LISP is correct in both cases: boundary is LWPOLYLINE or LINE
(defun DXF (code en) (cdr (assoc code (entget en))))
(defun Line (p1 p2) (entmakex (list (cons 0 "LINE") (cons 10 p1) (cons 11 p2))))
(defun Ray (po V)
    (entmakex (list (cons 0 "RAY")
                    (cons 100 "AcDbEntity")
                    (cons 100 "AcDbRay")
                    (cons 10 po)
                    (cons 11 v)
(defun sysvar-set (lst_setvar / strN var var_oldname n)
    (setq n 0
          lstvar_thiep nil
          lstValue_thiep nil
    (repeat (/ (length lst_setvar) 2)
        (setq var         (nth n lst_setvar)
              var_oldname (strcat "oldvar_thiep" (itoa n))
        (setq lstvar_thiep (append lstvar_thiep (list var)))
        (set (read var_oldname) (getvar var))
        (setq lstValue_thiep (append lstValue_thiep (list (read var_oldname))))
        (setvar var (nth (+ n 1) lst_setvar))
        (setq n (+ 2 n))
(defun Get-Area (lst )
    (/ (apply
           (mapcar '(lambda (a b) (- (* (car b) (cadr a)) (* (car a) (cadr b))))
                   lst
                   (cons (last lst) lst)
       2
(defun SYSVAR-RESTORE ()
    (mapcar '(lambda (var value) (setvar var (eval value)))
            lstvar_thiep
            lstValue_thiep
(defun CalcZ (Pt1 Pt2 Pt3 / v w)
    (setq v (mapcar '- Pt1 Pt2)
          w (mapcar '- Pt3 Pt2)
    (- (* (car v) (cadr w)) (* (cadr v) (car w)))
(defun calcThiep (po1 po2 po3 po4 / bit dis m anpha beta h obj_top poS poE)
    (setq anpha_org (LM:GetInsideAngle po4 po1 po2)
          beta_org  (LM:GetInsideAngle po1 po2 po3)
    (if (< dt 0)
        (setq anpha anpha_org
              beta  beta_org
        (setq anpha (- pi anpha_org)
              beta  (- pi beta_org)
    (Setq bit (CalcZ po1 po4 po2))
    (setq dis (distance po1 po2)
          ang (angle po1 po2)
    (setq m (+ (/ (cos anpha) (sin anpha)) (/ (cos beta) (sin beta))))
    (setq h  (abs (/ (- dis (sqrt (abs (- (* dis dis) (* 2 m (abs dt)))))) m)))
       (cond ((or (and (> bit 0) (> dt 0)) (and (< bit 0) (< dt 0)))
              (setq po5 (polar po2 (- ang (/ pi 2)) h)
                    po6 (polar po1 (- ang (/ pi 2)) h)
             ((or (and (> bit 0) (< dt 0)) (and (< bit 0) (> dt 0)))
              (setq po5 (polar po2 (+ ang (/ pi 2)) h)
                    po6 (polar po1 (+ ang (/ pi 2)) h)
       (setq po_in1 (inters po5 po6 po1 po4 nil)
             po_in2 (inters po5 po6 po2 po3 nil)
(defun makeLWPoly (lst)
    (entmakex (append (list (cons 0 "LWPOLYLINE")
                            (cons 100 "AcDbPolyline")
                            (cons 90 (length lst))
                      (mapcar (function (lambda (p) (cons 10 p))) lst)
(defun limS (po1 po2 po3 po4 / objL1 objL2 objR iplist)
    (line po4 po1)
    (setq objL1 (vlax-ename->vla-object (entlast)))
    (line po3 po2)
    (setq objL2 (vlax-ename->vla-object (entlast)))
    (cond ((> dt 0)
           (setq
               iplist (vlax-safearray->list
                          (vlax-variant-value (vla-intersectwith objL1 objL2 3))
           (vla-delete objL1)
           (vla-delete objL2)
           (SETQ A (Get-Area (list po1 po2 iplist po1)))
          ((< dt 0)
           (ray po4 (mapcar '- po2 po1))
           (setq objR (vlax-ename->vla-object (entlast)))
           (if (null (vlax-invoke objR 'IntersectWith objL2 acExtendNone))
