Sambuddy
Automated Reactor - Request for idea
Sambuddy
Hey guys,
I wrote a routine that automatically change the setting or copy files from server onto C drive. What I am looking for is an idea to invoke these changes each time I make any changes on the source folder. I do not want to search for changes, but rather I was thinking let's say acaddoc evaluate something or through a lisp I tell it to < Update is available. Do you want to update? > for directories on anyone's C Drive if I make any changes on the source directory. I am looking for an idea...
I have about 10-15 folders and sub-folders with all bunch of extensions on the server - when I finished editing them, I was thinking to write a routine to say < Ready to distribute? Yes or No > on my end. When I say "Yes", then for computers that are mapped on C drive, they would get a message "Update is available. Do you want to update? yes or no"
I am just fiddling with this idea - any better idea?
I DO NOT want to invoke it every time a session is starting or autocad is starting - rather a creative way to invoke it...
on a different note, How do I evaluate blah.txt for a date change, if outdated then execute the copy routine, if not business as usual?
Thanks guys
Edited by Sambuddy
Share this post
Link to post
Sambuddy
I actually like this on :  https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/need-to-compare-quot-lsp-quot-last-modified-date/td-p/4638319
but I do not know how to work with it:
If I add this to acaddoc to invoke and evaluate for a specific text file modified date, does anyone know how to make it happen?
Let's say if I have a C:/blah/blah.txt on local machines but I went ahead and opened and saved T:/blah/blah.txt, on the cad startup, how can I evaluate T if older than the one on C then do things.
Can someone help?
Thanks guys
;; Returns T if f1 has been modified more recently than f2
(defun newer-p ( f1 f2 / compare )
    (defun compare ( a b )
        (cond
            (   (> (car a) (car b)))
            (   (and a b (= (car a) (car b)))
                (compare (cdr a) (cdr b))
    (apply 'compare
        (mapcar '(lambda ( x ) (vl-list* (car x) (cadr x) (cdddr x)))
            (mapcar 'vl-file-systime (list f1 f2))
Share this post
Link to post
BIGAL
You may need to convert to a number what systime returns. Ctoj is a julian date function as part of express tools.
(setq a (vl-File-systime filename))
(ctoj (nth 0 a)(nth 1 a)(nth 2 a)(nth 3 a)(nth 4 a)(nth 5 a))
Share this post
Link to post
dlanorh
Can someone help?
Thanks guys
        (cond
    (apply 'compare
See the last few lines for how to use it. file1 & file2 should include the full path to each file.
        (cond
    (apply 'compare
;; THIS IS THE EXAMPLE OF HOW TO USE IT
(setq file1 "someFile"
      file2 "someOtherFile"
(if (newer-p file1 file2)
(princ (strcat file1 " is newer than " file2))
(princ (strcat file1 " is NOT newer than " file2))
Share this post
Link to post
Sambuddy
@BIGAL Thanks Alan, you always saved my mess! Always!
@dlanorh Great! Now I can make sense of this a bit. I should introduce my path.
Since it is evaluating time for the condition to work, what happens if I modify blah.txt two times in a minute?
Could you please let me know?
Thank you again
Edited by Sambuddy
Share this post
Link to post
Sambuddy
I actually found my answer for the question I asked about file 1 & 2. I mean ONLY the path part not the automatic checking...
Now the second question would be, If I change file1.txt on my T drive, how do I make it so the action (in my case copying action) happens automatically without entering a command.
What I am asking is how can I ask to evaluate file1.txt every X minutes?
Your help is appreciated!
Thanks
Edited by Sambuddy
Share this post
Link to post
hanhphuc
OOTB i heard sort Dynamic WrapperX maybe able to utilize 3rd party library (but it only supports 32bit)
or google  monitoring software ?
Share this post
Link to post
dlanorh
Thanks
Google : autolisp autosave reactor
Share this post
Link to post
Sambuddy
Great!
Thanks
Share this post
Link to post
