I copy tour code and ask me to select objects ...
  • Replies 22
  • jim78b
    13
  • BIGAL
    5
  • hanhphuc
    3
  • maratovich
    2
Posted Images
BIGAL wants you to select any object in order to know whether nanocad supports activeX
try this error or echo ?
(progn (vl-load-com) (vlax-dump-object (vlax-get-acad-object) t))
or straight to the point check SUBR with prefix "VLA-*"
( (lambda ( / l)(foreach x ( atoms-family 1 ) ( if ( wcmatch ( strcase x ) "VLA-*" ) ( setq l (cons x l)) ) ) l) )
 others VLISP*, VLR*, VLA* ,VL* ,V*
the 1st work the 2nd give me:
"VLA-GET-ENDPOINT" "VLA-PUT-CENTER" "VLA-GET-CENTER" "VLA-GET-STARTPOINT" "VLA-GET-LENGTH" "VLA-PUT-CLOSED" "VLA-GET-CLOSED" "VLA-EXPLODE" "VLA-APPENDVERTEX" "VLA-PUT-TYPE" "VLA-GET-TYPE" "VLA-GET-NVERTEXCOUNT" "VLA-GET-MVERTEXCOUNT" "VLA-PUT-NDENSITY" "VLA-GET-NDENSITY" "VLA-PUT-MDENSITY" "VLA-GET-MDENSITY" "VLA-PUT-NCLOSE" "VLA-GET-NCLOSE" "VLA-PUT-MCLOSE" "VLA-GET-MCLOSE" "VLA-PUT-COORDINATE" "VLA-GET-COORDINATE" "VLA-SETINVISIBLEEDGE" "VLA-GETINVISIBLEEDGE" "VLA-PUT-VISIBILITYEDGE4" "VLA-GET-VISIBILITYEDGE4" "VLA-PUT-VISIBILITYEDGE3" "VLA-GET-VISIBILITYEDGE3" "VLA-PUT-VISIBILITYEDGE2" "VLA-GET-VISIBILITYEDGE2" "VLA-PUT-VISIBILITYEDGE1" "VLA-GET-VISIBILITYEDGE1" "VLA-PUT-COORDINATES" "VLA-GET-COORDINATES" "VLA-GET-URLNAMEDLOCATION" "VLA-PUT-URLNAMEDLOCATION" "VLA-GET-URLDESCRIPTION" "VLA-PUT-URLDESCRIPTION" "VLA-GET-URL" "VLA-PUT-URL" "VLA-ADD" "VLA-SETCOLORBOOKCOLOR" "VLA-PUT-COLORINDEX" "VLA-GET-COLORINDEX" "VLA-GET-COLORMETHOD" "VLA-PUT-COLORMETHOD" "VLA-SETRGB" "VLA-GET-GREEN" "VLA-GET-BLUE" "VLA-GET-RED" "VLA-SETNAMES" "VLA-GET-BOOKNAME" "VLA-GET-COLORNAME" "VLA-GET-ENTITYCOLOR" "VLA-PUT-ENTITYCOLOR" "VLA-PUT-MATERIAL" "VLA-GET-MATERIAL" "VLA-GET-HYPERLINKS" "VLA-PUT-LINEWEIGHT" "VLA-GET-LINEWEIGHT" "VLA-PUT-PLOTSTYLENAME" "VLA-GET-PLOTSTYLENAME" "VLA-INTERSECTWITH" "VLA-GETBOUNDINGBOX" "VLA-UPDATE" "VLA-TRANSFORMBY" "VLA-SCALEENTITY" "VLA-MIRROR3D" "VLA-MIRROR" "VLA-ROTATE3D" "VLA-ROTATE" "VLA-MOVE" "VLA-COPY" "VLA-HIGHLIGHT" "VLA-ARRAYRECTANGULAR" "VLA-ARRAYPOLAR" "VLA-PUT-VISIBLE" "VLA-GET-VISIBLE" "VLA-PUT-LINETYPESCALE" "VLA-GET-LINETYPESCALE" "VLA-PUT-LINETYPE" "VLA-GET-LINETYPE" "VLA-PUT-LAYER" "VLA-GET-LAYER" "VLA-PUT-TRUECOLOR" "VLA-GET-TRUECOLOR" "VLA-ADDEMBEDDEDRASTER" "VLA-ADDMLEADER" "VLA-ADDSECTION" "VLA-ADDDIMRADIALLARGE" "VLA-ADDDIMARC" "VLA-GET-ISDYNAMICBLOCK" "VLA-PUT-BLOCKSCALING" "VLA-GET-BLOCKSCALING" "VLA-PUT-EXPLODABLE" "VLA-GET-EXPLODABLE" "VLA-PUT-UNITS" "VLA-GET-UNITS" "VLA-PUT-COMMENTS" "VLA-GET-COMMENTS" "VLA-PUT-PATH" "VLA-GET-PATH" "VLA-ADDTABLE" "VLA-DETACH" "VLA-BIND" "VLA-RELOAD" "VLA-UNLOAD" "VLA-ATTACHEXTERNALREFERENCE" "VLA-GET-XREFDATABASE" "VLA-ADDDIM3POINTANGULAR" "VLA-ADDMLINE" "VLA-ADDPOLYFACEMESH" "VLA-ADDMINSERTBLOCK" "VLA-GET-ISXREF" "VLA-GET-LAYOUT" "VLA-GET-ISLAYOUT" "VLA-ADDLINE" "VLA-ADDRASTER" "VLA-ADDHATCH" "VLA-INSERTBLOCK" "VLA-ADDXLINE" "VLA-ADDWEDGE" "VLA-ADDTRACE" "VLA-ADDTORUS" "VLA-ADDTOLERANCE" "VLA-ADDTEXT" "VLA-ADDSPLINE" "VLA-ADDSPHERE" "VLA-ADDSOLID" "VLA-ADDSHAPE" "VLA-ADDREVOLVEDSOLID" "VLA-ADDREGION" "VLA-ADDRAY" "VLA-ADDPOLYLINE" "VLA-ADDLIGHTWEIGHTPOLYLINE" "VLA-ADDPOINT" "VLA-ADDMTEXT" "VLA-ADDLEADER" "VLA-ADDEXTRUDEDSOLIDALONGPATH" "VLA-ADDEXTRUDEDSOLID" "VLA-ADDELLIPTICALCYLINDER" "VLA-ADDELLIPTICALCONE" "VLA-ADDELLIPSE" "VLA-ADDDIMRADIAL" "VLA-ADDDIMORDINATE" "VLA-ADDDIMROTATED" "VLA-ADDDIMDIAMETRIC" "VLA-ADDDIMANGULAR" "VLA-ADDDIMALIGNED" "VLA-ADDCYLINDER" "VLA-ADDCONE" "VLA-ADDCIRCLE" "VLA-ADDBOX" "VLA-ADDATTRIBUTE" "VLA-ADDARC" "VLA-ADD3DPOLY" "VLA-ADD3DMESH" "VLA-ADD3DFACE" "VLA-ADDCUSTOMOBJECT" "VLA-PUT-ORIGIN" "VLA-GET-ORIGIN" "VLA-PUT-NAME" "VLA-GET-NAME" "VLA-GET-COUNT" "VLA-ITEM" "VLA-GET-MATERIALS" "VLA-GET-SECTIONMANAGER" "VLA-GET-SUMMARYINFO" "VLA-GET-FILEDEPENDENCIES" "VLA-GET-PREFERENCES" "VLA-GET-PLOTCONFIGURATIONS" "VLA-GET-LAYOUTS" "VLA-OBJECTIDTOOBJECT" "VLA-HANDLETOOBJECT" "VLA-PUT-LIMITS" "VLA-GET-LIMITS" "VLA-PUT-ELEVATIONPAPERSPACE" "VLA-GET-ELEVATIONPAPERSPACE" "VLA-PUT-ELEVATIONMODELSPACE" "VLA-GET-ELEVATIONMODELSPACE" "VLA-GET-VIEWPORTS" "VLA-GET-VIEWS" "VLA-GET-USERCOORDINATESYSTEMS" "VLA-GET-TEXTSTYLES" "VLA-GET-REGISTEREDAPPLICATIONS" "VLA-GET-DICTIONARIES" "VLA-GET-LINETYPES" "VLA-GET-LAYERS" "VLA-GET-DIMSTYLES" "VLA-GET-GROUPS" "VLA-COPYOBJECTS" "VLA-GET-BLOCKS" "VLA-GET-PAPERSPACE" "VLA-GET-MODELSPACE" "VLA-GET-DOCUMENT" "VLA-GET-OWNERID" "VLA-GETEXTENSIONDICTIONARY" "VLA-GET-HASEXTENSIONDICTIONARY" "VLA-GET-APPLICATION" "VLA-GET-OBJECTID" "VLA-DELETE" "VLA-SETXDATA" "VLA-GETXDATA" "VLA-GET-OBJECTNAME" "VLA-GET-HANDLE")
*cancel*
*cancel*
*cancel*
Command: lsp
lsp - lsp
Enter an option or [cOmmands/Functions/Variables/Load/Execute/Console]: c
_> Welcome to LISP console!
_> Enter LISP's commands. To exit use Esc or command (quit) or (exit).
_>: ( (lambda ( / l)(foreach x ( atoms-family 1 ) ( if ( wcmatch ( strcase x ) "VLA-*" ) ( setq l (cons x l)) ) ) l) )
("VLA-RUN" "VLA-GET-MENUGROUP" "VLA-GET-MENUTEXT" "VLA-GET-CAPS" "VLA-GET-TOOLTIP" "VLA-GET-STATUSSTRING" "VLA-GET-LAUNCHWEIGHT" "VLA-GET-WEIGHT" "VLA-GET-DISPNAME" "VLA-GET-INTERNALNAME" "VLA-PUT-ID" "VLA-GET-ID" "VLA-ENDOPEN" "VLA-BEGINOPEN" "VLA-BEGINFILEDROP" "VLA-BEGINQUIT" "VLA-ENDMODAL" "VLA-BEGINMODAL" "VLA-APPDEACTIVATE" "VLA-APPACTIVATE" "VLA-NEWDRAWING" "VLA-SYSVARCHANGED" "VLA-BEGINDOCCLOSE" "VLA-BEGINCLOSE" "VLA-WINDOWCHANGED" "VLA-LAYOUTSWITCHED" "VLA-WINDOWMOVEDORRESIZED" "VLA-ENDPLOT" "VLA-BEGINPLOT" "VLA-OBJECTMODIFIED" "VLA-OBJECTERASED" "VLA-OBJECTADDED" "VLA-BEGINDOUBLECLICK" "VLA-ENDSHORTCUTMENU" "VLA-BEGINSHORTCUTMENUOSNAP" "VLA-BEGINSHORTCUTMENUGRIP" "VLA-BEGINSHORTCUTMENUCOMMAND" "VLA-BEGINSHORTCUTMENUEDIT" "VLA-BEGINSHORTCUTMENUDEFAULT" "VLA-BEGINRIGHTCLICK" "VLA-DEACTIVATE" "VLA-SELECTIONCHANGED" "VLA-ENDCOMMAND" "VLA-BEGINCOMMAND" "VLA-ENDSAVE" "VLA-BEGINSAVE" "VLA-PUT-CUSTOMPLOTSETTINGS" "VLA-GET-CUSTOMPLOTSETTINGS" "VLA-STARTBATCHMODE" "VLA-SETLAYOUTSTOPLOT" "VLA-PLOTTODEVICE" "VLA-PLOTTOFILE" "VLA-DISPLAYPLOTPREVIEW" "VLA-PUT-BATCHPLOTPROGRESS" "VLA-GET-BATCHPLOTPROGRESS" "VLA-PUT-NUMBEROFCOPIES" "VLA-GET-NUMBEROFCOPIES" "VLA-PUT-QUIETERRORMODE" "VLA-GET-QUIETERRORMODE" "VLA-GET-ISQUIESCENT" "VLA-GET-PLOTAREAS" "VLA-PUT-PAPEROUTMARGINS" "VLA-GET-PAPEROUTMARGINS" "VLA-PUT-INFLATEWIDTH" "VLA-GET-INFLATEWIDTH" "VLA-PUT-MULTIPAGE" "VLA-GET-MULTIPAGE" "VLA-PUT-PLOTTOFILE" "VLA-GET-PLOTTOFILE" "VLA-PUT-FILEMASK" "VLA-GET-FILEMASK" "VLA-PUT-FILEFOLDER" "VLA-GET-FILEFOLDER" "VLA-PUT-USEDWGPATH" "VLA-GET-USEDWGPATH" "VLA-PUT-RUNPDFAPP" "VLA-GET-RUNPDFAPP" "VLA-PUT-IFFILEEXIST" "VLA-GET-IFFILEEXIST" "VLA-PUT-USEPREFINEDNAMES" "VLA-GET-USEPREFINEDNAMES" "VLA-PUT-PRINTERDPI" "VLA-GET-PRINTERDPI" "VLA-PUT-COLORMODE" "VLA-GET-COLORMODE" "VLA-PUT-PARAMS" "VLA-GET-PARAMS" "VLA-PUT-PTMAX" "VLA