               (PROGN (setq iplist (vlax-invoke objR
                                                'IntersectWith
                                                objL2
                                                acExtendOtherEntity
                   (SETQ A (Get-Area (list po1 po2 iplist po4 po1)))
               (PROGN (vla-delete objR)
                      (ray po3 (mapcar '- po1 po2))
                                                'IntersectWith
                                                objL1
                                                acExtendOtherEntity
                   (SETQ A (Get-Area (list po1 po2 po3 iplist  po1)))
           (vla-delete objL1)
           (vla-delete objL2)
           (vla-delete objR)
    (abs A)
(defun c:dht (/ ent1_lst        ent1    ent2    ent3    po1     po2     po3
                po4     ang1    ang2    ang3    dis     m       lstpo1  lstpo2
                lstpo3  lstpo-int1      lstpo-int2      anpha   beta    pS1
                pS2     pS3     pE1     pE2     pE3     h       bit     obj_top
                poS     poE     po_in1  po_in2  prom    Alim
    (command "undo" "be")
    (sysvar-set '("cmdecho" 0 "osmode" 0))
    (defun *error* (msg)
            (princ (strcat "\n** Error: " msg " **"))
        (setq dt nil)
        (acet-ui-status)
        (sysvar-restore)
        (command "undo" "en")
    (or dt (setq dt (getcfg "AppData/trapezoid/area")) (setq dt 1000))
    (acet-ui-status (setq prom
                             (acet-str-format
                                 "\nEnter Area given for to expand (+S) or to trim (-S) <%1> : "
                                 (if (numberp dt)
                                     (rtos dt 2 3)
                                     dt
                                 "LOOK AT"
    (setq olddt dt)
    (setq dt (getreal prom))
    (if (null dt)
        (setq dt olddt)
    (if (not (numberp dt))
        (setq dt (atof dt))
                             "\nPick a LINE (or LWPOLYLINE) edge for to expand (or to trim) area "
                    "LOOK AT"
    (while
        (OR (NOT (setq ent1_lst (entsel prom)))
            (NOT (wcmatch (DXF 0 (setq ent1 (car ent1_lst))) "LINE,LWPOLYLINE"))
        )  (acet-ui-status (setq prom "Pick a LINE is not right, Please pick again")
                           "LOOK AT"
           (prompt prom)
    (acet-ui-status)
    (cond
        ((eq (DXF 0 ent1) "LINE")
         (acet-ui-status (setq prom "\nPick a LINE 1st edge of the trapezoid ")
                         "LOOK AT"
         (while (OR (NOT (setq ent2 (car (entsel prom))))
                    (NOT (wcmatch (DXF 0 ent2) "LINE"))
             (acet-ui-status
                 "LOOK AT"
             (prompt prom)
         (acet-ui-status (setq prom "\nPick a LINE 2nd edge of the trapezoid ")
                         "LOOK AT"
         (while (OR (NOT (setq ent3 (car (entsel prom))))
                    (NOT (wcmatch (DXF 0 ent3) "LINE"))
             (acet-ui-status
                 "LOOK AT"
             (prompt prom)
         (acet-ui-status)
         (setq po1 (vlax-curve-getStartpoint ent1) ;_bottom edge
               po2 (vlax-curve-getEndpoint ent1)
         (setq pS2 (vlax-curve-getStartpoint ent2) ;_ 1st side
               pE2 (vlax-curve-getEndpoint ent2)
         (setq pS3 (vlax-curve-getStartpoint ent3) ;_ 2nd side
