Anushka Posted February 13, 2020 Share Posted February 13, 2020 (edited) why the code doesn't work ?? I'm trying to develop a snippet report, I need to export to a .csv the color of the polyline and the block it is passing, Example: RED or 1; 01; 02; 65 I'm trying this way and I don't know why it doesn't work, can someone help me ??? example of .dwg, I thank you already !!! (defun c:SS () (setq ss (ssget '((0 . "LWPOLYLINE")))) (setq file (open (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname)) ".csv") "w")) (write-line "color;Start") (repeat (setq i (sslength ss)) (setq plineobj (vlax-ename->vla-object (setq entname (ssname ss (setq i (1- i)))))) (setq entdata (entget (ssname ss 0))) (setq ll (vl-remove-if 'not (mapcar (function (lambda ( p ) (if (= 10 (car p))(:Addzerolist 0.00 2 (cdr p))))) entdata))) (foreach ponto ll (progn (if (and (setq selptsvert (ssget "_C" (mapcar '+ ponto '(5 5)) (mapcar '- ponto '(5 5)) '((0 . "INSERT") (2 . "`*U*")))) (= (sslength selptsvert) 1) ) (progn (setq blkt (vlax-ename->vla-object (ssname selptsvert 0))) (setq tt (LM:vl-getattributevalue blkt "NUMBER")) ) ;;(exit) ) (write-line tt file) (close file) ) ) ) ) Edited February 14, 2020 by Anushka Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 14, 2020 Share Posted February 14, 2020 Made a couple of changes the 1st was defun name it did not like ss. Got to lee's get attributes I normally code that in its only about 4 lines. So did not test further. (defun c:SSzz () (setq ss (ssget '((0 . "LWPOLYLINE")))) (setq file (open (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname)) ".csv") "w")) (write-line "color;Start") (repeat (setq i (sslength ss)) (setq entdata (entget (ssname ss (setq i (- i 1))))) (setq ll (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) entdata))) (foreach ponto ll (progn (if (and (setq selptsvert (ssget "_C" (mapcar '+ ponto '(5 5)) (mapcar '- ponto '(5 5)) '((0 . "INSERT") (2 . "`*U*")))) (= (sslength selptsvert) 1) ) (progn (setq blkt (vlax-ename->vla-object (ssname selptsvert 0))) (setq tt (LM:vl-getattributevalue blkt "NUMBER")) ) ) (write-line tt file) (close file) ) ) ) ) (foreach att (vlax-invoke (vlax-ename->vla-object (ssname selptsvert 0 )) 'getattributes) (if (= (vla-get-tagstring att) "NUMBER") (setq tt (vla-get-textstring att )) ) ) Quote Link to comment Share on other sites More sharing options...