-GET-PTMAX" "VLA-PUT-PTMIN" "VLA-GET-PTMIN" "VLA-PUT-OFFSET" "VLA-GET-OFFSET" "VLA-PUT-COMMANDDISPLAYNAME" "VLA-GET-COMMANDDISPLAYNAME" "VLA-ATTACHTOOLBARTOFLYOUT" "VLA-SETBITMAPS" "VLA-GETBITMAPS" "VLA-GET-FLYOUT" "VLA-FLOAT" "VLA-DOCK" "VLA-ADDTOOLBARBUTTON" "VLA-PUT-FLOATINGROWS" "VLA-GET-FLOATINGROWS" "VLA-PUT-TOP" "VLA-GET-TOP" "VLA-PUT-LEFT" "VLA-GET-LEFT" "VLA-GET-DOCKSTATUS" "VLA-PUT-LARGEBUTTONS" "VLA-GET-LARGEBUTTONS" "VLA-PUT-ENDSUBMENULEVEL" "VLA-GET-ENDSUBMENULEVEL" "VLA-PUT-HELPSTRING" "VLA-GET-HELPSTRING" "VLA-PUT-MACRO" "VLA-GET-MACRO" "VLA-GET-SUBMENU" "VLA-PUT-CHECK" "VLA-GET-CHECK" "VLA-PUT-ENABLE" "VLA-GET-ENABLE" "VLA-PUT-LABEL" "VLA-GET-LABEL" "VLA-REMOVEFROMMENUBAR" "VLA-INSERTINMENUBAR" "VLA-ADDSEPARATOR" "VLA-ADDSUBMENU" "VLA-ADDMENUITEM" "VLA-GET-ONMENUBAR" "VLA-GET-SHORTCUTMENU" "VLA-GET-NAMENOMNEMONIC" "VLA-REMOVEMENUFROMMENUBAR" "VLA-INSERTMENUINMENUBAR" "VLA-GET-TOOLBARS" "VLA-GET-MENUS" "VLA-GET-MENUFILENAME" "VLA-GET-PARENT" "VLA-GETALLPROFILENAMES" "VLA-COPYPROFILE" "VLA-RENAMEPROFILE" "VLA-RESETPROFILE" "VLA-DELETEPROFILE" "VLA-EXPORTPROFILE" "VLA-IMPORTPROFILE" "VLA-GET-ACTIVEPROFILE" "VLA-PUT-ACTIVEPROFILE" "VLA-GET-PICKGROUP" "VLA-PUT-PICKGROUP" "VLA-GET-GRIPSIZE" "VLA-PUT-GRIPSIZE" "VLA-GET-GRIPCOLORUNSELECTED" "VLA-PUT-GRIPCOLORUNSELECTED" "VLA-GET-GRIPCOLORSELECTED" "VLA-PUT-GRIPCOLORSELECTED" "VLA-GET-DISPLAYGRIPSWITHINBLOCKS" "VLA-PUT-DISPLAYGRIPSWITHINBLOCKS" "VLA-GET-DISPLAYGRIPS" "VLA-PUT-DISPLAYGRIPS" "VLA-GET-PICKBOXSIZE" "VLA-PUT-PICKBOXSIZE" "VLA-GET-PICKAUTO" "VLA-PUT-PICKAUTO" "VLA-GET-PICKDRAG" "VLA-PUT-PICKDRAG" "VLA-GET-PICKADD" "VLA-PUT-PICKADD" "VLA-GET-PICKFIRST" "VLA-PUT-PICKFIRST" "VLA-GET-ALIGNMENTPOINTACQUISITION" "VLA-PUT-ALIGNMENTPOINTACQUISITION" "VLA-GET-AUTOTRACKTOOLTIP" "VLA-PUT-AUTOTRACKTOOLTIP" "VLA-GET-FULLSCREENTRACKINGVECTOR" "VLA-PUT-FULLSCREENTRACKINGVECTOR" "VLA-GET-POLARTRACKINGVECTOR" "VLA-PUT-POLARTRACKINGVECTOR" "VLA-GET-AUTOSNAPMARKERSIZE" "VLA-PUT-AUTOSNAPMARKERSIZE" "VLA-GET-AUTOSNAPMARKERCOLOR" "VLA-PUT-AUTOSNAPMARKERCOLOR" "VLA-GET-AUTOSNAPAPERTURESIZE" "VLA-PUT-AUTOSNAPAPERTURESIZE" "VLA-GET-AUTOSNAPAPERTURE" "VLA-PUT-AUTOSNAPAPERTURE" "VLA-GET-AUTOSNAPTOOLTIP" "VLA-PUT-AUTOSNAPTOOLTIP" "VLA-GET-AUTOSNAPMAGNET" "VLA-PUT-AUTOSNAPMAGNET" "VLA-GET-AUTOSNAPMARKER" "VLA-PUT-AUTOSNAPMARKER" "VLA-GET-SCMTIMEVALUE" "VLA-PUT-SCMTIMEVALUE" "VLA-GET-SCMTIMEMODE" "VLA-PUT-SCMTIMEMODE" "VLA-GET-SCMCOMMANDMODE" "VLA-PUT-SCMCOMMANDMODE" "VLA-GET-SCMEDITMODE" "VLA-PUT-SCMEDITMODE" "VLA-GET-SCMDEFAULTMODE" "VLA-PUT-SCMDEFAULTMODE" "VLA-GET-SHORTCUTMENUDISPLAY" "VLA-PUT-SHORTCUTMENUDISPLAY" "VLA-GET-ADCINSERTUNITSDEFAULTTARGET" "VLA-PUT-ADCINSERTUNITSDEFAULTTARGET" "VLA-GET-ADCINSERTUNITSDEFAULTSOURCE" "VLA-PUT-ADCINSERTUNITSDEFAULTSOURCE" "VLA-GET-HYPERLINKDISPLAYTOOLTIP" "VLA-PUT-HYPERLINKDISPLAYTOOLTIP" "VLA-GET-HYPERLINKDISPLAYCURSOR" "VLA-PUT-HYPERLINKDISPLAYCURSOR" "VLA-GET-KEYBOARDPRIORITY" "VLA-PUT-KEYBOARDPRIORITY" "VLA-GET-KEYBOARDACCELERATOR" "VLA-PUT-KEYBOARDACCELERATOR" "VLA-GET-LOADACADLSPINALLDOCUMENTS" "VLA-PUT-LOADACADLSPINALLDOCUMENTS" "VLA-GET-SHOWWARNINGMESSAGES" "VLA-PUT-SHOWWARNINGMESSAGES" "VLA-GET-BEEPONERROR" "VLA-PUT-BEEPONERROR" "VLA-GET-ENABLESTARTUPDIALOG" "VLA-PUT-ENABLESTARTUPDIALOG" "VLA-GET-TABLESREADONLY" "VLA-PUT-TABLESREADONLY" "VLA-GET-STORESQLINDEX" "VLA-PUT-STORESQLINDEX" "VLA-GET-DISPLAYOLESCALE" "VLA-PUT-DISPLAYOLESCALE" "VLA-GET-SINGLEDOCUMENTMODE" "VLA-PUT-SINGLEDOCUMENTMODE" "VLA-GET-DEFAULTPLOTSTYLEFORLAYER" "VLA-PUT-DEFAULTPLOTSTYLEFORLAYER" "VLA-GET-DEFAULTPLOTSTYLEFOROBJECTS" "VLA-PUT-DEFAULTPLOTSTYLEFOROBJECTS" "VLA-GET-DEFAULTPLOTSTYLETABLE" "VLA-PUT-DEFAULTPLOTSTYLETABLE" "VLA-GET-PLOTPOLICY" "VLA-PUT-PLOTPOLICY" "VLA-GET-USELASTPLOTSETTINGS" "VLA-PUT-USELASTPLOTSETTINGS" "VLA-GET-OLEQUALITY" "VLA-PUT-OLEQUALITY" "VLA-GET-PLOTLEGACY" "VLA-PUT-PLOTLEGACY" "VLA-GET-PRINTERPAPERSIZEALERT" "VLA-PUT-PRINTERPAPERSIZEALERT" "VLA-GET-PRINTERSPOOLALERT" "VLA-PUT-PRINTERSPOOLALERT" "VLA-GET-DEFAULTOUTPUTDEVICE" "VLA-PUT-DEFAULTOUTPUTDEVICE" "VLA-GET-MRUNUMBER" "VLA-GET-SAVEASTYPE" "VLA-PUT-SAVEASTYPE" "VLA-GET-AUTOAUDIT" "VLA-PUT-AUTOAUDIT" "VLA-GET-SHOWPROXYDIALOGBOX" "VLA-PUT-SHOWPROXYDIALOGBOX" "VLA-GET-PROXYIMAGE" "VLA-PUT-PROXYIMAGE" "VLA-GET-DEMANDLOADARXAPP" "VLA-PUT-DEMANDLOADARXAPP" "VLA-GET-XREFDEMANDLOAD" "VLA-PUT-XREFDEMANDLOAD" "VLA-GET-TEMPFILEEXTENSION" "VLA-PUT-TEMPFILEEXTENSION" "VLA-GET-LOGFILEON" "VLA-PUT-LOGFILEON" "VLA-GET-FULLCRCVALIDATION" "VLA-PUT-FULLCRCVALIDATION" "VLA-GET-CREATEBACKUP" "VLA-PUT-CREATEBACKUP" "VLA-GET-AUTOSAVEINTERVAL" "VLA-PUT-AUTOSAVEINTERVAL" "VLA-GET-INCREMENTALSAVEPERCENT" "VLA-PUT-INCREMENTALSAVEPERCENT" "VLA-GET-SAVEPREVIEWTHUMBNAIL" "VLA-PUT-SAVEPREVIEWTHUMBNAIL" "VLA-GET-XREFFADEINTENSITY" "VLA-PUT-XREFFADEINTENSITY" "VLA-GET-TRUECOLORIMAGES" "VLA-PUT-TRUECOLORIMAGES" "VLA-GET-IMAGEFRAMEHIGHLIGHT" "VLA-PUT-IMAGEFRAMEHIGHLIGHT" "VLA-GET-DISPLAYLAYOUTTABS" "VLA-PUT-DISPLAYLAYOUTTABS" "VLA-GET-MAXWINDOW" "VLA-PUT-MAXWINDOW" "VLA-GET-HISTORYLINES" "VLA-PUT-HISTORYLINES" "VLA-GET-TEXTFONTSIZE" "VLA-PUT-TEXTFONTSIZE" "VLA-GET-TEXTFONTSTYLE" "VLA-PUT-TEXTFONTSTYLE" "VLA-GET-TEXTFONT" "VLA-PUT-TEXTFONT" "VLA-GET-AUTOTRACKINGVECCOLOR" "VLA-PUT-AUTOTRACKINGVECCOLOR" "VLA-GET-LAYOUTCROSSHAIRCOLOR" "VLA-PUT-LAYOUTCROSSHAIRCOLOR" "VLA-GET-TEXTWINTEXTCOLOR" "VLA-PUT-TEXTWINTEXTCOLOR" "VLA-GET-TEXTWINBACKGRNDCOLOR" "VLA-PUT-TEXTWINBACKGRNDCOLOR" "VLA-GET-GRAPHICSWINLAYOUTBACKGRNDCOLOR" "VLA-PUT-GRAPHICSWINLAYOUTBACKGRNDCOLOR" "VLA-GET-MODELCROSSHAIRCOLOR" "VLA-PUT-MODELCROSSHAIRCOLOR" "VLA-GET-GRAPHICSWINMODELBACKGRNDCOLOR" "VLA-PUT-GRAPHICSWINMODELBACKGRNDCOLOR" "VLA-GET-SHOWRASTERIMAGE" "VLA-PUT-SHOWRASTERIMAGE" "VLA-GET-DOCKEDVISIBLELINES" "VLA-PUT-DOCKEDVISIBLELINES" "VLA-GET-CURSORSIZE" "VLA-PUT-CURSORSIZE" "VLA-GET-DISPLAYSCREENMENU" "VLA-PUT-DISPLAYSCREENMENU" "VLA-GET-DISPLAYSCROLLBARS" "VLA-PUT-DISPLAYSCROLLBARS" "VLA-GET-LAYOUTCREATEVIEWPORT" "VLA-PUT-LAYOUTCREATEVIEWPORT" "VLA-GET-LAYOUTSHOWPLOTSETUP" "VLA-PUT-LAYOUTSHOWPLOTSETUP" "VLA-GET-LAYOUTDISPLAYPAPERSHADOW" "VLA-PUT-LAYOUTDISPLAYPAPERSHADOW" "VLA-GET-LAYOUTDISPLAYPAPER" "VLA-PUT-LAYOUTDISPLAYPAPER" "VLA-GET-LAYOUTDISPLAYMARGINS" "VLA-PUT-LAYOUTDISPLAYMARGINS" "VLA-GET-TOOLPALETTEPATH" "VLA-PUT-TOOLPALETTEPATH" "VLA-GET-COLORBOOKPATH" "VLA-PUT-COLORBOOKPATH" "VLA-GET-WORKSPACEPATH" "VLA-PUT-WORKSPACEPATH" "VLA-GET-PRINTERSTYLESHEETPATH" "VLA-PUT-PRINTERSTYLESHEETPATH" "VLA-GET-PRINTERDESCPATH" "VLA-PUT-PRINTERDESCPATH" "VLA-GET-PRINTERCONFIGPATH" "VLA-PUT-PRINTERCONFIGPATH" "VLA-GETPROJECTFILEPATH" "VLA-SETPROJECTFILEPATH" "VLA-GET-ALTTABLETMENUFILE" "VLA-PUT-ALTTABLETMENUFILE" "VLA-GET-TEXTUREMAPPATH" "VLA-PUT-TEXTUREMAPPATH" "VLA-GET-TEMPXREFPATH" "VLA-PUT-TEMPXREFPATH" "VLA-GET-TEMPFILEPATH" "VLA-PUT-TEMPFILEPATH" "VLA-GET-LOGFILEPATH" "VLA-PUT-LOGFILEPATH" "VLA-GET-TEMPLATEDWGPATH" "VLA-PUT-TEMPLATEDWGPATH" "VLA-GET-AUTOSAVEPATH" "VLA-PUT-AUTOSAVEPATH" "VLA-GET-PRINTSPOOLERPATH" "VLA-PUT-PRINTSPOOLERPATH" "VLA-GET-POSTSCRIPTPROLOGFILE" "VLA-PUT-POSTSCRIPTPROLOGFILE" "VLA-GET-PRINTSPOOLEXECUTABLE" "VLA-PUT-PRINTSPOOLEXECUTABLE" "VLA-GET-PRINTFILE" "VLA-PUT-PRINTFILE" "VLA-GET-FONTFILEMAP" "VLA-PUT-FONTFILEMAP" "VLA-GET-ALTFONTFILE" "VLA-PUT-ALTFONTFILE" "VLA-GET-CUSTOMDICTIONARY" "VLA-PUT-CUSTOMDICTIONARY" "VLA-GET-MAINDICTIONARY" "VLA-PUT-MAINDICTIONARY" "VLA-GET-TEXTEDITOR" "VLA-PUT-TEXTEDITOR" "VLA-GET-CONFIGFILE" "VLA-GET-DEFAULTINTERNETURL" "VLA-PUT-DEFAULTINTERNETURL" "VLA-GET-HELPFILEPATH" "VLA-PUT-HELPFILEPATH" "VLA-GET-MENUFILE" "VLA-PUT-MENUFILE" "VLA-GET-DRIVERSPATH" "VLA-PUT-DRIVERSPATH" "VLA-GET-SUPPORTPATH" "VLA-PUT-SUPPORTPATH" "VLA-GET-PROFILES" "VLA-GET-SELECTION" "VLA-GET-DRAFTING" "VLA-GET-USER" "VLA-GET-SYSTEM" "VLA-GET-OUTPUT" "VLA-GET-OPENSAVE" "VLA-GET-DISPLAY" "VLA-GET-FILES" "VLA-APPEND" "VLA-PUT-ITEM" "VLA-PUT-TEXT" "VLA-GET-TEXT" "VLA-GET-VALUES" "VLA-GET-SECTIONS" "VLA-GET-SECTION" "VLA-PUT-SECTION" "VLA-REMOVEALL" "VLA-COORDFROMWORLDTOPIXEL" "VLA-COORDFROMPIXELTOWORLD" "VLA-GETWINNUM" "VLA-SHOWMENU" "VLA-SAVEDATABASE" "VLA-OPENDATABASE" "VLA-NEWDATABASE" "VLA-SHELLEXEC" "VLA-CHOOSEFOLDER" "VLA-CHOOSEFILE" "VLA-TRANSLATESTRING" "VLA-MATRIX4X4" "VLA-GETPOLYLINE" "VLA-ANALYZEENT" "VLA-CREATETYPEDARRAYFROMJSARRAY" "VLA-CREATESAFEARRAYFROMVECTOR" "VLA-LAUNCHBROWSERDIALOG" "VLA-ISREMOTEFILE" "VLA-PUTREMOTEFILE" "VLA-GETREMOTEFILE" "VLA-ISURL" "VLA-GETSUBENTITY" "VLA-PROMPT" "VLA-GETENTITY" "VLA-CREATETYPEDARRAY" "VLA-POLARPOINT" "VLA-GETPOINT" "VLA-GETORIENTATION" "VLA-GETDISTANCE" "VLA-GETCORNER" "VLA-ANGLEFROMXAXIS" "VLA-GETANGLE" "VLA-GETSTRING" "VLA-GETKEYWORD" "VLA-GETINPUT" "VLA-GETREAL" "VLA-GETINTEGER" "VLA-INITIALIZEUSERINPUT" "VLA-TRANSLATECOORDINATES" "VLA-REALTOSTRING" "VLA-DISTANCETOREAL" "VLA-ANGLETOSTRING" "VLA-ANGLETOREAL" "VLA-SELECTONSCREEN" "VLA-SELECTBYPOLYGON" "VLA-SELECTATPOINT" "VLA-CLEAR" "VLA-ADDITEMS" "VLA-ERASE" "VLA-GET-ITEM" "VLA-ADDCUSTOMOBJECTTOBLOCK" "VLA-ENDUNDOMARK" "VLA-STARTUNDOMARK" "VLA-GET-DATABASE" "VLA-PUT-WINDOWTITLE" "VLA-GET-WINDOWTITLE" "VLA-GET-ACTIVELAYOUT" "VLA-PUT-ACTIVELAYOUT" "VLA-CLOSE" "VLA-ACTIVATE" "VLA-GET-ACTIVE" "VLA-GET-PICKFIRSTSELECTIONSET" "VLA-REGEN" "VLA-SETVARIABLE" "VLA-GETVARIABLE" "VLA-PURGEALL" "VLA-WBLOCK" "VLA-SAVEAS" "VLA-SAVE" "VLA-NEW" "VLA-EXPORT" "VLA-IMPORT" "VLA-AUDITINFO" "VLA-OPEN" "VLA-PUT-MSPACE" "VLA-GET-MSPACE" "VLA-GET-SAVED" "VLA-PUT-OBJECTSNAPMODE" "VLA-GET-OBJECTSNAPMODE" "VLA-GET-ACTIVESELECTIONSET" "VLA-GET-SELECTIONSETS" "VLA-PUT-ACTIVESPACE" "VLA-GET-ACTIVESPACE" "VLA-PUT-ACTIVEPVIEWPORT" "VLA-GET-ACTIVEPVIEWPORT" "VLA-PUT-ACTIVEVIEWPORT" "VLA-GET-ACTIVEVIEWPORT" "VLA-PUT-ACTIVEUCS" "VLA-GET-ACTIVEUCS" "VLA-PUT-ACTIVETEXTSTYLE" "VLA-GET-ACTIVETEXTSTYLE" "VLA-PUT-ACTIVEDIMSTYLE" "VLA-GET-ACTIVEDIMSTYLE" "VLA-PUT-ACTIVELINETYPE" "VLA-GET-ACTIVELINETYPE" "VLA-PUT-ACTIVELAYER" "VLA-GET-ACTIVELAYER" "VLA-GET-PLOT" "VLA-GETINTERFACEOBJECT" "VLA-APPLYPROFILE" "VLA-RUNMACRO" "VLA-GET-MENUBAR" "VLA-GET-MENUGROUPS" "VLA-GET-LISTARX" "VLA-UNLOADARX" "VLA-LOADARX" "VLA-GET-LISTMODULES" "VLA-UNLOADMODULE" "VLA-LOADMODULE" "VLA-NEWPARAM" "VLA-HELP" "VLA-GET-PROFILE" "VLA-GET-CURUSERAPPDATA" "VLA-GET-ALLUSERSAPPDATA" "VLA-GET-SERVICES" "VLA-SENDCOMMAND" "VLA-GET-UTILITY" "VLA-GET-HWND" "VLA-ZOOMPREVIOUS" "VLA-GETSTATE" "VLA-ZOOMPICKWINDOW" "VLA-ZOOMWINDOW" "VLA-ZOOMSCALED" "VLA-ZOOMCENTER" "VLA-ZOOMALL" "VLA-ZOOMEXTENTS" "VLA-PUT-WINDOWSTATE" "VLA-GET-WINDOWSTATE" "VLA-GET-DOCUMENTS" "VLA-QUIT" "VLA-GET-STATUSID" "VLA-GET-VERSION" "VLA-PUT-WINDOWTOP" "VLA-GET-WINDOWTOP" "VLA-GET-LOCALEID" "VLA-PUT-WINDOWLEFT" "VLA-GET-WINDOWLEFT" "VLA-GET-FULLNAME" "VLA-PUT-ACTIVEDOCUMENT" "VLA-GET-ACTIVEDOCUMENT" "VLA-GET-CAPTION" "VLA-PUT-CAPTION" "VLA-PUT-COLOR" "VLA-GET-COLOR" "VLA-ONMODIFIED" "VLA-PUT-DWFFORMAT" "VLA-GET-DWFFORMAT" "VLA-PUT-UNDERLAYLAYEROVERRIDEAPPLIED" "VLA-GET-UNDERLAYLAYEROVERRIDEAPPLIED" "VLA-PUT-UNDERLAYVISIBILITY" "VLA-GET-UNDERLAYVISIBILITY" "VLA-PUT-FILE" "VLA-GET-FILE" "VLA-PUT-ADJUSTFORBACKGROUND" "VLA-GET-ADJUSTFORBACKGROUND" "VLA-PUT-MONOCHROME" "VLA-GET-MONOCHROME" "VLA-GET-ITEMNAME" "VLA-PUT-ITEMNAME" "VLA-PUT-UNDERLAYNAME" "VLA-GET-UNDERLAYNAME" "VLA-PUT-INTERSECTIONBOUNDARYVISIBLE" "VLA-GET-INTERSECTIONBOUNDARYVISIBLE" "VLA-GET-TOTALLENGTH" "VLA-GET-TURNSLOPE" "VLA-PUT-TOPRADIUS" "VLA-GET-TOPRADIUS" "VLA-PUT-BASERADIUS" "VLA-GET-BASERADIUS" "VLA-PUT-TURNHEIGHT" "VLA-GET-TURNHEIGHT" "VLA-PUT-TURNS" "VLA-GET-TURNS" "VLA-PUT-CONSTRAIN" "VLA-GET-CONSTRAIN" "VLA-PUT-TAPERANGLE" "VLA-GET-TAPERANGLE" "VLA-GET-AXISDIRECTION" "VLA-PUT-AXISPOSITION" "VLA-GET-AXISPOSITION" "VLA-PUT-REVOLUTIONANGLE" "VLA-GET-REVOLUTIONANGLE" "VLA-PUT-SCALE" "VLA-GET-SCALE" "VLA-PUT-TWIST" "VLA-GET-TWIST" "VLA-PUT-BANK" "VLA-GET-BANK" "VLA-PUT-PROFILEROTATION" "VLA-GET-PROFILEROTATION" "VLA-PUT-ENDDRAFTMAGNITUDE" "VLA-GET-ENDDRAFTMAGNITUDE" "VLA-PUT-ENDDRAFTANGLE" "VLA-GET-ENDDRAFTANGLE" "VLA-PUT-STARTDRAFTMAGNITUDE" "VLA-GET-STARTDRAFTMAGNITUDE" "VLA-PUT-STARTDRAFTANGLE" "VLA-GET-STARTDRAFTANGLE" "VLA-PUT-SURFACENORMALS" "VLA-GET-SURFACENORMALS" "VLA-GET-NUMGUIDEPATHS" "VLA-GET-NUMCROSSSECTIONS" "VLA-PUT-VISOLINEDENSITY" "VLA-GET-VISOLINEDENSITY" "VLA-PUT-UISOLINEDENSITY" "VLA-GET-UISOLINEDENSITY" "VLA-GET-SURFACETYPE" "VLA-GET-UNITSTYPE" "VLA-PUT-VALUE" "VLA-GET-VALUE" "VLA-GET-ALLOWEDVALUES" "VLA-GET-SHOW" "VLA-GET-READONLY" "VLA-GET-PROPERTYNAME" "VLA-PUT-LINETYPEAT" "VLA-GET-LINETYPEAT" "VLA-PUT-COLORAT" "VLA-GET-COLORAT" "VLA-PUT-OFFSETAT" "VLA-GET-OFFSETAT" "VLA-ADDELEMENT" "VLA-PUT-ENDINNERARCS" "VLA-GET-ENDINNERARCS" "VLA-PUT-ENDROUNDCAP" "VLA-GET-ENDROUNDCAP" "VLA-PUT-ENDSQUARECAP" "VLA-GET-ENDSQUARECAP" "VLA-PUT-STARTINNERARCS" "VLA-GET-STARTINNERARCS" "VLA-PUT-STARTROUNDCAP" "VLA-GET-STARTROUNDCAP" "VLA-PUT-STARTSQUARECAP" "VLA-GET-STARTSQUARECAP" "VLA-PUT-SHOWMITERS" "VLA-GET-SHOWMITERS" "VLA-PUT-FILLED" "VLA-GET-FILLED" "VLA-GET-ELEMENTSCOUNT" "VLA-PUT-FILLCOLOR" "VLA-GET-FILLCOLOR" "VLA-SETRELATIVEDRAWORDER" "VLA-GETRELATIVEDRAWORDER" "VLA-GETFULLDRAWORDER" "VLA-BLOCK" "VLA-SWAPORDER" "VLA-MOVEABOVE" "VLA-MOVEBELOW" "VLA-MOVETOTOP" "VLA-MOVETOBOTTOM" "VLA-SETTEMPLATEID" "VLA-PUT-TEMPLATEID" "VLA-GET-TEMPLATEID" "VLA-GETISMERGEALLENABLED" "VLA-SETCELLCLASS" "VLA-GETCELLCLASS" "VLA-SETFORMAT2" "VLA-GETFORMAT2" "VLA-SETBACKGROUNDCOLOR2" "VLA-GETBACKGROUNDCOLOR2" "VLA-SETCOLOR2" "VLA-GETCOLOR2" "VLA-SETALIGNMENT2" "VLA-GETALIGNMENT2" "VLA-SETTEXTSTYLEID" "VLA-GETTEXTSTYLEID" "VLA-GETCELLSTYLES" "VLA-GET-NUMCELLSTYLES" "VLA-GETISCELLSTYLEINUSE" "VLA-GETUNIQUECELLSTYLENAME" "VLA-DELETECELLSTYLE" "VLA-RENAMECELLSTYLE" "VLA-CREATECELLSTYLEFROMSTYLE" "VLA-CREATECELLSTYLE" "VLA-SETCOLOR" "VLA-GETCOLOR" "VLA-GET-LINKPATH" "VLA-GET-LINKNAME" "VLA-GET-LOADED" "VLA-GETFACES" "VLA-SETNURBSDATA" "VLA-PUT-TEXTALIGNMENTTYPE" "VLA-GET-TEXTALIGNMENTTYPE" "VLA-PUT-TEXTANGLETYPE" "VLA-GET-TEXTANGLETYPE" "VLA-PUT-BREAKSIZE" "VLA-GET-BREAKSIZE" "VLA-PUT-ANNOTATIVE" "VLA-GET-ANNOTATIVE" "VLA-GET-OVERWRITEPROPCHANGED" "VLA-PUT-BLOCKROTATION" "VLA-GET-BLOCKROTATION" "VLA-PUT-ENABLEBLOCKROTATION" "VLA-GET-ENABLEBLOCKROTATION" "VLA-PUT-ENABLEBLOCKSCALE" "VLA-GET-ENABLEBLOCKSCALE" "VLA-PUT-BLOCKCOLOR" "VLA-GET-BLOCKCOLOR" "VLA-PUT-BLOCK" "VLA-PUT-ALIGNSPACE" "VLA-GET-ALIGNSPACE" "VLA-PUT-ENABLEFRAMETEXT" "VLA-GET-ENABLEFRAMETEXT" "VLA-PUT-ARROWSIZE" "VLA-GET-ARROWSIZE" "VLA-PUT-ARROWSYMBOL" "VLA-GET-ARROWSYMBOL" "VLA-PUT-ENABLEDOGLEG" "VLA-GET-ENABLEDOGLEG" "VLA-PUT-ENABLELANDING" "VLA-GET-ENABLELANDING" "VLA-PUT-LEADERLINETYPEID" "VLA-GET-LEADERLINETYPEID" "VLA-PUT-SECONDSEGMENTANGLECONSTRAINT" "VLA-GET-SECONDSEGMENTANGLECONSTRAINT" "VLA-PUT-FIRSTSEGMENTANGLECONSTRAINT" "VLA-GET-FIRSTSEGMENTANGLECONSTRAINT" "VLA-PUT-MAXLEADERSEGMENTSPOINTS" "VLA-GET-MAXLEADERSEGMENTSPOINTS" "VLA-PUT-DRAWLEADERORDERTYPE" "VLA-GET-DRAWLEADERORDERTYPE" "VLA-PUT-DRAWMLEADERORDERTYPE" "VLA-GET-DRAWMLEADERORDERTYPE" "VLA-PUT-BITFLAGS" "VLA-GET-BITFLAGS" "VLA-SETOVERLAID" "VLA-GET-ISUNLOADED" "VLA-GET-ISDEPENDENT" "VLA-GET-ISRESOLVED" "VLA-GET-ISFROMOVERLAYREFERENCE" "VLA-GETREFERENCES" "VLA-PUT-SHAPESTYLEAT" "VLA-GET-SHAPESTYLEAT" "VLA-PUT-SHAPEOFFSETAT" "VLA-GET-SHAPEOFFSETAT" "VLA-PUT-SHAPEROTATIONAT" "VLA-GET-SHAPEROTATIONAT" "VLA-PUT-SHAPENUMBERAT" "VLA-GET-SHAPENUMBERAT" "VLA-PUT-SHAPESCALEAT" "VLA-GET-SHAPESCALEAT" "VLA-PUT-DASHLENGTHAT" "VLA-GET-DASHLENGTHAT" "VLA-PUT-PATTERNLENGTH" "VLA-GET-PATTERNLENGTH" "VLA-PUT-TEXTAT" "VLA-GET-TEXTAT" "VLA-PUT-NUMDASHES" "VLA-GET-NUMDASHES" "VLA-GETUNIQUESECTIONNAME" "VLA-GETLIVESECTION" "VLA-REMOVECUSTOMBYKEY" "VLA-REMOVECUSTOMBYINDEX" "VLA-ADDCUSTOMINFO" "VLA-SETCUSTOMBYKEY" "VLA-SETCUSTOMBYINDEX" "VLA-GETCUSTOMBYKEY" "VLA-GETCUSTOMBYINDEX" "VLA-NUMCUSTOMINFO" "VLA-PUT-TITLE" "VLA-GET-TITLE" "VLA-PUT-SUBJECT" "VLA-GET-SUBJECT" "VLA-PUT-REVISIONNUMBER" "VLA-GET-REVISIONNUMBER" "VLA-PUT-LASTSAVEDBY" "VLA-GET-LASTSAVEDBY" "VLA-PUT-KEYWORDS" "VLA-GET-KEYWORDS" "VLA-PUT-HYPERLINKBASE" "VLA-GET-HYPERLINKBASE" "VLA-PUT-AUTHOR" "VLA-GET-AUTHOR" "VLA-GET-REFERENCECOUNT" "VLA-GET-FILESIZE" "VLA-GET-TIMESTAMP" "VLA-GET-INDEX" "VLA-GET-AFFECTSGRAPHICS" "VLA-GET-ISMODIFIED" "VLA-GET-FEATURE" "VLA-GET-VERSIONGUID" "VLA-GET-FINGERPRINTGUID" "VLA-GET-FOUNDPATH" "VLA-GET-FILENAME" "VLA-GET-FULLFILENAME" "VLA-UPDATEENTRY" "VLA-REMOVEENTRY" "VLA-INDEXOF" "VLA-CREATEENTRY" "VLA-GET-LINEWEIGHTDISPLAY" "VLA-PUT-LINEWEIGHTDISPLAY" "VLA-GET-SEGMENTPERPOLYLINE" "VLA-PUT-SEGMENTPERPOLYLINE" "VLA-GET-RENDERSMOOTHNESS" "VLA-PUT-RENDERSMOOTHNESS" "VLA-GET-MAXACTIVEVIEWPORTS" "VLA-PUT-MAXACTIVEVIEWPORTS" "VLA-GET-DISPLAYSILHOUETTE" "VLA-PUT-DISPLAYSILHOUETTE" "VLA-GET-CONTOURLINESPERSURFACE" "VLA-PUT-CONTOURLINESPERSURFACE" "VLA-PUT-OBJECTSORTBYPSOUTPUT" "VLA-GET-OBJECTSORTBYPSOUTPUT" "VLA-PUT-OBJECTSORTBYPLOTTING" "VLA-GET-OBJECTSORTBYPLOTTING" "VLA-PUT-OBJECTSORTBYREGENS" "VLA-GET-OBJECTSORTBYREGENS" "VLA-PUT-OBJECTSORTBYREDRAWS" "VLA-GET-OBJECTSORTBYREDRAWS" "VLA-PUT-OBJECTSORTBYSNAP" "VLA-GET-OBJECTSORTBYSNAP" "VLA-PUT-OBJECTSORTBYSELECTION" "VLA-GET-OBJECTSORTBYSELECTION" "VLA-PUT-ALLOWLONGSYMBOLNAMES" "VLA-GET-ALLOWLONGSYMBOLNAMES" "VLA-PUT-OLELAUNCH" "VLA-GET-OLELAUNCH" "VLA-PUT-XREFLAYERVISIBILITY" "VLA-GET-XREFLAYERVISIBILITY" "VLA-PUT-XREFEDIT" "VLA-GET-XREFEDIT" "VLA-PUT-SOLIDFILL" "VLA-GET-SOLIDFILL" "VLA-SETVIEW" "VLA-SPLIT" "VLA-GET-UPPERRIGHTCORNER" "VLA-GET-LOWERLEFTCORNER" "VLA-PUT-ORTHOON" "VLA-GET-ORTHOON" "VLA-DELETECONFIGURATION" "VLA-GETUCSMATRIX" "VLA-PUT-YVECTOR" "VLA-GET-YVECTOR" "VLA-PUT-XVECTOR" "VLA-GET-XVECTOR" "VLA-SETFONT" "VLA-GETFONT" "VLA-PUT-LASTHEIGHT" "VLA-GET-LASTHEIGHT" "VLA-PUT-FONTFILE" "VLA-GET-FONTFILE" "VLA-PUT-BIGFONTFILE" "VLA-GET-BIGFONTFILE" "VLA-PUT-TRANSLATEIDS" "VLA-GET-TRANSLATEIDS" "VLA-SETXRECORDDATA" "VLA-GETXRECORDDATA" "VLA-ADDXRECORD" "VLA-REPLACE" "VLA-RENAME" "VLA-REMOVE" "VLA-GETOBJECT" "VLA-GETNAME" "VLA-ADDOBJECT" "VLA-LOAD" "VLA-GET-USED" "VLA-PUT-DESCRIPTION" "VLA-GET-DESCRIPTION" "VLA-PUT-VIEWPORTDEFAULT" "VLA-GET-VIEWPORTDEFAULT" "VLA-PUT-PLOTTABLE" "VLA-GET-PLOTTABLE" "VLA-PUT-LOCK" "VLA-GET-LOCK" "VLA-PUT-LAYERON" "VLA-GET-LAYERON" "VLA-PUT-FREEZE" "VLA-GET-FREEZE" "VLA-GENERATEUSAGEDATA" "VLA-REMOVEITEMS" "VLA-APPENDITEMS" "VLA-PUT-HASVPASSOCIATION" "VLA-GET-HASVPASSOCIATION" "VLA-PUT-LAYERSTATE" "VLA-GET-LAYERSTATE" "VLA-PUT-LAYOUTID" "VLA-GET-LAYOUTID" "VLA-PUT-CATEGORYNAME" "VLA-GET-CATEGORYNAME" "VLA-GET-LAYERPROPERTYOVERRIDES" "VLA-PUT-STANDARDSCALE2" "VLA-GET-STANDARDSCALE2" "VLA-SYNCMODELVIEW" "VLA-GET-HASSHEETVIEW" "VLA-PUT-LABELBLOCKID" "VLA-GET-LABELBLOCKID" "VLA-PUT-SHEETVIEW" "VLA-GET-SHEETVIEW" "VLA-PUT-MODELVIEW" "VLA-GET-MODELVIEW" "VLA-PUT-SHADEPLOT" "VLA-GET-SHADEPLOT" "VLA-PUT-VISUALSTYLE" "VLA-GET-VISUALSTYLE" "VLA-PUT-ARCSMOOTHNESS" "VLA-GET-ARCSMOOTHNESS" "VLA-PUT-TARGET" "VLA-GET-TARGET" "VLA-PUT-LENSLENGTH" "VLA-GET-LENSLENGTH" "VLA-PUT-TWISTANGLE" "VLA-GET-TWISTANGLE" "VLA-DISPLAY" "VLA-SETSNAPSPACING" "VLA-GETSNAPSPACING" "VLA-SETGRIDSPACING" "VLA-GETGRIDSPACING" "VLA-PUT-UCSICONATORIGIN" "VLA-GET-UCSICONATORIGIN" "VLA-PUT-UCSICONON" "VLA-GET-UCSICONON" "VLA-PUT-SNAPROTATIONANGLE" "VLA-GET-SNAPROTATIONANGLE" "VLA-PUT-SNAPON" "VLA-GET-SNAPON" "VLA-PUT-SNAPBASEPOINT" "VLA-GET-SNAPBASEPOINT" "VLA-PUT-UCSPERVIEWPORT" "VLA-GET-UCSPERVIEWPORT" "VLA-PUT-CUSTOMSCALE" "VLA-GET-CUSTOMSCALE" "VLA-PUT-DISPLAYLOCKED" "VLA-GET-DISPLAYLOCKED" "VLA-GET-CLIPPED" "VLA-PUT-VIEWPORTON" "VLA-GET-VIEWPORTON" "VLA-PUT-GRIDON" "VLA-GET-GRIDON" "VLA-ADDPVIEWPORT" "VLA-PUT-OLESOURCEAPP" "VLA-GET-OLESOURCEAPP" "VLA-PUT-OLEPLOTQUALITY" "VLA-GET-OLEPLOTQUALITY" "VLA-PUT-OLEITEMTYPE" "VLA-GET-OLEITEMTYPE" "VLA-PUT-LOCKASPECTRATIO" "VLA-GET-LOCKASPECTRATIO" "VLA-PUT-SCALEHEIGHT" "VLA-GET-SCALEHEIGHT" "VLA-PUT-SCALEWIDTH" "VLA-GET-SCALEWIDTH" "VLA-SETDOGLEGDIRECTION" "VLA-GETDOGLEGDIRECTION" "VLA-PUT-TEXTFRAMEDISPLAY" "VLA-GET-TEXTFRAMEDISPLAY" "VLA-GETVERTEXCOUNT" "VLA-GETLEADERLINEINDEXES" "VLA-GETLEADERINDEX" "VLA-GET-CONTENTTYPE" "VLA-PUT-CONTENTTYPE" "VLA-GETLEADERLINEVERTICES" "VLA-SETLEADERLINEVERTICES" "VLA-REMOVELEADERLINE" "VLA-ADDLEADERLINEEX" "VLA-ADDLEADERLINE" "VLA-REMOVELEADER" "VLA-GET-LEADERCOUNT" "VLA-PUT-CONTENTBLOCKTYPE" "VLA-GET-CONTENTBLOCKTYPE" "VLA-PUT-LANDINGGAP" "VLA-GET-LANDINGGAP" "VLA-PUT-TEXTBOTTOMATTACHMENTTYPE" "VLA-GET-TEXTBOTTOMATTACHMENTTYPE" "VLA-PUT-TEXTTOPATTACHMENTTYPE" "VLA-GET-TEXTTOPATTACHMENTTYPE" "VLA-PUT-TEXTRIGHTATTACHMENTTYPE" "VLA-GET-TEXTRIGHTATTACHMENTTYPE" "VLA-PUT-TEXTLEFTATTACHMENTTYPE" "VLA-GET-TEXTLEFTATTACHMENTTYPE" "VLA-PUT-TEXTATTACHMENTDIRECTION" "VLA-GET-TEXTATTACHMENTDIRECTION" "VLA-PUT-TEXTBACKGROUNDFILL" "VLA-GET-TEXTBACKGROUNDFILL" "VLA-PUT-TEXTLINESPACINGSTYLE" "VLA-GET-TEXTLINESPACINGSTYLE" "VLA-PUT-TEXTLINESPACINGDISTANCE" "VLA-GET-TEXTLINESPACINGDISTANCE" "VLA-PUT-TEXTLINESPACINGFACTOR" "VLA-GET-TEXTLINESPACINGFACTOR" "VLA-PUT-TEXTWIDTH" "VLA-GET-TEXTWIDTH" "VLA-PUT-TEXTDIRECTION" "VLA-GET-TEXTDIRECTION" "VLA-PUT-TEXTJUSTIFY" "VLA-GET-TEXTJUSTIFY" "VLA-PUT-TEXTSTYLENAME" "VLA-GET-TEXTSTYLENAME" "VLA-PUT-BLOCKSCALE" "VLA-GET-BLOCKSCALE" "VLA-PUT-BLOCKCONNECTIONTYPE" "VLA-GET-BLOCKCONNECTIONTYPE" "VLA-PUT-CONTENTBLOCKNAME" "VLA-GET-CONTENTBLOCKNAME" "VLA-PUT-DOGLEGLENGTH" "VLA-GET-DOGLEGLENGTH" "VLA-PUT-DOGLEGGED" "VLA-GET-DOGLEGGED" "VLA-PUT-LEADERLINEWEIGHT" "VLA-GET-LEADERLINEWEIGHT" "VLA-PUT-LEADERLINETYPE" "VLA-GET-LEADERLINETYPE" "VLA-PUT-LEADERLINECOLOR" "VLA-GET-LEADERLINECOLOR" "VLA-PUT-LEADERTYPE" "VLA-GET-LEADERTYPE" "VLA-PUT-CURVETANGENCYLINESLINEWEIGHT" "VLA-GET-CURVETANGENCYLINESLINEWEIGHT" "VLA-PUT-CURVETANGENCYLINESPLOTSTYLENAME" "VLA-GET-CURVETANGENCYLINESPLOTSTYLENAME" "VLA-PUT-CURVETANGENCYLINESLINETYPESCALE" "VLA-GET-CURVETANGENCYLINESLINETYPESCALE" "VLA-PUT-CURVETANGENCYLINESLINETYPE" "VLA-GET-CURVETANGENCYLINESLINETYPE" "VLA-PUT-CURVETANGENCYLINESLAYER" "VLA-GET-CURVETANGENCYLINESLAYER" "VLA-PUT-CURVETANGENCYLINESCOLOR" "VLA-GET-CURVETANGENCYLINESCOLOR" "VLA-PUT-CURVETANGENCYLINESVISIBLE" "VLA-GET-CURVETANGENCYLINESVISIBLE" "VLA-PUT-FOREGROUNDLINESEDGETRANSPARENCY" "VLA-GET-FOREGROUNDLINESEDGETRANSPARENCY" "VLA-PUT-FOREGROUNDLINESFACETRANSPARENCY" "VLA-GET-FOREGROUNDLINESFACETRANSPARENCY" "VLA-PUT-FOREGROUNDLINESLINEWEIGHT" "VLA-GET-FOREGROUNDLINESLINEWEIGHT" "VLA-PUT-FOREGROUNDLINESPLOTSTYLENAME" "VLA-GET-FOREGROUNDLINESPLOTSTYLENAME" "VLA-PUT-FOREGROUNDLINESLINETYPESCALE" "VLA-GET-FOREGROUNDLINESLINETYPESCALE" "VLA-PUT-FOREGROUNDLINESLINETYPE" "VLA-GET-FOREGROUNDLINESLINETYPE" "VLA-PUT-FOREGROUNDLINESLAYER" "VLA-GET-FOREGROUNDLINESLAYER" "VLA-PUT-FOREGROUNDLINESCOLOR" "VLA-GET-FOREGROUNDLINESCOLOR" "VLA-PUT-FOREGROUNDLINESHIDDENLINE" "VLA-GET-FOREGROUNDLINESHIDDENLINE" "VLA-PUT-FOREGROUNDLINESVISIBLE" "VLA-GET-FOREGROUNDLINESVISIBLE" "VLA-PUT-BACKGROUNDLINESLINEWEIGHT" "VLA-GET-BACKGROUNDLINESLINEWEIGHT" "VLA-PUT-BACKGROUNDLINESPLOTSTYLENAME" "VLA-GET-BACKGROUNDLINESPLOTSTYLENAME" "VLA-PUT-BACKGROUNDLINESLINETYPESCALE" "VLA-GET-BACKGROUNDLINESLINETYPESCALE" "VLA-PUT-BACKGROUNDLINESLINETYPE" "VLA-GET-BACKGROUNDLINESLINETYPE" "VLA-PUT-BACKGROUNDLINESLAYER" "VLA-GET-BACKGROUNDLINESLAYER" "VLA-PUT-BACKGROUNDLINESCOLOR" "VLA-GET-BACKGROUNDLINESCOLOR" "VLA-PUT-BACKGROUNDLINESHIDDENLINE" "VLA-GET-BACKGROUNDLINESHIDDENLINE" "VLA-PUT-BACKGROUNDLINESVISIBLE" "VLA-GET-BACKGROUNDLINESVISIBLE" "VLA-PUT-INTERSECTIONFILLFACETRANSPARENCY" "VLA-GET-INTERSECTIONFILLFACETRANSPARENCY" "VLA-PUT-INTERSECTIONFILLLINEWEIGHT" "VLA-GET-INTERSECTIONFILLLINEWEIGHT" "VLA-PUT-INTERSECTIONFILLPLOTSTYLENAME" "VLA-GET-INTERSECTIONFILLPLOTSTYLENAME" "VLA-PUT-INTERSECTIONFILLLINETYPESCALE" "VLA-GET-INTERSECTIONFILLLINETYPESCALE" "VLA-PUT-INTERSECTIONFILLLINETYPE" "VLA-GET-INTERSECTIONFILLLINETYPE" "VLA-PUT-INTERSECTIONFILLLAYER" "VLA-GET-INTERSECTIONFILLLAYER" "VLA-PUT-INTERSECTIONFILLCOLOR" "VLA-GET-INTERSECTIONFILLCOLOR" "VLA-PUT-INTERSECTIONFILLHATCHSPACING" "VLA-GET-INTERSECTIONFILLHATCHSPACING" "VLA-PUT-INTERSECTIONFILLHATCHSCALE" "VLA-GET-INTERSECTIONFILLHATCHSCALE" "VLA-PUT-INTERSECTIONFILLHATCHANGLE" "VLA-GET-INTERSECTIONFILLHATCHANGLE" "VLA-PUT-INTERSECTIONFILLHATCHPATTERNNAME" "VLA-GET-INTERSECTIONFILLHATCHPATTERNNAME" "VLA-PUT-INTERSECTIONFILLHATCHPATTERNTYPE" "VLA-GET-INTERSECTIONFILLHATCHPATTERNTYPE" "VLA-PUT-INTERSECTIONFILLVISIBLE" "VLA-GET-INTERSECTIONFILLVISIBLE" "VLA-PUT-INTERSECTIONBOUNDARYDIVISIONLINES" "VLA-GET-INTERSECTIONBOUNDARYDIVISIONLINES" "VLA-PUT-INTERSECTIONBOUNDARYLINEWEIGHT" "VLA-GET-INTERSECTIONBOUNDARYLINEWEIGHT" "VLA-PUT-INTERSECTIONBOUNDARYPLOTSTYLENAME" "VLA-GET-INTERSECTIONBOUNDARYPLOTSTYLENAME" "VLA-PUT-INTERSECTIONBOUNDARYLINETYPESCALE" "VLA-GET-INTERSECTIONBOUNDARYLINETYPESCALE" "VLA-PUT-INTERSECTIONBOUNDARYLINETYPE" "VLA-GET-INTERSECTIONBOUNDARYLINETYPE" "VLA-PUT-INTERSECTIONBOUNDARYLAYER" "VLA-GET-INTERSECTIONBOUNDARYLAYER" "VLA-PUT-INTERSECTIONBOUNDARYCOLOR" "VLA-GET-INTERSECTIONBOUNDARYCOLOR" "VLA-PUT-DESTINATIONFILE" "VLA-GET-DESTINATIONFILE" "VLA-PUT-DESTINATIONBLOCK" "VLA-GET-DESTINATIONBLOCK" "VLA-PUT-SOURCEOBJECTS" "VLA-GET-SOURCEOBJECTS" "VLA-PUT-GENERATIONOPTIONS" "VLA-GET-GENERATIONOPTIONS" "VLA-GETSECTIONTYPESETTINGS" "VLA-PUT-CURRENTSECTIONTYPE" "VLA-GET-CURRENTSECTIONTYPE" "VLA-GENERATESECTIONGEOMETRY" "VLA-GET-SETTINGS" "VLA-CREATEJOG" "VLA-REMOVEVERTEX" "VLA-PUT-VERTICES" "VLA-GET-VERTICES" "VLA-GET-NUMVERTICES" "VLA-PUT-BOTTOMHEIGHT" "VLA-GET-BOTTOMHEIGHT" "VLA-PUT-TOPHEIGHT" "VLA-GET-TOPHEIGHT" "VLA-PUT-INDICATORFILLCOLOR" "VLA-GET-INDICATORFILLCOLOR" "VLA-PUT-INDICATORTRANSPARENCY" "VLA-GET-INDICATORTRANSPARENCY" "VLA-PUT-LIVESECTIONENABLED" "VLA-GET-LIVESECTIONENABLED" "VLA-PUT-VERTICALDIRECTION" "VLA-GET-VERTICALDIRECTION" "VLA-PUT-VIEWINGDIRECTION" "VLA-GET-VIEWINGDIRECTION" "VLA-PUT-STATE" "VLA-GET-STATE" "VLA-PUT-CHORDPOINT" "VLA-GET-CHORDPOINT" "VLA-PUT-JOGANGLE" "VLA-GET-JOGANGLE" "VLA-PUT-JOGLOCATION" "VLA-GET-JOGLOCATION" "VLA-PUT-OVERRIDECENTER" "VLA-GET-OVERRIDECENTER" "VLA-PUT-SYMBOLPOSITION" "VLA-GET-SYMBOLPOSITION" "VLA-PUT-HASLEADER" "VLA-GET-HASLEADER" "VLA-PUT-ARCENDPARAM" "VLA-GET-ARCENDPARAM" "VLA-PUT-ARCSTARTPARAM" "VLA-GET-ARCSTARTPARAM" "VLA-PUT-ISPARTIAL" "VLA-GET-ISPARTIAL" "VLA-PUT-LEADER2POINT" "VLA-GET-LEADER2POINT" "VLA-PUT-LEADER1POINT" "VLA-GET-LEADER1POINT" "VLA-PUT-CENTERPOINT" "VLA-GET-CENTERPOINT" "VLA-PUT-ARCPOINT" "VLA-GET-ARCPOINT" "VLA-SETTOOLTIP" "VLA-SETCOLUMNNAME" "VLA-GETCOLUMNNAME" "VLA-PUT-BREAKSPACING" "VLA-GET-BREAKSPACING" "VLA-PUT-TABLEBREAKHEIGHT" "VLA-GET-TABLEBREAKHEIGHT" "VLA-PUT-ALLOWMANUALHEIGHTS" "VLA-GET-ALLOWMANUALHEIGHTS" "VLA-PUT-ALLOWMANUALPOSITIONS" "VLA-GET-ALLOWMANUALPOSITIONS" "VLA-PUT-TABLEBREAKFLOWDIRECTION" "VLA-GET-TABLEBREAKFLOWDIRECTION" "VLA-PUT-REPEATBOTTOMLABELS" "VLA-GET-REPEATBOTTOMLABELS" "VLA-PUT-REPEATTOPLABELS" "VLA-GET-REPEATTOPLABELS" "VLA-PUT-BREAKSENABLED" "VLA-GET-BREAKSENABLED" "VLA-ISMERGEALLENABLED" "VLA-ENABLEMERGEALL" "VLA-SETCELLSTATE" "VLA-GETCELLSTATE" "VLA-ISFORMATEDITABLE" "VLA-ISCONTENTEDITABLE" "VLA-SETFORMULA" "VLA-GETFORMULA" "VLA-GETHASFORMULA" "VLA-INSERTCOLUMNSANDINHERIT" "VLA-INSERTROWSANDINHERIT" "VLA-SETGRIDLINESTYLE" "VLA-GETGRIDLINESTYLE" "VLA-SETOVERRIDE" "VLA-GETOVERRIDE" "VLA-SETCONTENTLAYOUT" "VLA-GETCONTENTLAYOUT" "VLA-SETMARGIN" "VLA-GETMARGIN" "VLA-GETCONTENTTYPE" "VLA-SETBREAKHEIGHT" "VLA-GETBREAKHEIGHT" "VLA-PUT-ENABLEBREAK" "VLA-SETGRIDDOUBLELINESPACING" "VLA-GETGRIDDOUBLELINESPACING" "VLA-SETGRIDVISIBILITY2" "VLA-GETGRIDVISIBILITY2" "VLA-SETGRIDCOLOR2" "VLA-GETGRIDCOLOR2" "VLA-SETGRIDLINETYPE" "VLA-GETGRIDLINETYPE" "VLA-SETGRIDLINEWEIGHT2" "VLA-GETGRIDLINEWEIGHT2" "VLA-REMOVEALLOVERRIDES" "VLA-SETSCALE" "VLA-GETSCALE" "VLA-SETAUTOSCALE2" "VLA-GETAUTOSCALE2" "VLA-SETROTATION" "VLA-GETROTATION" "VLA-SETTEXTHEIGHT2" "VLA-GETTEXTHEIGHT2" "VLA-SETTEXTSTYLE2" "VLA-GETTEXTSTYLE2" "VLA-SETDATATYPE2" "VLA-GETDATATYPE2" "VLA-SETCONTENTCOLOR2" "VLA-GETCONTENTCOLOR2" "VLA-SETCELLSTYLE" "VLA-GETCELLSTYLE" "VLA-SETCUSTOMDATA" "VLA-GETCUSTOMDATA" "VLA-SETBLOCKATTRIBUTEVALUE2" "VLA-GETBLOCKATTRIBUTEVALUE2" "VLA-SETBLOCKTABLERECORDID2" "VLA-GETBLOCKTABLERECORDID2" "VLA-SETFIELDID2" "VLA-GETFIELDID2" "VLA-SETTEXTSTRING" "VLA-GETTEXTSTRING" "VLA-SETDATAFORMAT" "VLA-GETDATAFORMAT" "VLA-SETVALUEFROMTEXT" "VLA-SETVALUE" "VLA-GETVALUE" "VLA-DELETECONTENT" "VLA-MOVECONTENT" "VLA-CREATECONTENT" "VLA-ISEMPTY" "VLA-RESETCELLVALUE" "VLA-SETCELLVALUEFROMTEXT" "VLA-SETCELLVALUE" "VLA-GETCELLVALUE" "VLA-SETCELLFORMAT" "VLA-GETCELLFORMAT" "VLA-SETCELLDATATYPE" "VLA-GETCELLDATATYPE" "VLA-FORMATVALUE" "VLA-SETFORMAT" "VLA-GETFORMAT" "VLA-SETDATATYPE" "VLA-GETDATATYPE" "VLA-PUT-REGENERATETABLESUPPRESSED" "VLA-GET-REGENERATETABLESUPPRESSED" "VLA-GET-HASSUBSELECTION" "VLA-CLEARSUBSELECTION" "VLA-SETSUBSELECTION" "VLA-GETSUBSELECTION" "VLA-RESELECTSUBREGION" "VLA-SELECTSUBREGION" "VLA-SELECT" "VLA-HITTEST" "VLA-RECOMPUTETABLEBLOCK" "VLA-GENERATELAYOUT" "VLA-SETFIELDID" "VLA-GETFIELDID" "VLA-ISMERGEDCELL" "VLA-UNMERGECELLS" "VLA-MERGECELLS" "VLA-DELETEROWS" "VLA-INSERTROWS" "VLA-DELETECOLUMNS" "VLA-INSERTCOLUMNS" "VLA-SETCELLGRIDVISIBILITY" "VLA-GETCELLGRIDVISIBILITY" "VLA-SETCELLGRIDCOLOR" "VLA-GETCELLGRIDCOLOR" "VLA-SETCELLGRIDLINEWEIGHT" "VLA-GETCELLGRIDLINEWEIGHT" "VLA-SETBLOCKATTRIBUTEVALUE" "VLA-GETBLOCKATTRIBUTEVALUE" "VLA-SETBLOCKROTATION" "VLA-GETBLOCKROTATION" "VLA-SETBLOCKSCALE" "VLA-GETBLOCKSCALE" "VLA-SETBLOCKTABLERECORDID" "VLA-GETBLOCKTABLERECORDID" "VLA-SETAUTOSCALE" "VLA-GETAUTOSCALE" "VLA-SETTEXTROTATION" "VLA-GETTEXTROTATION" "VLA-SETCELLTEXTHEIGHT" "VLA-GETCELLTEXTHEIGHT" "VLA-SETCELLTEXTSTYLE" "VLA-GETCELLTEXTSTYLE" "VLA-SETTEXT" "VLA-GETTEXT" "VLA-GETROWTYPE" "VLA-DELETECELLCONTENT" "VLA-GETCELLSTYLEOVERRIDES" "VLA-SETCELLCONTENTCOLOR" "VLA-GETCELLCONTENTCOLOR" "VLA-SETCELLBACKGROUNDCOLOR" "VLA-GETCELLBACKGROUNDCOLOR" "VLA-SETCELLBACKGROUNDCOLORNONE" "VLA-GETCELLBACKGROUNDCOLORNONE" "VLA-SETCELLALIGNMENT" "VLA-GETCELLALIGNMENT" "VLA-GETATTACHMENTPOINT" "VLA-GETCELLEXTENTS" "VLA-SETCELLTYPE" "VLA-GETCELLTYPE" "VLA-CLEARTABLESTYLEOVERRIDES" "VLA-GET-TABLESTYLEOVERRIDES" "VLA-SETGRIDVISIBILITY" "VLA-GETGRIDVISIBILITY" "VLA-SETGRIDCOLOR" "VLA-GETGRIDCOLOR" "VLA-SETGRIDLINEWEIGHT" "VLA-GETGRIDLINEWEIGHT" "VLA-SETTEXTHEIGHT" "VLA-GETTEXTHEIGHT" "VLA-SETTEXTSTYLE" "VLA-GETTEXTSTYLE" "VLA-SETCONTENTCOLOR" "VLA-GETCONTENTCOLOR" "VLA-SETBACKGROUNDCOLOR" "VLA-GETBACKGROUNDCOLOR" "VLA-SETBACKGROUNDCOLORNONE" "VLA-GETBACKGROUNDCOLORNONE" "VLA-SETALIGNMENT" "VLA-GETALIGNMENT" "VLA-PUT-HEADERSUPPRESSED" "VLA-GET-HEADERSUPPRESSED" "VLA-PUT-TITLESUPPRESSED" "VLA-GET-TITLESUPPRESSED" "VLA-PUT-DIRECTION" "VLA-GET-DIRECTION" "VLA-GET-MINIMUMTABLEHEIGHT" "VLA-GET-MINIMUMTABLEWIDTH" "VLA-GETMINIMUMROWHEIGHT" "VLA-GETMINIMUMCOLUMNWIDTH" "VLA-PUT-ROWHEIGHT" "VLA-SETROWHEIGHT" "VLA-GETROWHEIGHT" "VLA-PUT-COLUMNWIDTH" "VLA-SETCOLUMNWIDTH" "VLA-GETCOLUMNWIDTH" "VLA-PUT-HORZCELLMARGIN" "VLA-GET-HORZCELLMARGIN" "VLA-PUT-VERTCELLMARGIN" "VLA-GET-VERTCELLMARGIN" "VLA-PUT-FLOWDIRECTION" "VLA-GET-FLOWDIRECTION" "VLA-PUT-ANGLEVERTEX" "VLA-GET-ANGLEVERTEX" "VLA-PUT-MLINESCALE" "VLA-GET-MLINESCALE" "VLA-PUT-JUSTIFICATION" "VLA-GET-JUSTIFICATION" "VLA-GET-NUMBEROFFACES" "VLA-GET-NUMBEROFVERTICES" "VLA-GET-ROWSPACING" "VLA-PUT-ROWSPACING" "VLA-GET-ROWS" "VLA-PUT-ROWS" "VLA-GET-COLUMNSPACING" "VLA-PUT-COLUMNSPACING" "VLA-GET-COLUMNS" "VLA-PUT-COLUMNS" "VLA-PUT-TABORDER" "VLA-GET-TABORDER" "VLA-GET-BLOCK" "VLA-GETLOCALEMEDIANAME" "VLA-REFRESHPLOTDEVICEINFO" "VLA-GETPLOTSTYLETABLENAMES" "VLA-GETPLOTDEVICENAMES" "VLA-GETCANONICALMEDIANAMES" "VLA-COPYFROM" "VLA-GET-MODELTYPE" "VLA-PUT-PLOTWITHPLOTSTYLES" "VLA-GET-PLOTWITHPLOTSTYLES" "VLA-SETWINDOWTOPLOT" "VLA-GETWINDOWTOPLOT" "VLA-PUT-PLOTORIGIN" "VLA-GET-PLOTORIGIN" "VLA-GETPAPERSIZE" "VLA-GETPAPERMARGINS" "VLA-PUT-STYLESHEET" "VLA-GET-STYLESHEET" "VLA-PUT-PLOTVIEWPORTSFIRST" "VLA-GET-PLOTVIEWPORTSFIRST" "VLA-PUT-PLOTWITHLINEWEIGHTS" "VLA-GET-PLOTWITHLINEWEIGHTS" "VLA-PUT-SCALELINEWEIGHTS" "VLA-GET-SCALELINEWEIGHTS" "VLA-SETCUSTOMSCALE" "VLA-GETCUSTOMSCALE" "VLA-PUT-STANDARDSCALE" "VLA-GET-STANDARDSCALE" "VLA-PUT-USESTANDARDSCALE" "VLA-GET-USESTANDARDSCALE" "VLA-PUT-VIEWTOPLOT" "VLA-GET-VIEWTOPLOT" "VLA-PUT-PLOTTYPE" "VLA-GET-PLOTTYPE" "VLA-PUT-PLOTHIDDEN" "VLA-GET-PLOTHIDDEN" "VLA-PUT-CENTERPLOT" "VLA-GET-CENTERPLOT" "VLA-PUT-PLOTROTATION" "VLA-GET-PLOTROTATION" "VLA-PUT-SHOWPLOTSTYLES" "VLA-GET-SHOWPLOTSTYLES" "VLA-PUT-PLOTVIEWPORTBORDERS" "VLA-GET-PLOTVIEWPORTBORDERS" "VLA-PUT-PAPERUNITS" "VLA-GET-PAPERUNITS" "VLA-PUT-CANONICALMEDIANAME" "VLA-GET-CANONICALMEDIANAME" "VLA-PUT-CONFIGNAME" "VLA-GET-CONFIGNAME" "VLA-GET-ANGLE" "VLA-GET-DELTA" "VLA-PUT-ENDPOINT" "VLA-PUT-STARTPOINT" "VLA-PUT-SHOWROTATION" "VLA-GET-SHOWROTATION" "VLA-CLIPBOUNDARY" "VLA-PUT-TRANSPARENCY" "VLA-GET-TRANSPARENCY" "VLA-PUT-CLIPPINGENABLED" "VLA-GET-CLIPPINGENABLED" "VLA-PUT-IMAGEVISIBILITY" "VLA-GET-IMAGEVISIBILITY" "VLA-GET-IMAGEFILE" "VLA-PUT-IMAGEFILE" "VLA-PUT-IMAGEHEIGHT" "VLA-GET-IMAGEHEIGHT" "VLA-PUT-IMAGEWIDTH" "VLA-GET-IMAGEWIDTH" "VLA-PUT-FADE" "VLA-GET-FADE" "VLA-PUT-CONTRAST" "VLA-GET-CONTRAST" "VLA-PUT-BRIGHTNESS" "VLA-GET-BRIGHTNESS" "VLA-PUT-HATCHOBJECTTYPE" "VLA-GET-HATCHOBJECTTYPE" "VLA-PUT-GRADIENTNAME" "VLA-GET-GRADIENTNAME" "VLA-PUT-GRADIENTCENTERED" "VLA-GET-GRADIENTCENTERED" "VLA-PUT-GRADIENTANGLE" "VLA-GET-GRADIENTANGLE" "VLA-PUT-GRADIENTCOLOR2" "VLA-GET-GRADIENTCOLOR2" "VLA-PUT-GRADIENTCOLOR1" "VLA-GET-GRADIENTCOLOR1" "VLA-GETLOOPAT" "VLA-INSERTLOOPAT" "VLA-APPENDINNERLOOP" "VLA-APPENDOUTERLOOP" "VLA-SETPATTERN" "VLA-PUT-HATCHSTYLE" "VLA-GET-HATCHSTYLE" "VLA-PUT-ASSOCIATIVEHATCH" "VLA-GET-ASSOCIATIVEHATCH" "VLA-PUT-PATTERNDOUBLE" "VLA-GET-PATTERNDOUBLE" "VLA-PUT-ISOPENWIDTH" "VLA-GET-ISOPENWIDTH" "VLA-PUT-PATTERNSPACE" "VLA-GET-PATTERNSPACE" "VLA-PUT-PATTERNSCALE" "VLA-GET-PATTERNSCALE" "VLA-PUT-PATTERNANGLE" "VLA-GET-PATTERNANGLE" "VLA-GET-PATTERNNAME" "VLA-GET-PATTERNTYPE" "VLA-GET-NUMBEROFLOOPS" "VLA-GET-INSUNITSFACTOR" "VLA-GET-INSUNITS" "VLA-PUT-ZEFFECTIVESCALEFACTOR" "VLA-GET-ZEFFECTIVESCALEFACTOR" "VLA-PUT-YEFFECTIVESCALEFACTOR" "VLA-GET-YEFFECTIVESCALEFACTOR" "VLA-PUT-XEFFECTIVESCALEFACTOR" "VLA-GET-XEFFECTIVESCALEFACTOR" "VLA-CONVERTTOSTATICBLOCK" "VLA-CONVERTTOANONYMOUSBLOCK" "VLA-RESETBLOCK" "VLA-GETDYNAMICBLOCKPROPERTIES" "VLA-GET-EFFECTIVENAME" "VLA-GET-HASATTRIBUTES" "VLA-GETCONSTANTATTRIBUTES" "VLA-GETATTRIBUTES" "VLA-PUT-ZSCALEFACTOR" "VLA-GET-ZSCALEFACTOR" "VLA-PUT-YSCALEFACTOR" "VLA-GET-YSCALEFACTOR" "VLA-PUT-XSCALEFACTOR" "VLA-GET-XSCALEFACTOR" "VLA-PUT-WEIGHTS" "VLA-GET-WEIGHTS" "VLA-PUT-KNOTS" "VLA-GET-KNOTS" "VLA-REVERSE" "VLA-PURGEFITDATA" "VLA-ELEVATEORDER" "VLA-DELETEFITPOINT" "VLA-ADDFITPOINT" "VLA-GETWEIGHT" "VLA-SETWEIGHT" "VLA-GETFITPOINT" "VLA-SETFITPOINT" "VLA-GETCONTROLPOINT" "VLA-SETCONTROLPOINT" "VLA-PUT-FITTOLERANCE" "VLA-GET-FITTOLERANCE" "VLA-PUT-ENDTANGENT" "VLA-GET-ENDTANGENT" "VLA-PUT-STARTTANGENT" "VLA-GET-STARTTANGENT" "VLA-GET-ISPERIODIC" "VLA-GET-ISRATIONAL" "VLA-GET-ISPLANAR" "VLA-GET-DEGREE" "VLA-PUT-FITPOINTS" "VLA-GET-FITPOINTS" "VLA-GET-NUMBEROFFITPOINTS" "VLA-PUT-CONTROLPOINTS" "VLA-GET-CONTROLPOINTS" "VLA-GET-NUMBEROFCONTROLPOINTS" "VLA-PUT-DIRECTIONVECTOR" "VLA-GET-DIRECTIONVECTOR" "VLA-PUT-SECONDPOINT" "VLA-GET-SECONDPOINT" "VLA-PUT-BASEPOINT" "VLA-GET-BASEPOINT" "VLA-PUT-LINETYPEGENERATION" "VLA-GET-LINETYPEGENERATION" "VLA-PUT-ELEVATION" "VLA-GET-ELEVATION" "VLA-PUT-CONSTANTWIDTH" "VLA-GET-CONSTANTWIDTH" "VLA-SETWIDTH" "VLA-GETWIDTH" "VLA-SETBULGE" "VLA-GETBULGE" "VLA-ADDVERTEX" "VLA-FIELDCODE" "VLA-PUT-BACKGROUNDFILL" "VLA-GET-BACKGROUNDFILL" "VLA-PUT-LINESPACINGDISTANCE" "VLA-GET-LINESPACINGDISTANCE" "VLA-PUT-LINESPACINGSTYLE" "VLA-GET-LINESPACINGSTYLE" "VLA-PUT-LINESPACINGFACTOR" "VLA-GET-LINESPACINGFACTOR" "VLA-PUT-WIDTH" "VLA-GET-WIDTH" "VLA-PUT-DRAWINGDIRECTION" "VLA-GET-DRAWINGDIRECTION" "VLA-PUT-ATTACHMENTPOINT" "VLA-GET-ATTACHMENTPOINT" "VLA-PUT-ANNOTATION" "VLA-GET-ANNOTATION" "VLA-EVALUATE" "VLA-GET-MINORAXIS" "VLA-PUT-MAJORAXIS" "VLA-GET-MAJORAXIS" "VLA-PUT-ENDPARAMETER" "VLA-GET-ENDPARAMETER" "VLA-PUT-STARTPARAMETER" "VLA-GET-STARTPARAMETER" "VLA-PUT-RADIUSRATIO" "VLA-GET-RADIUSRATIO" "VLA-PUT-MINORRADIUS" "VLA-GET-MINORRADIUS" "VLA-PUT-MAJORRADIUS" "VLA-GET-MAJORRADIUS" "VLA-PUT-ARROWHEADBLOCK" "VLA-GET-ARROWHEADBLOCK" "VLA-PUT-ARROWHEADTYPE" "VLA-GET-ARROWHEADTYPE" "VLA-PUT-DIMLINESUPPRESS" "VLA-GET-DIMLINESUPPRESS" "VLA-PUT-CENTERMARKSIZE" "VLA-GET-CENTERMARKSIZE" "VLA-PUT-CENTERTYPE" "VLA-GET-CENTERTYPE" "VLA-PUT-LEADERLENGTH" "VLA-PUT-TEXTPRECISION" "VLA-GET-TEXTPRECISION" "VLA-PUT-ANGLEFORMAT" "VLA-GET-ANGLEFORMAT" "VLA-PUT-EXTLINE2ENDPOINT" "VLA-GET-EXTLINE2ENDPOINT" "VLA-PUT-EXTLINE2STARTPOINT" "VLA-GET-EXTLINE2STARTPOINT" "VLA-PUT-EXTLINE1ENDPOINT" "VLA-GET-EXTLINE1ENDPOINT" "VLA-PUT-EXTLINE1STARTPOINT" "VLA-GET-EXTLINE1STARTPOINT" "VLA-PUT-ALTSUBUNITSFACTOR" "VLA-GET-ALTSUBUNITSFACTOR" "VLA-PUT-ALTSUBUNITSSUFFIX" "VLA-GET-ALTSUBUNITSSUFFIX" "VLA-PUT-SUBUNITSFACTOR" "VLA-GET-SUBUNITSFACTOR" "VLA-PUT-SUBUNITSSUFFIX" "VLA-GET-SUBUNITSSUFFIX" "VLA-PUT-DIMCONSTRDESC" "VLA-GET-DIMCONSTRDESC" "VLA-PUT-DIMCONSTRVALUE" "VLA-GET-DIMCONSTRVALUE" "VLA-PUT-DIMCONSTREXPRESSION" "VLA-GET-DIMCONSTREXPRESSION" "VLA-PUT-DIMCONSTRNAME" "VLA-GET-DIMCONSTRNAME" "VLA-PUT-DIMCONSTRREFERENCE" "VLA-GET-DIMCONSTRREFERENCE" "VLA-PUT-DIMCONSTRFORM" "VLA-GET-DIMCONSTRFORM" "VLA-PUT-EXTLINEFIXEDLEN" "VLA-GET-EXTLINEFIXEDLEN" "VLA-PUT-EXTLINEFIXEDLENSUPPRESS" "VLA-GET-EXTLINEFIXEDLENSUPPRESS" "VLA-PUT-EXTLINE2LINETYPE" "VLA-GET-EXTLINE2LINETYPE" "VLA-PUT-EXTLINE1LINETYPE" "VLA-GET-EXTLINE1LINETYPE" "VLA-PUT-DIMENSIONLINETYPE" "VLA-GET-DIMENSIONLINETYPE" "VLA-PUT-ARROWHEAD2BLOCK" "VLA-GET-ARROWHEAD2BLOCK" "VLA-PUT-ARROWHEAD1BLOCK" "VLA-GET-ARROWHEAD1BLOCK" "VLA-GET-MEASUREMENT" "VLA-PUT-ARROWHEAD2TYPE" "VLA-GET-ARROWHEAD2TYPE" "VLA-PUT-ARROWHEAD1TYPE" "VLA-GET-ARROWHEAD1TYPE" "VLA-PUT-ARROWHEADSIZE" "VLA-GET-ARROWHEADSIZE" "VLA-PUT-DIMENSIONLINEWEIGHT" "VLA-GET-DIMENSIONLINEWEIGHT" "VLA-PUT-TOLERANCESUPPRESSZEROINCHES" "VLA-GET-TOLERANCESUPPRESSZEROINCHES" "VLA-PUT-TOLERANCESUPPRESSZEROFEET" "VLA-GET-TOLERANCESUPPRESSZEROFEET" "VLA-PUT-SUPPRESSZEROINCHES" "VLA-GET-SUPPRESSZEROINCHES" "VLA-PUT-SUPPRESSZEROFEET" "VLA-GET-SUPPRESSZEROFEET" "VLA-PUT-ALTTOLERANCESUPPRESSZEROINCHES" "VLA-GET-ALTTOLERANCESUPPRESSZEROINCHES" "VLA-PUT-ALTTOLERANCESUPPRESSZEROFEET" "VLA-GET-ALTTOLERANCESUPPRESSZEROFEET" "VLA-PUT-ALTTOLERANCESUPPRESSTRAILINGZEROS" "VLA-GET-ALTTOLERANCESUPPRESSTRAILINGZEROS" "VLA-PUT-ALTTOLERANCESUPPRESSLEADINGZEROS" "VLA-GET-ALTTOLERANCESUPPRESSLEADINGZEROS" "VLA-PUT-ALTSUPPRESSZEROINCHES" "VLA-GET-ALTSUPPRESSZEROINCHES" "VLA-PUT-ALTSUPPRESSZEROFEET" "VLA-GET-ALTSUPPRESSZEROFEET" "VLA-PUT-ALTSUPPRESSTRAILINGZEROS" "VLA-GET-ALTSUPPRESSTRAILINGZEROS" "VLA-PUT-ALTSUPPRESSLEADINGZEROS" "VLA-GET-ALTSUPPRESSLEADINGZEROS" "VLA-PUT-EXTENSIONLINEOFFSET" "VLA-GET-EXTENSIONLINEOFFSET" "VLA-PUT-TEXTOUTSIDEALIGN" "VLA-GET-TEXTOUTSIDEALIGN" "VLA-PUT-FORCELINEINSIDE" "VLA-GET-FORCELINEINSIDE" "VLA-PUT-TEXTINSIDE" "VLA-GET-TEXTINSIDE" "VLA-PUT-TEXTINSIDEALIGN" "VLA-GET-TEXTINSIDEALIGN" "VLA-PUT-DIMLINEINSIDE" "VLA-GET-DIMLINEINSIDE" "VLA-PUT-EXTLINE2SUPPRESS" "VLA-GET-EXTLINE2SUPPRESS" "VLA-PUT-EXTLINE1SUPPRESS" "VLA-GET-EXTLINE1SUPPRESS" "VLA-PUT-DIMLINE2SUPPRESS" "VLA-GET-DIMLINE2SUPPRESS" "VLA-PUT-DIMLINE1SUPPRESS" "VLA-GET-DIMLINE1SUPPRESS" "VLA-PUT-ROUNDDISTANCE" "VLA-GET-ROUNDDISTANCE" "VLA-PUT-EXTENSIONLINEWEIGHT" "VLA-GET-EXTENSIONLINEWEIGHT" "VLA-PUT-UNITSFORMAT" "VLA-GET-UNITSFORMAT" "VLA-PUT-LINEARSCALEFACTOR" "VLA-GET-LINEARSCALEFACTOR" "VLA-PUT-HORIZONTALTEXTPOSITION" "VLA-GET-HORIZONTALTEXTPOSITION" "VLA-PUT-FRACTIONFORMAT" "VLA-GET-FRACTIONFORMAT" "VLA-PUT-FIT" "VLA-GET-FIT" "VLA-PUT-EXTENSIONLINEEXTEND" "VLA-GET-EXTENSIONLINEEXTEND" "VLA-PUT-DIMENSIONLINEEXTEND" "VLA-GET-DIMENSIONLINEEXTEND" "VLA-PUT-PRIMARYUNITSPRECISION" "VLA-GET-PRIMARYUNITSPRECISION" "VLA-PUT-EXTENSIONLINECOLOR" "VLA-GET-EXTENSIONLINECOLOR" "VLA-PUT-DIMENSIONLINECOLOR" "VLA-GET-DIMENSIONLINECOLOR" "VLA-PUT-ALTTEXTSUFFIX" "VLA-GET-ALTTEXTSUFFIX" "VLA-PUT-ALTTEXTPREFIX" "VLA-GET-ALTTEXTPREFIX" "VLA-PUT-ALTUNITSFORMAT" "VLA-GET-ALTUNITSFORMAT" "VLA-PUT-ALTTOLERANCEPRECISION" "VLA-GET-ALTTOLERANCEPRECISION" "VLA-PUT-ALTROUNDDISTANCE" "VLA-GET-ALTROUNDDISTANCE" "VLA-PUT-ALTUNITSSCALE" "VLA-GET-ALTUNITSSCALE" "VLA-PUT-ALTUNITSPRECISION" "VLA-GET-ALTUNITSPRECISION" "VLA-PUT-ALTUNITS" "VLA-GET-ALTUNITS" "VLA-PUT-EXTLINE2POINT" "VLA-GET-EXTLINE2POINT" "VLA-PUT-EXTLINE1POINT" "VLA-GET-EXTLINE1POINT" "VLA-PUT-TEXTFILLCOLOR" "VLA-GET-TEXTFILLCOLOR" "VLA-PUT-TEXTFILL" "VLA-GET-TEXTFILL" "VLA-PUT-TOLERANCESUPPRESSTRAILINGZEROS" "VLA-GET-TOLERANCESUPPRESSTRAILINGZEROS" "VLA-PUT-TOLERANCESUPPRESSLEADINGZEROS" "VLA-GET-TOLERANCESUPPRESSLEADINGZEROS" "VLA-PUT-SUPPRESSTRAILINGZEROS" "VLA-GET-SUPPRESSTRAILINGZEROS" "VLA-PUT-SUPPRESSLEADINGZEROS" "VLA-GET-SUPPRESSLEADINGZEROS" "VLA-PUT-TEXTHEIGHT" "VLA-GET-TEXTHEIGHT" "VLA-PUT-TEXTSTYLE" "VLA-GET-TEXTSTYLE" "VLA-PUT-TOLERANCEUPPERLIMIT" "VLA-GET-TOLERANCEUPPERLIMIT" "VLA-PUT-TOLERANCEJUSTIFICATION" "VLA-GET-TOLERANCEJUSTIFICATION" "VLA-PUT-TOLERANCEDISPLAY" "VLA-GET-TOLERANCEDISPLAY" "VLA-PUT-TEXTMOVEMENT" "VLA-GET-TEXTMOVEMENT" "VLA-PUT-TOLERANCELOWERLIMIT" "VLA-GET-TOLERANCELOWERLIMIT" "VLA-PUT-TOLERANCEHEIGHTSCALE" "VLA-GET-TOLERANCEHEIGHTSCALE" "VLA-PUT-TOLERANCEPRECISION" "VLA-GET-TOLERANCEPRECISION" "VLA-PUT-VERTICALTEXTPOSITION" "VLA-GET-VERTICALTEXTPOSITION" "VLA-PUT-TEXTSUFFIX" "VLA-GET-TEXTSUFFIX" "VLA-PUT-TEXTPREFIX" "VLA-GET-TEXTPREFIX" "VLA-PUT-TEXTGAP" "VLA-GET-TEXTGAP" "VLA-PUT-DECIMALSEPARATOR" "VLA-GET-DECIMALSEPARATOR" "VLA-PUT-TEXTCOLOR" "VLA-GET-TEXTCOLOR" "VLA-PUT-TEXTOVERRIDE" "VLA-GET-TEXTOVERRIDE" "VLA-PUT-TEXTROTATION" "VLA-GET-TEXTROTATION" "VLA-PUT-TEXTPOSITION" "VLA-GET-TEXTPOSITION" "VLA-PUT-AREA" "VLA-PUT-CIRCUMFERENCE" "VLA-GET-CIRCUMFERENCE" "VLA-PUT-DIAMETER" "VLA-GET-DIAMETER" "VLA-GET-PERIMETER" "VLA-PUT-SHOWHISTORY" "VLA-GET-SHOWHISTORY" "VLA-PUT-HISTORY" "VLA-GET-HISTORY" "VLA-PUT-POSITION" "VLA-GET-POSITION" "VLA-GET-SOLIDTYPE" "VLA-SLICESOLID" "VLA-SECTIONSOLID" "VLA-CHECKINTERFERENCE" "VLA-BOOLEAN" "VLA-GET-VOLUME" "VLA-GET-RADIIOFGYRATION" "VLA-GET-PRODUCTOFINERTIA" "VLA-GET-PRINCIPALMOMENTS" "VLA-GET-PRINCIPALDIRECTIONS" "VLA-GET-MOMENTOFINERTIA" "VLA-GET-CENTROID" "VLA-PUT-MTEXTDRAWINGDIRECTION" "VLA-GET-MTEXTDRAWINGDIRECTION" "VLA-PUT-MTEXTBOUNDARYWIDTH" "VLA-GET-MTEXTBOUNDARYWIDTH" "VLA-UPDATEMTEXTATTRIBUTE" "VLA-PUT-MTEXTATTRIBUTECONTENT" "VLA-GET-MTEXTATTRIBUTECONTENT" "VLA-PUT-MTEXTATTRIBUTE" "VLA-GET-MTEXTATTRIBUTE" "VLA-PUT-LOCKPOSITION" "VLA-GET-LOCKPOSITION" "VLA-PUT-PRESET" "VLA-GET-PRESET" "VLA-PUT-VERIFY" "VLA-GET-VERIFY" "VLA-PUT-CONSTANT" "VLA-GET-CONSTANT" "VLA-PUT-INVISIBLE" "VLA-GET-INVISIBLE" "VLA-PUT-BACKWARD" "VLA-GET-BACKWARD" "VLA-PUT-UPSIDEDOWN" "VLA-GET-UPSIDEDOWN" "VLA-PUT-MODE" "VLA-GET-MODE" "VLA-PUT-TEXTGENERATIONFLAG" "VLA-GET-TEXTGENERATIONFLAG" "VLA-PUT-INSERTIONPOINT" "VLA-GET-INSERTIONPOINT" "VLA-PUT-TEXTALIGNMENTPOINT" "VLA-GET-TEXTALIGNMENTPOINT" "VLA-PUT-OBLIQUEANGLE" "VLA-GET-OBLIQUEANGLE" "VLA-PUT-SCALEFACTOR" "VLA-GET-SCALEFACTOR" "VLA-PUT-ROTATION" "VLA-GET-ROTATION" "VLA-PUT-HEIGHT" "VLA-GET-HEIGHT" "VLA-PUT-ALIGNMENT" "VLA-GET-ALIGNMENT" "VLA-PUT-STYLENAME" "VLA-GET-STYLENAME" "VLA-PUT-TEXTSTRING" "VLA-GET-TEXTSTRING" "VLA-PUT-PROMPTSTRING" "VLA-GET-PROMPTSTRING" "VLA-PUT-TAGSTRING" "VLA-GET-TAGSTRING" "VLA-PUT-FIELDLENGTH" "VLA-GET-FIELDLENGTH" "VLA-PUT-NORMAL" "VLA-GET-NORMAL" "VLA-GET-AREA" "VLA-OFFSET" "VLA-PUT-THICKNESS" "VLA-GET-THICKNESS" "VLA-GET-ARCLENGTH" "VLA-GET-TOTALANGLE" "VLA-PUT-ENDANGLE" "VLA-GET-ENDANGLE" "VLA-PUT-STARTANGLE" "VLA-GET-STARTANGLE" "VLA-PUT-RADIUS" "VLA-GET-RADIUS" "VLA-GET-ENDPOINT" "VLA-PUT-CENTER" "VLA-GET-CENTER" "VLA-GET-STARTPOINT" "VLA-GET-LENGTH" "VLA-PUT-CLOSED" "VLA-GET-CLOSED" "VLA-EXPLODE" "VLA-APPENDVERTEX" "VLA-PUT-TYPE" "VLA-GET-TYPE" "VLA-GET-NVERTEXCOUNT" "VLA-GET-MVERTEXCOUNT" "VLA-PUT-NDENSITY" "VLA-GET-NDENSITY" "VLA-PUT-MDENSITY" "VLA-GET-MDENSITY" "VLA-PUT-NCLOSE" "VLA-GET-NCLOSE" "VLA-PUT-MCLOSE" "VLA-GET-MCLOSE" "VLA-PUT-COORDINATE" "VLA-GET-COORDINATE" "VLA-SETINVISIBLEEDGE" "VLA-GETINVISIBLEEDGE" "VLA-PUT-VISIBILITYEDGE4" "VLA-GET-VISIBILITYEDGE4" "VLA-PUT-VISIBILITYEDGE3" "VLA-GET-VISIBILITYEDGE3" "VLA-PUT-VISIBILITYEDGE2" "VLA-GET-VISIBILITYEDGE2" "VLA-PUT-VISIBILITYEDGE1" "VLA-GET-VISIBILITYEDGE1" "VLA-PUT-COORDINATES" "VLA-GET-COORDINATES" "VLA-GET-URLNAMEDLOCATION" "VLA-PUT-URLNAMEDLOCATION" "VLA-GET-URLDESCRIPTION" "VLA-PUT-URLDESCRIPTION" "VLA-GET-URL" "VLA-PUT-URL" "VLA-ADD" "VLA-SETCOLORBOOKCOLOR" "VLA-PUT-COLORINDEX" "VLA-GET-COLORINDEX" "VLA-GET-COLORMETHOD" "VLA-PUT-COLORMETHOD" "VLA-SETRGB" "VLA-GET-GREEN" "VLA-GET-BLUE" "VLA-GET-RED" "VLA-SETNAMES" "VLA-GET-BOOKNAME" "VLA-GET-COLORNAME" "VLA-GET-ENTITYCOLOR" "VLA-PUT-ENTITYCOLOR" "VLA-PUT-MATERIAL" "VLA-GET-MATERIAL" "VLA-GET-HYPERLINKS" "VLA-PUT-LINEWEIGHT" "VLA-GET-LINEWEIGHT" "VLA-PUT-PLOTSTYLENAME" "VLA-GET-PLOTSTYLENAME" "VLA-INTERSECTWITH" "VLA-GETBOUNDINGBOX" "VLA-UPDATE" "VLA-TRANSFORMBY" "VLA-SCALEENTITY" "VLA-MIRROR3D" "VLA-MIRROR" "VLA-ROTATE3D" "VLA-ROTATE" "VLA-MOVE" "VLA-COPY" "VLA-HIGHLIGHT" "VLA-ARRAYRECTANGULAR" "VLA-ARRAYPOLAR" "VLA-PUT-VISIBLE" "VLA-GET-VISIBLE" "VLA-PUT-LINETYPESCALE" "VLA-GET-LINETYPESCALE" "VLA-PUT-LINETYPE" "VLA-GET-LINETYPE" "VLA-PUT-LAYER" "VLA-GET-LAYER" "VLA-PUT-TRUECOLOR" "VLA-GET-TRUECOLOR" "VLA-ADDEMBEDDEDRASTER" "VLA-ADDMLEADER" "VLA-ADDSECTION" "VLA-ADDDIMRADIALLARGE" "VLA-ADDDIMARC" "VLA-GET-ISDYNAMICBLOCK" "VLA-PUT-BLOCKSCALING" "VLA-GET-BLOCKSCALING" "VLA-PUT-EXPLODABLE" "VLA-GET-EXPLODABLE" "VLA-PUT-UNITS" "VLA-GET-UNITS" "VLA-PUT-COMMENTS" "VLA-GET-COMMENTS" "VLA-PUT-PATH" "VLA-GET-PATH" "VLA-ADDTABLE" "VLA-DETACH" "VLA-BIND" "VLA-RELOAD" "VLA-UNLOAD" "VLA-ATTACHEXTERNALREFERENCE" "VLA-GET-XREFDATABASE" "VLA-ADDDIM3POINTANGULAR" "VLA-ADDMLINE" "VLA-ADDPOLYFACEMESH" "VLA-ADDMINSERTBLOCK" "VLA-GET-ISXREF" "VLA-GET-LAYOUT" "VLA-GET-ISLAYOUT" "VLA-ADDLINE" "VLA-ADDRASTER" "VLA-ADDHATCH" "VLA-INSERTBLOCK" "VLA-ADDXLINE" "VLA-ADDWEDGE" "VLA-ADDTRACE" "VLA-ADDTORUS" "VLA-ADDTOLERANCE" "VLA-ADDTEXT" "VLA-ADDSPLINE" "VLA-ADDSPHERE" "VLA-ADDSOLID" "VLA-ADDSHAPE" "VLA-ADDREVOLVEDSOLID" "VLA-ADDREGION" "VLA-ADDRAY" "VLA-ADDPOLYLINE" "VLA-ADDLIGHTWEIGHTPOLYLINE" "VLA-ADDPOINT" "VLA-ADDMTEXT" "VLA-ADDLEADER" "VLA-ADDEXTRUDEDSOLIDALONGPATH" "VLA-ADDEXTRUDEDSOLID" "VLA-ADDELLIPTICALCYLINDER" "VLA-ADDELLIPTICALCONE" "VLA-ADDELLIPSE" "VLA-ADDDIMRADIAL" "VLA-ADDDIMORDINATE" "VLA-ADDDIMROTATED" "VLA-ADDDIMDIAMETRIC" "VLA-ADDDIMANGULAR" "VLA-ADDDIMALIGNED" "VLA-ADDCYLINDER" "VLA-ADDCONE" "VLA-ADDCIRCLE" "VLA-ADDBOX" "VLA-ADDATTRIBUTE" "VLA-ADDARC" "VLA-ADD3DPOLY" "VLA-ADD3DMESH" "VLA-ADD3DFACE" "VLA-ADDCUSTOMOBJECT" "VLA-PUT-ORIGIN" "VLA-GET-ORIGIN" "VLA-PUT-NAME" "VLA-GET-NAME" "VLA-GET-COUNT" "VLA-ITEM" "VLA-GET-MATERIALS" "VLA-GET-SECTIONMANAGER" "VLA-GET-SUMMARYINFO" "VLA-GET-FILEDEPENDENCIES" "VLA-GET-PREFERENCES" "VLA-GET-PLOTCONFIGURATIONS" "VLA-GET-LAYOUTS" "VLA-OBJECTIDTOOBJECT" "VLA-HANDLETOOBJECT" "VLA-PUT-LIMITS" "VLA-GET-LIMITS" "VLA-PUT-ELEVATIONPAPERSPACE" "VLA-GET-ELEVATIONPAPERSPACE" "VLA-PUT-ELEVATIONMODELSPACE" "VLA-GET-ELEVATIONMODELSPACE" "VLA-GET-VIEWPORTS" "VLA-GET-VIEWS" "VLA-GET-USERCOORDINATESYSTEMS" "VLA-GET-TEXTSTYLES" "VLA-GET-REGISTEREDAPPLICATIONS" "VLA-GET-DICTIONARIES" "VLA-GET-LINETYPES" "VLA-GET-LAYERS" "VLA-GET-DIMSTYLES" "VLA-GET-GROUPS" "VLA-COPYOBJECTS" "VLA-GET-BLOCKS" "VLA-GET-PAPERSPACE" "VLA-GET-MODELSPACE" "VLA-GET-DOCUMENT" "VLA-GET-OWNERID" "VLA-GETEXTENSIONDICTIONARY" "VLA-GET-HASEXTENSIONDICTIONARY" "VLA-GET-APPLICATION" "VLA-GET-OBJECTID" "VLA-DELETE" "VLA-SETXDATA" "VLA-GETXDATA" "VLA-GET-OBJECTNAME" "VLA-GET-HANDLE")
