OMEGA-ThundeR Posted February 10, 2020 Posted February 10, 2020 (edited) Hi, A custumer asked if i can change the heightmap (about 2000 survey points) relative to 1 point. I currently have a survey i did that has all text based heights. In civil 3D i used 'movetext2elevation' to make the text go to the z-height of the text value. Then i moved all the text to that 1 relative point to Z=0.000 Let's say that 1 point once was 15.00+ and one next to one is 15.50+. By moving that 1 point to 0.00 that other point is now at a Z-value of 0.50+. However the textvalue still says 15.50+. I would like to know if there is a command or lisp that changes the textvalue to the current Z-value of that text. So the end result is 2 texts that have a text-value AND a Z-value of 0.00 and 0.50 Is that possible? Edit: I Now have used a lisp called 'txt2pt' to create points and used another lisp (down here) to label the points with it's Z-value. Does the same, but is a bit more work... Edited February 10, 2020 by OMEGA-ThundeR Quote
CyberAngel Posted February 10, 2020 Posted February 10, 2020 Since you have Civil 3D, couldn't you create a surface and move it? That would take care of the label values. Quote
