I need to figure out how to add a dialog popup box into the below routine. It is there to ask what layout tab you would want to use and then how many copies. I have alerts up to notify the user to place the commands at the command line. Just not sure if that is the best approach.
(defun c:Layouts_Duplicate ( / *error* oCMDECHO ctab name namer namei nname n i x )
  (Alert "Which Layout Tab to Duplicate?\n\nFor (Current Tab Press Enter):")
  (setq ctab (getvar "ctab"))
  (setq name (getstring (strcat "\nLayout to duplicate <" ctab "> (Current Tab Press Enter): "))) ;;;;;;; <<<<<--- Prompt for a Dialog for the user to set the value?
  (if (= name "") (setq name ctab))
  (setq n (1+ (strlen name))
        namei "")
  (while (and (> n 1)
              (wcmatch (setq x (substr name (setq n (1- n)) 1)) "#"))
    (setq namei (strcat x namei)))
  (setq namer (substr name 1 (- (strlen name) (strlen namei)))
        namei (atoi namei))
  (initget 6)
  (Alert "How many additional Layout Tabs needed?\n\n(Matchline Viewports)")
  (setq n (getint "\nHow many additional layout tabs needed: ")  ;;;;;;; <<<<<--- Prompt for a Dialog for the user to set the value?
        i (+ 1 namei n))
  (repeat n
    (setq nname (strcat namer (itoa (setq i (1- i)))))
    (if (member nname (layoutlist))
      (princ (strcat "\nLayout '" nname " ' already exists."))
      (command "_.LAYOUT" "_Copy" name (strcat namer "a")
               "_.LAYOUT" "_Rename" (strcat namer "a") nname)))
  (foreach name	(layoutlist)
    (setvar 'ctab name)
    (setq n (cdr (assoc -1 (dictsearch (namedobjdict) "acad_layout"))))
    (command "-layer"
	     "Freeze"
	     "Matchline*"
	     "Thaw"
	     (strcat "*Area" (itoa (cdr (assoc 71 (dictsearch n name)))))
    (command "_mspace")
    (command "zoom" "extents")
    (command "ZOOM" "Scale" "1/10xp")
    (command "_pspace")
(command "-xref" "reload" "*")
  (setvar 'CMDECHO oCMDECHO)
  (princ))
(c:Layouts_Duplicate)
thank you for any direction.
Edited by rcb007
You can use the DCL tools. I just started working with them myself recently, but the gist is that you write a DCL file (you can write and then run this from inside your existing LISP) which generates the dialog box. Take a look here for more info: https://www.afralisp.net/dialog-control-language/
If you want a pop up list then have a look at Lee-mac.com he has a good one can populate the list with the layout names.
So would replace at this point, note can make current layout the current highlited layout
Le Mac's http://www.lee-mac.com/tabsort.html lets you pick the Layout tab in a dialog box to copy, move, sort, rename, add prefix/suffix, or set current. There's even a help file.
A program designed with the intention to aid in the organisation of layout tabs in a drawing, the program enables the user to organise each layout tab using intuitively engineered buttons to move selected tabs up/down or to the top/bottom of the tab order.
The program also offers the ability to rename a layout tab by double-clicking on its entry in the list displayed, and furthermore add a prefix and/or suffix to selected/every layout tab.
A facility is also provided to add & delete layout tabs, and also sort the tabs into alphabetical, numerical, or architectural order; or reverse the order currently displayed.
A Find & Replace functionality is also offered to allow the user to quickly replace a text string in multiple layout tabs.
The user may also copy selected layout tabs, or set the selected entry as the current drawing layout.
A Help Dialog may be shown upon pressing H at the Main Dialog interface.
Thanks guys for the feedback. I will look into this.
  • 3 years later...
        namei "")
  (while (and (> n 1)
        namei (atoi namei))
  (initget 6)
        i (+ 1 namei n))
  (repeat n
    (setvar 'ctab name)
    (command "-layer"
	     "Freeze"
	     "Matchline*"
	     "Thaw"
    (command "_mspace")
    (command "_pspace")
  (princ))
I am testing this with 2024, and it seems it seems when creating a new layout tab, it is not sync'd to the right layout tab name. Everything prior to 2024 seems to work as expected.
For example. If I have 4 areas, usually it will match area 1 with the first layout tab and so forth. However, it is now starting the reverse, so layout 4 would be area 1, then layout tab 3 would be area 2 and so forth.
Not sure what in the code needs to be modified to make it work correctly.
Thanks for any help.
The fixed I used was to reorder the Layout Tabs.
https://www.cadtutor.net/forum/topic/65072-rename-layout/
(defun c:foo (/ i l n o)
 ;; Prefix
 (setq pre "BWSIP-2R-DD-TP-M")
 ;; Start number
 (setq n 1)
 ;; Get all paperspace layouts
 (vlax-for x (setq lo (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object))))
   (cond ((> (vla-get-taborder x) 0) (setq o (cons x o))))
 ;; Sort left to right
 (setq o (vl-sort o '(lambda (r j) (< (vla-get-taborder r) (vla-get-taborder j)))))
 ;; Apply a temp name to avoid duplicates
 (foreach l o (vla-put-name l (rtos (/ (getvar 'cdate) (vla-get-taborder l)) 2 12)))
 ;; Renumber
 (foreach l o
   (setq i (cond ((< n 10) (strcat "0" (itoa n)))
	  ((itoa n))
   (vla-put-name l (strcat pre i))
   (setq n (1+ n))
(vl-load-com)
Hope this helps! Thanks Ron for putting this together.
