hi
if i create a multi-leader, i play with its properties and i can see the effect as i play, when i like the result, i want to override the style values with the new result.
is it possible?
Tx
Shay
Don't think you can create a style from the overrides. Just make note of the settings and create a new style or adjust an existing one.
where is the wishlist located?
Right-Click>Multileader Style>Save as New Multileader Style.
Might be available in AutoCAD 2010. Why would you want to add to the wish list when you use a very old version?