               pE3 (vlax-curve-getEndpoint ent3)
         (cond ((Equal po1 ps3 1e-2)
                (setq po4 pE3)
                (cond ((Equal po2 ps2 1e-2) (setq po3 pE2))
                      ((Equal po2 pE2 1e-2) (setq po3 pS2))
               ((Equal po1 pE3 1e-2)
                (setq po4 pS3)
               ((Equal po1 ps2 1e-2)
                (setq po4 pE2)
                (cond ((Equal po2 ps3 1e-2) (setq po3 pE3))
                      ((Equal po2 pE3 1e-2) (setq po3 pS3))
               ((Equal po1 pE2 1e-2)
                (setq po4 pS2)
        ((eq (DXF 0 ent1) "LWPOLYLINE")
         (setq po_pick (cadr ent1_lst))
         (setq po_closest (vlax-curve-getClosestPointTo ent1 po_pick))
         (setq para1 (fix (vlax-curve-getParamatpoint ent1 po_closest)))
         (setq paraE (vlax-curve-getEndParam ent1))
         (setq paraS (vlax-curve-getStartParam ent1))
         (setq po1 (vlax-curve-getPointAtParam ent1 para1))
         (cond ((= para1 0)
                (setq po4 (vlax-curve-getPointAtParam ent1 paraE)
                      po2 (vlax-curve-getPointAtParam ent1 (+ para1 1))
                      po3 (vlax-curve-getPointAtParam ent1 (+ para1 2))
                (if (equal po1 po4 1e-3)
                    (setq po4 (vlax-curve-getPointAtParam ent1 (- paraE 1)))
               ((< (1+ para1) paraE)
                (setq po4 (vlax-curve-getPointAtParam ent1 (- para1 1))
               ((= (1+ para1) paraE)
                      po3 (vlax-curve-getPointAtParam ent1 paraS)
                (if (equal po2 po3 1e-3)
                    (setq po3 (vlax-curve-getPointAtParam ent1 (+ paraS 1)))
    (setq Alim (limS po1 po2 po3 po4))
    (calcThiep po1 po2 po3 po4)
    (setvar "cecolor" "1")
    (makeLWPoly (list po1 po2 po_in2 po_in1 po1))
    (setvar "cecolor" "256")
    (if (> (abs dt) Alim)
        (cond
            ((> (+ anpha_org beta_org) pi)
             (alert
                 (acet-str-format
                     "area to expand is too large (max = %1), so this case results in an area error"
                     (rtos Alim 2 3)
            ((< (+ anpha_org beta_org) pi)
             (alert
                 (acet-str-format
                     "area to trim is too large (max = %1), so this case results in an area error"
                     (rtos Alim 2 3)
    (setcfg "AppData/trapezoid/area" (rtos dt 2 3))
    (SYSVAR-RESTORE)
    (princ "ok")
(defun LM:GetInsideAngle ( p1 p2 p3 )
    (   (lambda ( a ) (min a (- (+ pi pi) a)))
        (rem (+ pi pi (- (angle p2 p1) (angle p2 p3))) (+ pi pi))
Extend_Trim_Area(DHT).lsp
  • Like 4
4 hours ago, hanhphuc said:
IMO, you can manually trim that 1st picked segment.
or some coding, store the picked point, p1 in extra variable, eg:  xp
(setq xp p1 p  (trans p1 1 0) ;...snippet...;
then at the end of the code, add extra command, entmod, addvertices etc..
 (vl-cmdf "_trim" s "" (list en xp) "")
maybe has some glitches?
so i just let it as simple as possible, another problem is bulged polyline.. :)
p/s: math formula: new area, A' = A x S² ,S=scale factor, A= max area  (triangle)
try to adopt it
Sorry, but I couldn't resist this. Attached takes care of displaying the overall area and a final polyline. I've used VL as it retains all the properties of the original polyline, but would also work entmaking a new polyline, transfering properties then deleting the old.
