samifox
Lock viewport scale
samifox
when in layout double-clicking in viewport access the model space temporarily.
if you accidentally roles the middle mouse button you might slightly change the scale.
I want to set my preferred scale to be 1:10 and restrict those unwanted scaling. locking a viewport doesn't solve the issue because the locking cause panning the whole layout. I want to be able to pan the model space only without panning the layout.
how it is nativly possible?
Tx
SHay
Share this post
Link to post
eldon
Very carefully!!
Do not use the scroll wheel!
Pan by starting the Pan command, or hold down the left mouse button (if it is set up that way).
Also when you have finished, check the viewport scaling.
Share this post
Link to post
RobDraw
It is not possible. The viewport is either locked or unlocked. You can't lock scale and unlock panning. I lock all of my viewports and if I need to change the view, I adjust the actual viewport using grips instead of panning. It works quite well.
Share this post
Link to post
samifox
nothing is imposiible with all the API autocad has. just wanna make sure no native option to do that before developing a solution.
Share this post
Link to post
RobDraw
In the context of your question as stated, it is not possible.
I gave you native solution.
You're welcome.
Share this post
Link to post
eldon
I should have prefaced my above remarks with "In an unlocked viewport..."
Then panning is possible, but check the scale and lock the viewport after panning.
Share this post
Link to post
samifox
sorry being rude.
if you didnt notice...autodesk should take care of it. seems like elementry wish.
tx
Share this post
Link to post
RobDraw
Sometimes, what seems like a simple software solution is not so simple in reality and wishing for it is an exercise in futility.
Share this post
Link to post
dtkell
You may want to try the "vpmax" command.
Enter command, pick viewport, and that viewport becomes maximized.
You can zoom, pan, orbit, or whatever to change what you're looking at, and when you enter "pspace" to exit, your viewport goes back to its original orientation.
  • Thanks 1
Share this post
Link to post
Dana W
That is exactly the correct solution.
Share this post
Link to post
BIGAL
In an unlocked viewport zoom to where you want pan so its in middle zoom to what you think is about right, then use zoom scaleXP for metric its easy as its a function say of 1000 4xp=1:250 then pan a bit if required then lock.
Will look at vpmax though learn some thing new every day.
Edited by BIGAL
Share this post
Link to post
