seem to be a very common issue. Quote