Bulges could be a problems and also the need to stop stretching once the intersection point is reached/ the segment length is zero.
aaa-v2.lsp
  • Funny 1
  • Thanks 1
 (defun c:DHT  ... <snippet> ...
hi, this looks promising to OP's request
it can be optimized working in UCS :)
another math function
;; sub function for divarea
(defun area:3side ( area x p a b c  / d e f g h i j k l p )
;; hanhphuc 30.03.2020
;; adopted from an old programmable calculator fx-603p
;; area    - minor area to split
;; x       - distance of segment to be extended as base line
;; p       - point of end segment
;; a       - segment angle direction
;; b       - angle at 'p' direction
;; c       - angle direction (firstderiv) close back to segment
;; direction a -> b -> c must be CCW
;; returns 3 sides as : b -> d -> c
  (if
    (<	0.0
	(setq d	(+ pi a)
	      e	(- c b)
	      e	(- (if (>= e 0.0)
		     e
		     (+ e (* 2 pi))
		   pi
	      f	(if (minusp e)
		  (- e)
		  e
	      g	(/ x (sin f))
	      h	(/ (* (-
			(* (* g (sin (- a c)))
			    x
			    (* (sin (- b a)) 0.5)
			((if (minusp e) + -) Area)
		      2.0
		      (sin (- d b))
		   (sin f)
		   (sin (- c d))
     (progn (setq h (sqrt h)
		  i (/ h (sin (- d b)))
		  j (mapcar
		      '(lambda (k l) (list k (abs l)))
		      (list b d c)
		      (list
			(- (* i (sin (- c d))) (* g (sin (- a c))))
			(* i (sin f))
			;(- h (* g (sin (- b a))))
		  k (mapcar '(lambda (x)
			       (setq p (apply 'polar (cons p x)))
			    j
minimal tested
@dlanorh
Quote
yes, known bug which parallel lines don't inters. purge or remove extra vertices
if you insist dynamic $0.02
1.update object properties using vla-get-area , vlax-curve-getarea faster? then can replace math:area
2.perhaps LM:grtext :)
Edited by hanhphuc
rename sub as it's part of routine 'divarea'
  • Thanks 1
sorry for the late response.
thanks a lot @tranthiep for this great lisp, i've tested this lisp it work as intended most of the time but & sometime it gives error, below i'll try to explain the issues i encountered.
1.  It's a minor inconvenience, this 'look at' window appears right at the centre of the screen. Plz remove it. All the command related info is already there on the commandline.
2. It works perfectly on irregular shapes. Ex. Fig A & B. But when i draw a square or rectangle with 'rectangle' command or with polyline command, lisp doesn't work instead it creates two overlapping lines adjacent to the line i picked, like in fig. C (i've moved the overlapping lines sideways so that you could see them). And gives this error
** Error: ActiveX Server returned an error: Invalid index **
Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Converting (command) calls to (command-s) is recommended.
i hope you'll look into these issues and fix them.
once again thanks a million times this lisp will help me a lot.
Edited by xpr0
edit
2. It works perfectly on irregular shapes. Ex. Fig A & B. But when in draw a square or rectangle with 'rectangle' command or with polyline command, lisp doesn't work instead it creates two overlapping lines adjacent to the line i picked, like in fig. C (i've moved the overlapping lines sideways so that you could see them). And gives this error
once again thanks a million times this lisp will me a lot.
Wow, I didn't anticipate the case of the top and bottom edges be parallel. I have fixed this lisp. But, I will check it again so that there are no more cases.
The "messages" window appears right at the centre of the screen.
If you drag the title bar of the "message" window into a any other corner, it will remember the location. The next time, it will appear there, without hindering your view.
I’ll remove, it if you don’t like
  • Thanks 1
Thanks for the swift response.
I think the the message window is redundant because, as i said in my previous post all the necessary information is available on the command line. I request you to remove the message window.
Edited by xpr0
Edit
Sometimes, autoCad are silly!!!. A parallelogram with two adjacent angles: a + b = pi.
