pmxcad
Insert block on block
pmxcad
Hello,
I found a lisp on the internet that I would like to use.
What I want to achieve is that the lisp puts the block "Marker4.dwg on the blocks "U0003" insertionpoint, with the attribute tag "SYMBOOL_TOEVOEGING" and the value "EIDS" "ETV" " like test.dwg left side.
;Alan Henderson @ A'cad Solutions, Aug 18, 2004#3
(defun GetBlock (BlockName AttribName AttribValue /)
(setq cannsca (/ 1 (getvar "cannoscalevalue")))							;Get cannoscale
(if (setq ss (ssget "X" (list (cons 0 "INSERT") (cons 2 BlockName))))
(setq SSN (ssadd))
(setq KK 0 KS (sslength SS))
(setq BlocksFound 0)
(while (< KK KS)
(setq EG (entget (ssname SS KK)))
(setq EN (entget (entnext (cdr (assoc -1 EG)))))
(while (/= (cdr (assoc 0 EN)) "SEQEND")
(if (and (= (cdr (assoc 2 EN)) AttribName) (= (cdr (assoc 1 EN))
AttribValue))
(ssadd (cdr (assoc -1 EG)) SSN)
(setq BlocksFound (1+ BlocksFound))
(setq blkins (cdr (assoc 10 (entget (ssname ss 0)))))
(command "-insert" (strcat (getvar "dwgprefix") "Marker4.dwg") blkins cannsca "" "")		;Insert block "marker"
(setq EN (entget (entnext (cdr (assoc -1 EN)))))
(setq KK (1+ KK))
(if SSN (princ (strcat "\n" (itoa BlocksFound) " Block(s) = " BlockName "
with Attribute = " AttribName " & Value = " AttribValue " was Found!")))
(defun c:test ()
(GetBlock "U00003" "SYMBOOL_TOEVOEGING" "EIDS")
(GetBlock "U00003" "SYMBOOL_TOEVOEGING" "ETV")
);defun
I have already added some lines. (between the ;---------------------------------------------- ------------- lines)
As now the code insert only 1 block.
Who could help me, so the code inserts the "Marker4" block on each "U00003" block with value "EIDS" and "ETV".
thanks in advance
Marker4.dwg test.dwg
Share this post
Link to post
