gotchy
How to add font to Solidworks from Word.
gotchy
Can someone here explain the procedure to add a font to the font library of Solidworks  2019 from Microsoft Word?
Thank you,
Gotchy
Share this post
Link to post
BIGAL
Don't use Solidworks but a Google suggested that it uses TTF true type fonts so if Word finds it so should Solidworks. Change the font style.
Share this post
Link to post
stevsmith
Bear in mind that even if you install a font for Solidworks it will be on your PC.
Sending files or using SW in a collaborative environment would require all PC's have that particular font installed on the users PC otherwise, an alternative font may load.
Share this post
Link to post
gotchy
Thank you Gentlemen.  I am having problems installing two   fonts.  evidentally there is an issue with an upgrade from MS that is yet unresolved, causing problems.
Gotchy
Share this post
Link to post
