hamid.r.aali Posted July 4, 2020 Share Posted July 4, 2020 (edited) I wonder if the code CountAttributeValues.lsp http://www.lee-mac.com/countattributevalues.html can be modified so that it shows in a column tags of block. I will use it in preparing MTO in electrical drawings. For example there may exist 10 blocks tag=breaker value=10A 8 blocks tag=fuse value=10AAt the moment the result of running the program is value =10A....Total=18 But i want the result be as follow : tag=breaker...value=10A....Total=10 tag=Fuse...value=10A....Total=8 Thanks a lot Edited July 5, 2020 by CADTutor Reduce text size Quote Link to comment Share on other sites More sharing options...