If you rotate this parallelogram , (at a 120 degree angle), then a + b ≠ pi ???
Ok, I have fixed them, ex condition: (equal (+ anpha beta) pi 1e-6)
or ex: (if (> (+ anpha_org beta_org) (+ pi 1e-6))
@xpr0, Lisp here:
(defun Ray (po V)
                    (cons 10 po)
                    (cons 11 v)
    (setq n 0
          lstvar_thiep nil
          lstValue_thiep nil
        (setq n (+ 2 n))
    (/ (apply
                   lst
       2
            lstvar_thiep
            lstValue_thiep
    (if (< dt 0)
              beta  beta_org
          ang (angle po1 po2)
    (cond ((not (equal (+ anpha_org beta_org) pi 1e-6))
          ((equal (+ anpha_org beta_org) pi 1e-6)
           (setq h (/ dt dis))
           (cond ((or (and (< bit 0) (< dt 0)) (and (< bit 0) (> dt 0)))
                 ((or (and (> bit 0) (> dt 0)) (and (> bit 0) (< dt 0)))
    (line po4 po1)
    (line po3 po2)
    (cond ((> dt 0)
           (setq
               iplist (vlax-invoke objL1 'IntersectWith objL2 acExtendBoth)
           (vla-delete objL1)
           (vla-delete objL2)
           (if iplist
           (SETQ A (Get-Area (list po1 po2 iplist po1))))
          ((< dt 0)
                                                'IntersectWith
                                                objL2
                                                acExtendOtherEntity
                                                'IntersectWith
                                                objL1
                                                acExtendOtherEntity
                   (if iplist (SETQ A (Get-Area (list po1 po2 po3 iplist po1))))
           (vla-delete objL1)
           (vla-delete objL2)
           (vla-delete objR)
    (if A (abs A))
              po3     po4     ang1    ang2    ang3    dis     m       lstpo1
              lstpo2  lstpo3  lstpo-int1      lstpo-int2      anpha   beta
              pS1     pS2     pS3     pE1     pE2     pE3     h       bit
              obj_top poS     poE     po_in1  po_in2  prom    Alim
        (setq dt nil)
        (sysvar-restore)
    (setq prom
             (acet-str-format
                 (if (numberp dt)
                     (rtos dt 2 3)
                     dt
    (setq olddt dt)
    (if (null dt)
        (setq dt olddt)
        (setq dt (atof dt))
    (while
                          (entsel
        )  (prompt "\nPick a LINE is not right, Please pick again")
    (cond ((eq (DXF 0 ent1) "LINE")
                                    (car (entsel
               (prompt "\nPick a LINE isn't right, Please pick again")
                                    (car (entsel
                  (setq po4 pE3)
                  (setq po4 pS3)
                  (setq po4 pE2)
                  (setq po4 pS2)
           (cond ((= para1 0)
        (cond ((> (+ anpha_org beta_org) (+ pi 1e-6))
             (alert
                 (acet-str-format
                     (rtos Alim 2 3)
            ((< (+ anpha_org beta_org 1e-6) pi)
             (alert
                 (acet-str-format
                     (rtos Alim 2 3)
    (SYSVAR-RESTORE)
    (princ "ok")
Edited by tranthiep
add words
14 hours ago, tranthiep said:
@xpr0, Lisp here:
 @tranthiep thankyou for making corrections in the lisp. now it is working  perfectly fine for all shapes & figures, although there is a tiny glitch, at the end of the command its showing this window with an error message. but lisp is working correctly there is no error in the end result. plz take a look at it.
$0.02
if both sides parallel 90d, manually calculation, Area= Width x Height, where A = W x H,
eg: required A= 20M ,known Height=4, ie: offset, W=A/H = 20/4 = 5.00
either offset or move along axis ortho ...
