I'm hoping someone could help me with a lisp that will do the following..
1. swap all instances of a block with another block (keeping location, rotation, scale)
2. change that new block to a new layer.
i'd like to automate this through the use of a csv file. If the old block doesn't exist, skip it.
oldblock1,newblock1,newlayer1
oldblock2,newblock2,newlayer2
Any help would be appreciated
I did find this code on the forum, but i'm unsure how to alter it.
; ; thanks to Lee-mac for this defun
(defun _csv->lst ( str / pos x lst lst2)
(if (setq pos (vl-string-position 44 str))
   (cons (substr str 1 pos) (_csv->lst (substr str (+ pos 2))))
   (list str)
(defun c:ins->csv ( / fo x)
(setq fo (open (getfiled "Choose CSV file" "G:/AutoCAD/Lisp/" "CSV" ) "R")
(while (setq ans (read-line fo))
(setq lst (cons (_csv->lst ans) lst))
(setq y (length lst))
(setq x (- y 1))
(repeat y
(setq lst2 (nth x lst))
;(setvar 'clayer (nth 6 lst2))
(command "insert" (nth 0 lst2) (strcat (nth 1 lst2)","(nth 2 lst2)","(nth 3 lst2)) 1 (nth 5 lst2) (nth 7 lst2) (nth 8 lst2))
(setq x (- x 1))
) ; end defun
Edited by therealjd
