i need create two points at either side of a line at once.
(setq L1(entsel "Get Line:"))
(setq enL1(entget(entlast)))
		 (setq ptL1STT  (cdr (assoc 10 enL1)))
                  (setq ptL1END  (cdr (assoc 11 enL1)))
(setq aa (angle (cdr (assoc 10 enL1))
                           (cdr (assoc 11 enL1)));angle
		 );setq
                 (setq dd (distance (cdr (assoc 10 enL1))
                              (cdr (assoc 11 enL1)));distance
           );setq
(setq midpnt(polar ptL1STT aa (/ dd 2)))
 (setq p1 (polar midpnt (+   aa (/ pi 4)) 1.0)
                   		     );setq
(setq L2(command "offset" 1.0  L1 p1""))
From above code, i can make one offset line at one side. now i need create another offset line at opposite side.
Can i get correct code for above. Thank you in advance.
		 );setq
           );setq
                   		     );setq
Are you trying to offset the original line 1 unit at 90 degrees or through point p1 which is 1 unit from the midpoint at 45 degrees (/ pi 4 is 45 degrees) ?
Edited by dlanorh
I just want to image.png.af0bed5c0bbca6fc90a4a452069274c4.png two offset lines at either side of a line.
(if (< (/ pi 2) aa (* pi 1.5));less than
              (setq sttp1 (cdr (assoc 11 enL1))
                     aa (rem (+ aa pi)(* pi 2))
		     );setq
	       (setq sttp1 (cdr (assoc 10 enL1))));if
	   (setq midpnt(polar sttp1 aa (/ dd 2)))
I used above code to solve the problem. now all ok. thankyou again for helping me.
On 4/26/2020 at 9:50 AM, Dhammike said:
(setq x ptlst)
(setq lst(mapcar '(lambda ( x ) (read (strcat "(" (vl-string-translate "," " " x) ")"))) lst))
(princ lst)
 (setq ss4 (ssget "_WP" lst (list (cons 0 "*Text"))))
(setq i (1 - i))
(setq en (ssname ss2 (setq k (1 + k))))
(setq ent (entget en))
I used above code and i got below results.
("426982.418,511619.699" "426974.535,511603.142" "426964.041,511609.123" "426954.742,511612.095" "426946.029,511615.082" "426950.240,511625.283" "426955.404,511635.795" "426959.956,511644.578" "426970.869,511642.286" "426979.196,511640.264" "426985.400,511638.352" "426990.116,511635.794")
nil nil
nil
; error: too many arguments
_$
Still my problem not solved. thank you for helping me.  I am waiting for your answer.
		     );setq
Look at these. They all work in AutoCAD Windows version. There may be a problem with the last one if you are not running windows
;; THIS IS YOUR CODE. I'VE CHANGED THE VARIABLE NAMES TO BETTER REFLECT WHAT EACH VARIABLE IS
;; AT THE END ARE TWO WAYS YOU CAN OFFSET EITHER SIDE USING THE TWO POINTS
(defun c:doff ( / ent elst spt ept ang dd mpt p1 p2)
  (while (not ent)
    (setq ent (car (entsel "Get Line:"))
          elst (entget ent)
    (if (/= (cdr (assoc 0 elst)) "LINE") (setq ent nil))
  );end_while
  (setq spt (cdr (assoc 10 elst))
        ept (cdr (assoc 11 elst))
        ang (angle spt ept)
        dd  (* (distance spt ept) 0.5)
        mpt (polar spt ang (/ dd 2.0))
        p1 (polar mpt (+ ang (* pi 0.25)) 1.0)
        p2 (polar mpt (- ang (* pi 0.25)) 1.0)
  (foreach pt (list p1 p2) (command "offset"  1.0 ent pt ""))
  ;(command "offset" 1.0 ent p1 ent p2 "")
;; THIS IS YOUR CODE BUT OPTIMISED SLIGHTLY. YOU DON'T NEED TO FIND THE MID POINT
;; AS EVERYTHING CAN BE DONE FROM THE START POINT OF THE LINE
(defun c:doff ( / ent elst spt ang p1 p2)
  (while (not ent)
          elst (entget ent)
  );end_while
        ang (angle spt ept)
        p1 (polar spt (+ ang (* pi 0.5)) 1.0)
        p2 (polar spt (- ang (* pi 0.5)) 1.0)
;; AS YOU PROGRESS YOU WILL FIND THAT THIS IS AN EASIER WAY TO DO THIS
;; THIS IS A SELECTION SET WHERE ONLY ONE ITEM CAN BE SELECTED, BUT
;; IF YOU REMOVE "_+.:E:S" AND LEAVE ":L" YOU CAN SELECT AND OFFSET
;; MULTIPLE LINES ON UNLOCKED LAYERS
(defun c:doff ( / dd ss obj)
  (vl-load-com)
  (initget 7)
  (setq dd (getreal "\nEnter Offset Distance : "))
  (prompt "Select Entity to Offset : ")
  (setq ss (ssget "_+.:E:S:L" '((0 . "LINE"))))
  (cond (ss
          (setq obj (vlax-ename->vla-object (ssname ss 0)))
          (foreach d (list dd (* dd -1.0)) (vlax-invoke obj 'offset d))
  (while (not ent)
          elst (entget ent)
  );end_while
        ang (angle spt ept)
  (while (not ent)
          elst (entget ent)
  );end_while
        ang (angle spt ept)
  (vl-load-com)
  (initget 7)
  (cond (ss
Thank you very much.
A quiker way is using Vla-offset it supports direct +ve and -ve values so get a left and right.
Like others I have some offset routines so for both sides the request would be 1,-1 this would do 2 lines -1,1,2,-2 would do 4 lines can be any number all +ve or a mix.
An example of vla-offset, as mentioned will not work on MAC
(setq obj (vlax-ename->vla-object (car (entsel "Pick object "))))
(while (setq x (getreal "\nEnter offset -ve ok Enter to exit"))
(vla-offset obj x)
Edited by BIGAL
