aravindkpe Posted February 3, 2009 Posted February 3, 2009 hi everybody, This is my first thread in cadtutor.thank you all for supporting me. I am using autocad 2005. i made more than 50 drawings and each of them has 3-5 revsions. all of them have title block in xref. finaly my client doesn't want to keep title block as xref. also two images in title block. purposly their path should have to changed. Now i fedup. opening one by one all. binding the xref and changing image path. Please anybody help me, if any tricks available to finish this very big job. Quote
Dipali Posted February 3, 2009 Posted February 3, 2009 you can write scripts to perform repetative actions in the drawings. you can also automate it using lisps(programming). so it runs in all the drawings without you opening it manually. but I don't know about thme in detial so may be some one else will help you., In the meantime do serach 'scripts' & lisps. & read similar threads Quote
rkent Posted February 3, 2009 Posted February 3, 2009 Reference Manager could help, in Windows>Start>Programs>autodesk>AutoCAD2008 >Reference Manager. Hopefully LT has that. If LT has Etransmit then that will do the binding for you as well. GL Quote
aravindkpe Posted July 20, 2009 Author Posted July 20, 2009 Mr.rkent, i do check in 'Reference Manager' . but i couldn't able to found binding option. Please give me more explanation binding in 'Referance Manager Thank you Quote
