wee Posted February 26, 2020 Posted February 26, 2020 In 2018 they made a change where you could zoom in and select and point then zoom into another area and it would keep all points or lines selected. That just today seems to be broken on my system and reverts back to the old way...IE if the lines are not on the screen they will be unselected. If I open the same dwg in 2020 it works as it should. Is there a system variable that controls this....? I checked the selection tab in the options and both 2018 and 2020 are the same. Brian Quote
wee Posted February 26, 2020 Author Posted February 26, 2020 SELECTIONOFFSCREEN System Variable found it after posting here. Brian Quote
