Hello guys
im gonna to make code for selecting  external block in my drawing and explode it.
please any command and idea to help this.
hi marko
I don know how i can appreciate of your helping, that s  great what i need. one more qustion::
the command lisp ask us open window in cuerrent path or spescifed pass defined in code lisp.
 something like this :
(defun c:blkinsexp ( / fn )
  (setq fn (getfiled "\nSelect block DWG file..." "\\" "dwg" 16))
(setq pathinsert  getstring "your external block in the current or in default path y/n")
if y ---->> open window in current path
   n ---->> open window in d://my ex block//
  (vl-cmdf "_.-INSERT" (strcat "*" fn))
  (while (< 0 (getvar 'cmdactive))
  (vl-cmdf "\\")
I have modified the above to ::
	  (initget 1 "Y N") ; 1 = no null input
      (setq hide (getkword "\nCURRENTLY? [Y/N] ? <Y>")) 	;Get the input
   (if
   (= hide "Y") ;If the user has entered the required key "Y"
   (setq e-path (getvar "dwgprefix"))
   (setq fn (getfiled "\nSelect block DWG file..." e-path "dwg" 16)))
   ( if
   (= hide "N")
   (setq fn (getfiled "\nSelect block DWG file..." "E://99/ "dwg" 16)))
     (vl-cmdf "\\")
and i get the following error:
Command:
error: malformed string on input
Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Converting (command) calls to (command-s) is recommended.
Command:
Edited by hosyn
You might also like to check out Lee Macs Upgraded Burst lisp.
I've never used it, but I am sure there are those who WILL find it very helpful.
Thanks Lee!  :beer:
hi marko
  (vl-cmdf "\\")
   (if
   ( if
   (= hide "N")
     (vl-cmdf "\\")
Command:
Command:
Try this mod...
(defun c:blkinsexp ( / fn hide path )
  (initget "Y N")
  (setq hide (getkword "\nCURRENTLY? [Y/N] ? <Y> : "))
  (if (null hide)
    (setq hide "Y")
  (cond
    ( (= hide "Y")
      (setq fn (getfiled "\nSelect block DWG file..." (getvar 'dwgprefix) "dwg" 16))
    ( (= hide "N")
      (if (not (vl-file-directory-p (setq path "E:\\99\\")))
        (if (vl-file-directory-p "E:\\")
          (vl-mkdir (setq path "E:\\99\\"))
          (if (not (vl-file-directory-p (setq path "C:\\99\\")))
            (vl-mkdir (setq path "C:\\99\\"))
      (setq fn (getfiled "\nSelect block DWG file..." path "dwg" 16))
    (vl-cmdf "\\")
Edited by marko_ribar
Hi marko
thats great thanxxxxxxxxxx a lot:surrender:
