rcb007
How to create a routine in a loop?
rcb007
I have several layout tabs in drawing, and I need to go through each tab to adjust the scale and layers, then go on to the next.
I am trying to manually do it within the code, but did not know how to make it loop to the last layout tab.
(defun C:AMVP_Part3()
;;Viewport 1
(command "-layout" "set" "C3.1")
(command "-layer" "Freeze" "xMatchline*" "Thaw" "*Area1" "")
(command "_mspace")
(command "zoom" "extents")
(command "ZOOM" "Scale" "1/20xp")
(command "_pspace")
;;Viewport 2
(command "-layout" "set" "C3.2")
(command "-layer" "Freeze" "xMatchline*" "Thaw" "*Area2" "")
(command "_mspace")
(command "_pspace")
;;Viewport 3
(command "-layout" "set" "C3.3")
(command "-layer" "Freeze" "xMatchline*" "Thaw" "*Area3" "")
(command "_mspace")
(command "_pspace")
;;Viewport 4
(command "-layout" "set" "C3.4")
(command "-layer" "Freeze" "xMatchline*" "Thaw" "*Area4" "")
(command "_mspace")
(command "_pspace")
(princ))
this goes all the way to 30 layout tabs.
Share this post
Link to post
ronjonp
Try something like this:
(foreach name (layoutlist)
  (setvar 'ctab name)
  (command "_mspace")
  (command "_pspace")
Share this post
Link to post
rcb007
Thanks man!. That piece helps out a lot! Saves a lot of extra anticipating code.
I forgot to mention this piece. I apologize.
with the  (command "-layer" "Freeze" "xMatchline*" "Thaw" "*Area1" "")
So how would this work if I needed the first tab be to turn on "*Area1"
Then the next time would be "*Area2" and so forth?
If it cant, I its not the end of the world.
Edited by rcb007
Share this post
Link to post
ronjonp
Here is one way untested:
(defun c:foo (/ n)
  (setvar 'cmdecho 0)
    (setvar 'ctab name)
    (setq n (cdr (assoc -1 (dictsearch (namedobjdict) "acad_layout"))))
    (command "-layer"
	     "Freeze"
	     "xMatchline*"
	     "Thaw"
	     (strcat "*Area" (itoa (cdr (assoc 71 (dictsearch n name)))))
    (command "_mspace")
    (command "_pspace")
  (setvar 'cmdecho 1)
Here's a VL version for your edumacation:
(defun c:foo nil
  (setvar 'cmdecho 0)
  (vlax-for lyt	(vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)))
    (if	(= 0 (vlax-get lyt 'modeltype))
      (progn (setvar 'ctab (vla-get-name lyt))
	     (command "-layer"
		      "Freeze"
		      "xMatchline*"
		      "Thaw"
		      (strcat "*Area" (itoa (vla-get-taborder lyt)))
	     (command "_mspace")
	     (command "_pspace")
  (setvar 'cmdecho 1)
(vl-load-com)
Edited by ronjonp
Share this post
Link to post
rcb007
It works great! Thank you again. Saves so much time!
Share this post
Link to post
ronjonp
Glad to help out 🍻
Share this post
Link to post
rcb007
Gotta a question. I am trying to configure the same code not to use the xref.
I thought all I had to do was remove the "Matchline" part of the code, but does it need to be there or replaced with a (*)?
(defun c:foo (/ n)
  (setvar 'cmdecho 0)
    (setvar 'ctab name)
    (command "-layer"
	     "Freeze"
	     "*" <--- How to remove the Xref Name and just use the layers within the drawing?
	     "Thaw"
    (command "_mspace")
    (command "_pspace")
  (setvar 'cmdecho 1)
Share this post
Link to post
ronjonp
You want to freeze all xref layers ( "*|*" ) or exclude xref layers ( "~*|*" ) ?
Share this post
Link to post
rcb007
Currently when I run the routine it works like it should with the matchline xref attached in the sheet.
If I were to bind the xref into  the sheet dwg (as a block) and run the routine, it does not seem to work as it does if it was an xref.
Share this post
Link to post
ronjonp
Post a sample drawing .. I'm not following what you're trying to do. If you bind a drawing the layer names change based on your BINDTYPE system variable.
Just Guessing use:  "*xMatchline*"
Share this post
Link to post
rcb007
Ronjonp,
I don't know what I did, but I got it working. I guess I had to reboot my pc, but its working.
Edited by rcb007
Share this post
Link to post
ronjonp
On 7/29/2020 at 12:15 PM, rcb007 said:
Ronjonp,
Share this post
Link to post
