Hi everyone,
I have some  points which I have created from a survey, the have individual x y z values, these are points relative to an area of land  have surveyed. If there a way using autocad 2020 to create a mesh or a surface to display this information and contours?  (hope that makes sense)
You can do this in Civil 3D, but as far as I know, you can't do it in plain Autocad unless someone has a custom lisp routine for this sort of thing?
It might be possible with CadTools.  You'd have to check.
www.glamsen.se/CadTools.htm
Edited by ReMark
Look here at Cadtutor for TriangV0.x.x.lsp, search ymg I have V0.5.9 may be newer versions. Its free.
;; Version V0.5.8                                                             ;
;; C:TIN, Generates Delaunay Triangulation and Voronoi Diagram.               ;
;; C:CONT, Generates Contours from a sset of 3DFACES.                         ;
;; C:GEN, Generates a bunch of points for testing.                            ;
;; C:DEMOZ, Demo of locating yourself in a triangulation.                     ;
;; C:LBL, Generates Label on Major Contour at regular spacing.                ;
;; C:FLBL, Generates Label on All Contours along Fence Lines.                 ;
;; C:DLBL, Generates Label Dynamically (Based on Alan JT routine)             ;
;; C:PROF, Generates a Longitudinal Profile.                                  ;
;; C:XSHAPE, (Chi-shape) Generates a concave boundary around triangulation    ;
;; Added triloc,   ymg                      August 2013                       ;
;; Added getz,     ymg                      August 2013                       ;
;; Added demoz,    ymg                      August 2013                       ;
;; Modif setup,    ymg                      September 2013                    ;
;; Added get_tin,  ymg                      October 2013                      ;
;; Added c:flbl,   Alan J Thompson          October 2013                      ;
;; Added c:cont,   ymg                      November 2013                     ;
;; Added c:dlbl,   ymg                      November 2013                     ;
;; Added c:ocd,    AUGI Forum               November 2013                     ;
;; Added c:prof,   ymg                      February 2014                     ;
;; Speed Optimization mainly in Contour        March 2014                     ;
;; Added c:xshape  ymg                           May 2014                     ;
Edited by BIGAL
You can do this and much more with CADTools which is free.
