Phamyen Posted May 14, 2020 Posted May 14, 2020 The selection box is not arranged in any order you can choose by pline or text (ordinal number) in Figure 1 b1: type command b2: scan by pline or text b3: select the print rate (500,1000,2000,5000 ..) b4: select a frame (if any) b5: enter the space between the layout side frames - If you have arranged in order, then automatically numbered (or pline ...) Figure 2 code : (defun C:mtll() (command "UNDO" "BE") (setvar "OSMODE" 0) (setq taphop(ssget)) (if (= Tyle nil) (setq Tyle1 1) (setq Tyle1 Tyle)) (setq Tyle (getreal (strcat "\n Ty le: <" (rtos Tyle1 2 0) "> "))) (if (= Tyle nil) (setq Tyle Tyle1)) (setq soluong (sslength taphop)) (setq index 0) (setq i 0) (setq ten (getstring "\n Nhap ten layout:")) (command "layout" "N" ten) (command "LAYOUT" "S" ten) (command "ERASE" "ALL" "") (command "MODEL") (setq X 0) (command "ZOOM" "E") (while (< index soluong) (setq i(1+ i)) (setq khung(ssname taphop index)) (setq lst(acet-geom-vertex-list khung)) (command "COPYCLIP" khung "") (command "LAYOUT" "S" ten) (command "PASTECLIP" (list X 0)) (command "SCALE" (entlast) "" (list X 0) (/ 1 tyle)) (command "MVIEW" "O" (entlast)) (command "MSPACE") (command "ZOOM" (nth 0 lst) (nth 2 lst)) (command "PSPACE") (setq X(+ X 300.5607 (/ (abs(- (car (nth 2 lst)) (car (nth 0 lst)))) tyle))) (command "ZOOM" "W" (list 0 0) (list (+ X 100) 0)) (setq index (+ index 1)) ) (command "MODEL") (command "UNDO" "END") (setvar "OSMODE" 15359) (princ) ) (I can't speak English to use google translate Sorry if bothered) aaa.dwg Quote