(defun c:tt ( / )
  (initget 7)
  (and
  (setq a (getreal "\nEnter Area ")) 					; input area
  (setq s (ssget "_:S:E+." '((0 . "LWPOLYLINE,LINE")))) 		; pick line single selection
  (setq en (ssname s 0))
  (setq p (getpoint "\npick side.. ")) 					; pick offset side
  (if (< (setq ep (vlax-curve-getEndParam en)) 2) 	    		; check whether only 2 points
    (progn (vl-cmdf "_OFFSET"				            	; offset the line
	      (/ a (vlax-curve-getDistAtParam en ep))       		; calculate X , A divided Y
		    en p ""
      (princ "\nDone.")
    (princ "\nSingle line!!")
another 2 different scenarios which open & close polyline
  • Like 2
another offset concept 2 options
;; Offset segment for polyline
(defun c:OFFSEG ( / *error* $ aa aa* _angle ang ax en ep force_closed
		 	i ip k l l1 lst n p p1 px s sc sp vs )
  ;;hanhphuc 01.04.2020
  ;*offseg_area* -  global variable
  (setq	force_closed 1 ;; setting closed=1 , open=0
	*error* '((msg) (princ " *cancel*"))
	_angle	'((en x) (angle '(0. 0. 0.) (vlax-curve-getFirstDeriv en x)))
(while
  (setq s (ssget "_:S:E:L+." '((0 . "LWPOLYLINE"))))
  (and
          p1 (osnap (cadr (grread t 13)) "_nea"))
    (not (vla-put-closed (vlax-ename->vla-object en) force_closed ))
    (setq p  (trans p1 1 0)
	  i  (fix (vlax-curve-getparamatpoint en p))
    (>= ep 2)
    (setq ang (mapcar
		'(lambda (x) (_angle en x)
		   (cond
		     ( (< i 1)(list (1- ep) (1+ i))  )
		     ( (>= i (1- ep)) (list (1- i) 0))
		     ( (list (1- i) (1+ i)) )
    (setq *offseg_area*
	    	(ureal  5  ""  "\nEnter area "
                        (cond
			      ( *offseg_area* )
                              ( 0.000 )
    (princ "\nStretching segment.. \n")
    (while
    (and p
	   (mapcar 'set '(k p) (grread t 13))
	   (= 5 k) (vl-consp p)
	   (setq p1 (trans p 1 0))
       (redraw)
      (if
       (vl-some 'not
          (setq l (mapcar
		    '(lambda (a b / p)
                                   (list (setq p (vlax-curve-getPointAtParam en b))
                                         (inters p (polar p a 1.0)
                                                 p1 (polar p1 (_angle en i)
                                                           1.0
                                                 nil
                          ang
                          (list i (1+ i))
                l1 (apply 'append l)
                n (length l1)
                lst (mapcar '(lambda (x) (nth x l1)) '(0 1 3 2))
     (setq p nil)
     (if (= *offseg_area* 0.0)
            (grvecs
              (apply 'append
                     (mapcar
                       '(lambda (x)
                                (cons (car x)
                                      (mapcar
					'(lambda (x)
					   (trans x 0 1)
					(cdr x)
                          (cons
                               (cons 2 (mapcar 'cadr l))
                               (mapcar '(lambda (x) (cons 2 x))
                                       l
     (princ
       (apply 'strcat
               (setq $
                     (list "\rArea = "
                           (rtos
			     (setq AA* (abs (math:area lst)))
			     2
			     2
                            " M\U+00B2 "
       (princ (strcat "\rSelect offset side..              "))
  ); while
    (if
      (and (/= *offseg_area* 0.00)
        (setq ip
	       (apply 'inters
		      (apply 'append (reverse (cons '(nil) l)))
        (setq AA
	       (abs (math:area (list (car l1) ip (caddr l1)))
        (setq Ax ((if (minusp
			(- AA (abs
				(math:area (list (cadr l1) ip (cadddr l1))))
