John Green Posted July 29, 2020 Share Posted July 29, 2020 Hi all I am a fairly basic Lisp user and I am having real issue trying to do something. Using AutoLISP rather than VisualLisp (but if no other way I will use visual lisp) I want t have a routine that will list all blocks on a drawing and return not only block name, but the layer it is on. I have a routine which list all the blocks fine but when I tried adding (cdr (assoc 8 selblk)) to get layer from dotted pair I just keep getting error that the value is nil I have tried all sorts and spent hours searching internet and cannot find anything that will give me what I want, which is to get for every block on drawing its name and layer (and possible the attribute attached to block, but this isn't vital) I don't want to change anything, just need the information to do some work on it when returned Any help would be most welcome Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 30, 2020 Share Posted July 30, 2020 Here's a relatively simple one: (defun c:blocklist ( / i l s x ) (if (setq s (ssget "_X" '((0 . "INSERT")))) (progn (repeat (setq i (sslength s)) (setq i (1- i) x (entget (ssname s i)) l (LM:nassoc++ (list (LM:name->effectivename (cdr (assoc 2 x))) (cdr (assoc 8 x))) l) ) ) (princ (strcat "\n" (padright "Block" " " 20) (padright "Layer" " " 20) (padleft "Quantity" " " 8))) (foreach x (vl-sort l '(lambda ( a b ) (< (strcase (car a)) (strcase (car b))))) (foreach y (vl-sort (cdr x) '(lambda ( a b ) (> (cadr a) (cadr b)))) (princ (strcat "\n" (padright (car x) " " 20) (padright (car y) " " 20) (padleft (itoa (cadr y)) " " 8))) ) ) ) (princ "\nNo block references were found in the active drawing.") ) (princ) ) (defun padright ( s c l ) (repeat (- l (strlen s)) (setq s (strcat s c))) s ) (defun padleft ( s c l ) (repeat (- l (strlen s)) (setq s (strcat c s))) s ) ;; Block Name -> Effective Block Name - Lee Mac ;; blk - [str] Block name (defun LM:name->effectivename ( blk / rep ) (if (and (wcmatch blk "`**") (setq rep (cdadr (assoc -3 (entget (cdr (assoc 330 (entget (tblobjname "block" blk)))) '("AcDbBlockRepBTag") ) ) ) ) (setq rep (handent (cdr (assoc 1005 rep)))) ) (cdr (assoc 2 (entget rep))) blk ) ) ;; Nested Assoc++ - Lee Mac ;; Increments the value of a key in an association list with possible nested structure, ;; or adds the set of keys to the list if not present. ;; key - [lst] List of keys & subkeys ;; lst - [lst] Association list (may be nil) (defun LM:nassoc++ ( key lst / itm ) (if key (if (setq itm (assoc (car key) lst)) (subst (cons (car key) (LM:nassoc++ (cdr key) (cdr itm))) itm lst) (cons (cons (car key) (LM:nassoc++ (cdr key) nil)) lst) ) (if lst (list (1+ (car lst))) '(1)) ) ) (princ) Quote Link to comment Share on other sites More sharing options...
