Hello everyone. I need to export several solids from a CAD file to STL. However, I need these solids in the STL files to be separated. When I use the STLOUT command in AutoCAD, the created STL file contains all the solids but joined together. Is there any way to export them without being all united in a single solid.
The idea is to model them in other software and not print, so I need them separately in the STL format.
Thanks
Luiz
Great thanks a lot. I'll check the solution.