                    AA
                    *offseg_area*
              sc (sqrt (/ (abs Ax) AA))
              lst (cons (car l1)
                        (append
                          (mapcar
			    '(lambda (x)
			       (polar ip
				      (angle ip (x l1))
				      (* (distance ip (x l1)) sc )
                             (list car caddr)
			  (list (caddr l1))
              $   (list "\rArea = "
                       (rtos AA* 2 2)
                       " M\U+00B2 "
	  (equal AA* *offseg_area* 1e-6)
	   ) ;and
      (princ
	(apply
	       'strcat
	    (setq sp
		   (mapcar
		     '(lambda (x)
			(vlax-curve-getPointAtParam en x)
			(list i (1+ i))
	         px
		     (mapcar
			     '(lambda (` p a)
                		(polar p a
                       			(` (/ *offseg_area*
					      (abs (* (sin (- (cadr ang) (_angle en i)))
                                            		(apply 'distance sp)
			(if
			  (LM:Inside-p p en ) ;;; UCS some not working
			  (list - +) (list + -))
			   sp
			   ang
        (setq
	      lst (if (= *offseg_area* 0.0) lst
		    (list (car sp) (car px) (cadr px) (cadr sp) )
              $   (list "\rArea = "
                           (rtos AA* 2 2)
                            " M\U+00B2 "
  ) ;if
 (if
   (or
      (entmakex
      	(vl-list* '(0 . "LWPOLYLINE")
                '(100 . "AcDbEntity")
                '(100 . "AcDbPolyline")
                '(70 . 0)
		(mapcar '(lambda (x) (cons 10 x)) lst)
	(if (not (= *offseg_area* 0))
           (alert
	     (strcat "Exceed chamfer limit!\nMax = " (if ip (rtos AA 2 2) "???") "\ M\U+00B2"
;This function is freeware courtesy of the author's of "Inside AutoLisp" for rel. 10
;published by New Riders Publications.
;This credit must accompany all copies of this function.
;;;October 19, 2004 added function chkkwds (see description at end of file)
;* UREAL User interface real function
;* BIT (0 for none) and KWD key word ("" for none) are same as for INITGET.
;* MSG is the prompt string, to which a default real is added as <DEF> (nil
;* for none), and a : is added.
(defun ureal (bit kwd msg def / inp)
  (if def
    (setq msg (strcat "\n"
		      msg
		      (if (eq (type def) 'REAL)
			(rtos def 2)
			(if (eq (type def) 'INT)
			  (itoa def)
			  def
	  bit (* 2 (fix (/ bit 2)))
    (setq msg (strcat "\n" msg ": "))
  (initget bit kwd)
  (setq inp (getreal msg))
  (if inp
    inp
    def
;;----------------------=={ Inside-p }==----------------------;;
;;  Predicate function to determine whether a point lies      ;;
;;  inside a supplied LWPolyline.                             ;;
;;  Author: Lee Mac - www.lee-mac.com                         ;;
;;  Using some code by gile (as marked below), thanks gile.   ;;
;;  Arguments:                                                ;;
;;  pt  - 3D WCS point to test                                ;;
;;  ent - LWPolyline Entity against which to test point       ;;
;;  Returns:  T if supplied point lies inside supplied LWPoly ;;
(defun LM:Inside-p ( pt ent / _GroupByNum lst nrm obj tmp )
 (defun _GroupByNum ( l n / r)
   (if l
     (cons
       (reverse (repeat n (setq r (cons (car l) r) l (cdr l)) r))
       (_GroupByNum l n)
 (if (= (type ent) 'VLA-OBJECT)
   (setq obj ent ent (vlax-vla-object->ename ent))
   (setq obj (vlax-ename->vla-object ent))
 (setq lst
   (_GroupByNum
     (vlax-invoke
       (setq tmp
           (entmakex
             (list
               (cons 0 "RAY")
               (cons 10 pt)
               (cons 11 (trans '(1. 0. 0.) ent 0))
