prax3des Posted June 30, 2020 Posted June 30, 2020 Good afternoon everyone.Sometimes I run into the following problem.I have a room of X square meters, but in autocad it indicates other meters. Is there a lisp that can help me rescale to get those square meters?Attached sample dwg Drawing1.dwg Quote
ronjonp Posted June 30, 2020 Posted June 30, 2020 (edited) Try this: (defun c:scaletoarea (/ _getarea a a2 ll o s ur) ;; RJP » 2020-06-30 (defun _getarea (e / a) (if (not (vl-catch-all-error-p (setq a (vl-catch-all-apply 'vlax-curve-getarea (list e))))) a 0. ) ) (if (and (setq s (ssget ":L")) (setq a (getreal "\nEnter desired area: "))) (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (if (/= 0 (setq a2 (_getarea e))) (progn (vla-getboundingbox (setq o (vlax-ename->vla-object e)) 'll 'ur) (setq ll (mapcar '+ (vlax-safearray->list ll) (vlax-safearray->list ur))) (vlax-invoke o 'scaleentity (mapcar '/ ll '(2 2 2)) (sqrt (/ a a2))) ) ) ) ) (princ) ) Edited June 30, 2020 by ronjonp Quote
