Excerpts in .csv
Anushka
why the code doesn't work ??
I'm trying to develop a snippet report, I need to export to a .csv the color of the polyline and the block it is passing,
Example: RED or 1; 01; 02; 65
I'm trying this way and I don't know why it doesn't work, can someone help me ???
example of .dwg, I thank you already !!!
(defun c:SS ()
  (setq ss (ssget '((0 . "LWPOLYLINE"))))
  (setq file (open (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname)) ".csv") "w"))
  (write-line "color;Start")
    (setq plineobj (vlax-ename->vla-object (setq entname (ssname ss (setq i (1- i))))))
    (setq entdata (entget (ssname ss 0)))
    (setq ll (vl-remove-if 'not (mapcar  (function (lambda ( p ) (if (= 10 (car p))(:Addzerolist 0.00 2 (cdr p))))) entdata)))
    (foreach ponto
	     ll
	(if
	  (and
	    (setq selptsvert (ssget "_C" (mapcar '+ ponto '(5 5)) (mapcar '- ponto '(5 5)) '((0 . "INSERT") (2 . "`*U*"))))
	    (= (sslength selptsvert) 1)
	    (setq blkt (vlax-ename->vla-object (ssname selptsvert 0)))
	    (setq tt (LM:vl-getattributevalue blkt "NUMBER"))
	  ;;(exit)
	(write-line tt  file)
	(close file)
Edited by Anushka
Made a couple of changes the 1st was defun name it did not like ss.
Got to lee's get attributes I normally code that in its only about 4 lines. So did not test further.
(defun c:SSzz ()
    (setq entdata (entget (ssname ss (setq i (- i 1)))))
    (setq ll (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) entdata)))
    (foreach ponto
	     ll
	(if
	  (and
	(close file)
(foreach att (vlax-invoke (vlax-ename->vla-object (ssname selptsvert 0 )) 'getattributes)
        (if (= (vla-get-tagstring att) "NUMBER")
           (setq tt (vla-get-textstring att ))
