Have You Tried: Rotate and Scale Objects in AutoCAD By Reference
The AutoCAD Blog
Commonly, a base point and then an angle or a scale factor is specified to rotate or scale selected objects. However, that workflow might not always provide for the best control over the outcome. Did you know you can rotate or scale an object relative to two other points?
The Reference option of the ROTATE and SCALE commands and the ALIGN command allow you to:
• Rotate objects to an absolute angle
• Scale objects to fit between two points
Here are some examples of rotating and scaling objects by reference with the ROTATE, SCALE, and ALIGN commands in the image below.
rotate and scale in AutoCAD
You can learn more about rotating and scaling objects by reference with the step-by-step examples in the Have You Tried: Rotate and Scale Objects by Reference topic.
Keep the Feedback Coming
Thanks for all the great feedback submitted so far. Because of the great feedback, we have been able to improve the topics in the AutoCAD Online Help system. Updated Help Topics contains a list of the most recently updated topics.
The best way to submit feedback is by using the “Was this helpful?” section located at the bottom of every Help topic. Let us know what you like or don’t like about a topic or provide suggestions for other subjects that you’d like to see covered in greater detail. The more specific your comments, the better.
