Hello all,
I need some help with extracting the block properties using vlax function.
After doing some research I found this, for eg: to extract the block insertion point -
(vlax-get (vlax-ename->vla-object (car (entsel "\nSelect object: "))) 'InsertionPoint)
But if I tried to extract the block scale value using the same logic like this ,it is giving error
(vlax-get (vlax-ename->vla-object (car (entsel "\nSelect object: "))) 'Scale)
Here is the error which I got
Select object: ; error: ActiveX Server returned the error: unknown name: "SCALE"
So can somebody help me out in extracting the block scale value using the vlax function?
Also, what is the difference between "vlax-get" and "vlax-get-property" ?
Thanks
If using VL recommend using dumpit.lsp so can see properties there are though different methods available to get the same answer as posted by rlx
: DUMPIT
Select entity:
; IAcadBlockReference 36ce68e0 : TeighaX Interface of an instance of a block definition inserted into a drawing
; Property values :
;   Application (RO) = #<VLA-OBJECT IAcadApplication 00000000296C9D30>
;   color = 256
;   Database (RO) = #<VLA-OBJECT IAcadDatabase 000000005DD1AED8>
;   Document (RO) = #<VLA-OBJECT IAcadDocument 0000000029A630E8>
;   EffectiveName (RO) = "aaa"
;   EntityName (RO) = "AcDbBlockReference"
;   EntityType (RO) = NIL
;   Handle (RO) = "A4"
;   HasAttributes (RO) = 0
;   HasExtensionDictionary (RO) = 0
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 0000000036892228>
;   InsertionPoint = (274.0 216.0 0.0)
;   InsUnits (RO) = "Meters"
;   InsUnitsFactor (RO) = 1.0
;   IsDynamicBlock (RO) = 0
;   Layer = "0"
;   Linetype = "ByLayer"
;   LinetypeScale = 1.0
;   Lineweight = -1
;   Material = "ByLayer"
;   Name = "aaa"
;   Normal = (0.0 0.0 1.0)
;   ObjectID (RO) = 1573934064
;   ObjectID32 (RO) = 1573934064
;   ObjectName (RO) = "AcDbBlockReference"
;   OwnerID (RO) = 917802848
;   OwnerID32 (RO) = 917802848
;   PlotStyleName = "ByLayer"
;   Rotation = 0.0
;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 000000005DD1B1F8>
;   Visible = -1
;   XEffectiveScaleFactor = 1.0
;   XScaleFactor = 1.0
;   YEffectiveScaleFactor = 1.0
;   YScaleFactor = 1.0
;   ZEffectiveScaleFactor = 1.0
;   ZScaleFactor = 1.0
: DUMPIT
Select entity:
; Property values :
;   color = 256
;   Layer = "0"
;   Lineweight = -1
;   Name = "aaa"
;   Rotation = 0.0
;   Visible = -1
Thanks @BIGAL 😀
