jim78b
change lineweight lisp correction please
jim78b
i have this lisp that in a block change all lineweight to byblock except layer 0.
but i tested if i make a block with only layer 0 , the lisp don't change layer 0 lineweight to byblock
is possible to adjust please?
(defun LM:unique  (l) (if l (cons (car l) (LM:Unique (vl-remove (car l) (cdr l))))))
(defun BB:setByBlock  (nam / blc blk)
  (setq blc (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
  (setq blk (vla-item blc nam))
  (vlax-for x  blk (if (= "0" (vlax-get-property x 'layer)) (vlax-put-property x 'lineweight acLnWtByBlock)))
(vl-load-com)
(defun c:bf ( / c_doc sel cnt obj col)
  (setq c_doc (vla-get-activedocument (vlax-get-acad-object)))
  (princ "\nSelect blocks : ")
  (setq sel (ssget '((0 . "INSERT"))))
  (cond (sel
          (repeat (setq cnt (sslength sel))
            (setq obj (vlax-ename->vla-object (ssname sel (setq cnt (1- cnt)))))
            (cond ( (= :vlax-true (vlax-get-property obj 'isdynamicblock))
                    (setq col (cons (vla-get-effectivename obj) col)
                          col (cons (vla-get-name obj) col)
                  (t  (setq col (cons (vla-get-effectiveName obx) col)))
            );end_cond
          );end_repeat
          (setq col (LM:unique col))
          (foreach x col (BB:setByBlock x))
        ( (princ "\nNothing Selected"))
  );end_cond
  (vla-regen c_doc acActiveViewport)
);end_defun
Share this post
Link to post
dlanorh
Try this, there was a variable mis-spelling in one branch of a condition statement
(vl-load-com)
  (cond (sel
                  (t  (setq col (cons (vla-get-effectiveName obj) col)))
            );end_cond
          );end_repeat
  );end_cond
);end_defun
Share this post
Link to post
jim78b
thanks so much you are the best! best regards have a nice day dlanorh
Share this post
Link to post
jim78b
sorry i try with a nested block all on layer 0 but don't change the 2nd block lineweight to byblock try to see my dwg
new block.dwg
Share this post
Link to post
dlanorh
It wasn't originally designed for nested blocks. I'll have a look later today.
Share this post
Link to post
jim78b
do me this favor thanks a lot
Share this post
Link to post
dlanorh
OK, try this. It works in my test.
  (vlax-for x  blk
    (if (= "AcDbBlockReference" (vlax-get-property x 'objectname)) (BB:setByBlock (vlax-get-property x 'effectivename)))
(vl-load-com)
  (cond (sel
            );end_cond
          );end_repeat
  );end_cond
);end_defun
  • Like 2
Share this post
Link to post
jim78b
thanks a lot you are the best it is work, thanks for your patience have a nice evening
Share this post
Link to post
