mjab8 Posted September 22, 2021 Share Posted September 22, 2021 This attribute is Area field of closed polyline, then follow with the text suffix. Eg. 15.3m2 (AT). I want to get the areas sum of all selected into a table (as field). Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 22, 2021 Share Posted September 22, 2021 It would probably be simplest to go back a step and use the direct fields of the pline areas and not the attribute in your table. Quote Link to comment Share on other sites More sharing options...
mjab8 Posted September 22, 2021 Share Posted September 22, 2021 Thanks Bigal but there are too many to go back. There are many in a dwg and many dwgs and also it's our standards. Example as Dwg attached (simplified and much smaller size) are 10 areas I wish to sum up and output onto a table in the dwg. Ignore the table on top right corner, it's just a table example that was manually created. AreaG.dwg Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 22, 2021 Share Posted September 22, 2021 Srory can not help "also it's our standards." that includes student version ? Quote Link to comment Share on other sites More sharing options...
mjab8 Posted September 23, 2021 Share Posted September 23, 2021 How about a routine to erase all area attribute suffix? Quote Link to comment Share on other sites More sharing options...