       'IntersectWith obj acextendnone
     3
 (vla-delete tmp)
 (setq nrm (cdr (assoc 210 (entget ent))))
 ;; gile:
 (and lst (not (vlax-curve-getparamatpoint ent pt))
   (= 1
     (rem
       (length
         (vl-remove-if
           (function
             (lambda ( p / pa p- p+ p0 s1 s2 ) (setq pa (vlax-curve-getparamatpoint ent p))
               (or
                 (and (equal (fix (+ pa (if (minusp pa) -0.5 0.5))) pa 1e-7)
                   (setq p-
                     (cond
                       ( (setq p- (vlax-curve-getPointatParam ent (- pa 1e-7)))
                         (trans p- 0 nrm)
                       ( (trans (vlax-curve-getPointatParam ent (- (vlax-curve-getEndParam ent) 1e-7)) 0 nrm) )
                   (setq p+
                     (cond
                       ( (setq p+ (vlax-curve-getPointatParam ent (+ pa 1e-7)))
                         (trans p+ 0 nrm)
                       ( (trans (vlax-curve-getPointatParam ent (+ (vlax-curve-getStartParam ent) 1e-7)) 0 nrm) )
                   (setq p0 (trans pt 0 nrm))
                   (<= 0 (* (sin (angle p0 p-)) (sin (angle p0 p+)))) ;; LM Mod
                 (and
                   (/= 0. (vla-getBulge obj (fix pa)))
                   (equal '(0. 0.) (cdr (trans (vlax-curve-getFirstDeriv ent pa) 0 nrm)) 1e-9)
           lst
       2
;math formula
;	  | x1  x2  x3  x4  xn.. |
;	1 |   \/  \/  \/  \/     |
;Area=	/ |   /\  /\  /\  /\     |
;	2 | y1  y2  y3  y4  yn.. |
(defun math:area (l) ;hanhphuc
  (* (apply '-
	    (mapcar '(lambda (x y)
		       (apply '+
			      (mapcar '* (mapcar x l)
				(mapcar y (append (cdr l) (list (car l)))))
		    '(car cadr)
		    '(cadr car)
     0.5
1. if user input any value <> 0 the routine emulates just like OFFSET command does, just move the mouse which side to offset saving typing -ve
2. if user input zero, i.e= 0, activate dynamic mode like my previous post which has no restriction, free style  :)
parallel solution, W=A/H
offset solution, scale A'=A x S²
checking bug...
1.not for lines, convert+join+ purge vertices
2.single line N/A
3.not support bulged polyline or 3dpoly
Edited by hanhphuc
  • Thanks 1
I'm afraid, you would put in an area that is too large, large area for expansion (case two adjacent angles: α + β > pi), or trim area (case two adjacent angles: α + β < pi). So, I added a warning. I have fixed this lisp.
  • Like 2
  • Thanks 1
After final corrections, lisp is working perfectly fine without any issues.
I can't thank you enough for the time and effort you put into making this wonderful lisp, this will be of great help to me.
Take care of yourself and your family and stay safe.
these are some bugs of last update .
Interested? test drawing attached.
offseg bugs.dwg
hint: inside-p ray vs ucs
Edited by hanhphuc
drawing
  • Thanks 1
@xpr0, No problem, may your family and all the world over the Wuhan coronavirus epidemic
Take care!
Thank @hanhphuc,  for found the shortcomings of lisp
1. Use funstion trans for transfer coordinate system point
2. Case: (bugled edge): I can't fix lisp.
3. Case: node ≡ node or 3 points on a line (v12//v23): I will fix lisp
4. Case: 3 points on a line (v12//v23) and polyline not closed: handcuffs.com, I can't fix lisp, But I'll add 1 message: "Lisp can't be done"
  • 3 months later...
Just have to say that this lisp really helped me this week to adjust a layout of a parking lot and I didn't know where to start.
Thank you guys for your efforts and sharing with us.
Very greatful,
~Greg
