Sign in to follow this
nj1105nj
Seem to be getting a CLayer Nil return on this very simple Lisp code. Any ideas?
nj1105nj
This is just a lisp to draw a 6' circle on our no plot layer, set the line weight, and change the color to magenta, and finally change back all the set variables
(defun C:mrs
      (setvar "clayer" nplt)
      (setvar "celweight" -2)
      (setvar "cecolor" magenta)
      (command "circle" "6")
      (setvar "clayer" 0)
      (setvar "cecolor" bylayer)
      (setvar "celweight" bylayer)
Share this post
Link to post
Tharwat
You set the current layer with nil variable but if that is the name of the layer then you need to wrap it with two strings all around. eg: "nplt"
Share this post
Link to post
nj1105nj
so it should be like this? It's still saying the Clayer Nil was a rejected variable
(defun C:mrs
      (setvar "clayer" "nplt")
      (setvar "clayer" "0")
Share this post
Link to post
Tharwat
Is this what you are after?
(defun c:mrs nil
  (if (tblsearch "LAYER" "nplt")
      (setvar "cecolor" "6")
      (command "circle" "6" "\\")
      (setvar "cecolor" "bylayer")
      (setvar "celweight" -1)
    (alert "Layer name <nplt> was not found <!>")
  • Thanks 1
Share this post
Link to post
nj1105nj
(defun c:mrs nil
That seems to have done the trick, thank you!
Share this post
Link to post
Tharwat
You need to disable the OSNAP system variable to ensure is that the center point of the circle would be positioned in the right destination as follows.
 (command "circle" "_none" "6" "\\")
Share this post
Link to post
Roy_043
Hmm, have the prompts of the circle command really been changed around in AutoCAD?
Edited by Roy_043
Typo.
Share this post
Link to post
BIGAL
Note also (setvar "cecolor" magenta) magenta would be expected to be a lisp value called Magenta, hence Tharwat's code using a string number.
Edited by BIGAL
Share this post
Link to post
