chubarka
Wrong Extrusion
chubarka
Anyone here have a clue as to where this situation comes from?  I have made a single line
sketch with hopes of extruding it as a solid,  this is the result.
Chubarka
Share this post
Link to post
cadasio
I would suggest you have thin feature ticked when you are doing your extrusion - this will occur automatically if you have a gap in your sketch.
If you fully define the sketch and/or use check sketch for feature and that may highlight any errors in it.
Share this post
Link to post
Dadgad
I suggest drawing it with a continuous Polyline, following the commandline prompts carefully.
For the last segment use the CLOSE option.
Try using the PRESSPULL command and you should be good.
Follow and pay attention to the different commandline options.
Share this post
Link to post
Cad64
Dadgad, you're in the Solidworks section. ;)
Share this post
Link to post
Dadgad
WHOOPS!  Never mind!  :oops:
Thanks for the headsup!  :beer:
@chubarka, your profile says Autocad 2007.  Should it?
Edited by Dadgad
Added user profile query.
Share this post
Link to post
BIGAL
Share this post
Link to post
