Hardney Posted February 3, 2009 Posted February 3, 2009 Hi, is there a way to manage the settings of the contour label lines through the prospector settings and not individually through the property tab? Quote
Hardney Posted February 3, 2009 Author Posted February 3, 2009 For those interested, here is the link to the answer to my question: http://discussion.autodesk.com/forums/message.jspa?messageID=5800880 Quote
rustysilo Posted February 3, 2009 Posted February 3, 2009 And if you already have a bunch you want to turn off select similar will grab them all. Quote
BIGAL Posted February 5, 2009 Posted February 5, 2009 Extra contour question How can you select "all" the contours and display say major lable using distance parameter without having to draw lines though the model so it knows which contours to use. Can not find a window option . Quote
alanjt Posted February 5, 2009 Posted February 5, 2009 what i've been confused about is if i label multiple contours at interval, it will place all my labels as i would like, but it puts the (can't remember the name) line that controls placement of the labels, on the 0 layer. however, if i label a contour any other way, it doesn't display them (as i have setup). i would very much like to use the interval labeling, but i can't figure out a way around this issue. Quote
rustysilo Posted February 5, 2009 Posted February 5, 2009 Extra contour question How can you select "all" the contours and display say major lable using distance parameter without having to draw lines though the model so it knows which contours to use. Can not find a window option . I don't think you can do that. Maybe with some programming it could be done. Quote
rustysilo Posted February 5, 2009 Posted February 5, 2009 what i've been confused about is if i label multiple contours at interval, it will place all my labels as i would like, but it puts the (can't remember the name) line that controls placement of the labels, on the 0 layer. however, if i label a contour any other way, it doesn't display them (as i have setup). i would very much like to use the interval labeling, but i can't figure out a way around this issue. For the contour label line display follow the link Hardney provided above ^ For the contour label line layer visit this thread. Quote
