amir0914
Text name filter
amir0914
Hello every one,
I wrote this code to ssget all text :
(setq ss1 (ssget '((0 . "text,mtext"))))
Is it possible to ssget all texts except a specific text string in above code?  for example get all text except "Screw"
Edited by amir0914
Share this post
Link to post
Tharwat
What do you mean by 'text name' ? is it text style or text string ?
Share this post
Link to post
amir0914
I mean is text string.
Share this post
Link to post
Tharwat
		   (-4 . "<NOT")
		   (1 . "Screw")
		   (-4 . "NOT>")
  • Like 2
Share this post
Link to post
amir0914
		   (-4 . "<NOT")
		   (1 . "Screw")
		   (-4 . "NOT>")
Thank you Tharwat, is it possible to do this with multiple text string name or list of string name? for example:
list = ("Screw","Hole","pin")
I mean ssget all texts except items of list
Share this post
Link to post
Lee Mac
Hint: (-4 . "<OR") ... (-4 . "OR>")
  • Like 2
Share this post
Link to post
Tharwat
Example:
(setq lst '("Screw" "Hole" "pin"))
(setq ss1 (ssget
	    (append '((0 . "text,mtext") (-4 . "<NOT") (-4 . "<OR"))
		    (mapcar '(lambda (u) (cons 1 u)) lst)
		    '((-4 . "OR>") (-4 . "NOT>"))
Share this post
Link to post
amir0914
Many thanks for your consideration, I have another request, is it possible to select items of lst by ssget ?
Share this post
Link to post
Tharwat
You're welcome anytime.
(setq ss1
       (ssget
	 (append
	   (list (cons 1 (apply 'strcat (mapcar '(lambda (u) (strcat u ",")) lst))))
Share this post
Link to post
ronjonp
8 hours ago, Tharwat said:
Example:
(setq ss1 (ssget
Quick test and this works too  (case sensitive of course).
(setq ss1 (ssget (append '((0 . "text,mtext"))
			 (mapcar '(lambda (u) (cons 1 (strcat "~" u))) '("Screw" "Hole" "pin"))
Share this post
Link to post
