 Its looking like coreconsole cannot run the purge command (unknown command error), which is a big part of what i wanted to do.
I have found this link
https://www.theswamp.org/index.php?topic=31867.msg373489#msg373489
but it isnt lisp, can this be run within lisp ?.
i have a routine that cleans up drawings (dpsr), it runs great when included in a script.
trying to use it with core console i get:-
the lisp code for dpsr is :-
;; checkcolor
(defun CheckEntColor (ent / entData color layer layerData layerColor)
  (setq entData (entget ent))
  (setq color (cdr (assoc 62 entData)))
  (cond
    ((and color (/= color 256) (>= color 5)) T)
    ((or (not color) (= color 256))  (setq layer (cdr (assoc 8 entData)))  (setq layerData (tblsearch "LAYER" layer))   (setq layerColor (cdr (assoc 62 layerData))) (if (and layerColor (>= layerColor 5)) T nil))
    (T nil)
(defun c:dpsr (/	    doc		 ms	      result
	       layers-ok    ltypes-ok	 ents-ok      props-ok
	       layer-errors ltype-errors enttype-errors
	       prop-errors  csv-line	 ename	      clr
	       lt	    lyr
  (vl-load-com)
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (setq ms (vla-get-modelspace doc))
  (setq	*audit-csv-path* (strcat (getvar "DWGPREFIX") "DWG_Audit_Report.csv"))
  ;; CSV functions
  (defun append2csv (line / file)
    (setq file (open *audit-csv-path* "a"))
    (if	file
      (progn (write-line line file) (close file))
      (prompt "\nERROR: Cannot write to audit CSV.")
  (defun writecsvheader	()
    (if	(not (findfile *audit-csv-path*))
      (append2csv
	"DWGNAME,LAYERSTATES,LINETYPES,ENTITYTYPES,ENTITYDEF,LAYER-ERRS,LT-ERRS,TYPE-ERRS,PROP-ERRS"
  ;; Create or set a layer
  (defun makelayer (name color lw tran ltype)
    (if	(not (tblsearch "layer" name))
      (vla-add (vla-get-layers doc) name)
    (vla-put-color (vla-item (vla-get-layers doc) name) color)
    (vla-put-lineweight (vla-item (vla-get-layers doc) name) lw)
    (command "-layer" "tr" (rtos tran 2 0) name "")
    (command "-layer" "l" ltype name "")
  ;; Explode blocks
  ;;(vlax-for ent	ms
  ;;  (if	(and (= "AcDbBlockReference" (vla-get-objectname ent))
	;;     (vlax-method-applicable-p ent 'explode)
      ;;(vla-explode ent)
(defun explodeall ( / explode layouts )
   (setq layouts (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)))
         explode t
   (while explode
       (setq explode nil)
       (vlax-for layout layouts
           (vlax-for obj (vla-get-block layout)
               (and
                   (= "AcDbBlockReference" (vla-get-objectname obj))
                   (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-explode (list obj))))
                   (not (vl-catch-all-error-p (vl-catch-all-apply 'vla-delete  (list obj))))
                   (setq explode t)
   ;(princ)
(explodeall)
  ;; Create layers
  (makelayer "D-3D-SOL" 7 30 0 "Continuous")
  (makelayer "D-3D-CLG" 1 18 0 "Center")
  (makelayer "D-3D-CLM" 5 18 0 "Center")
  (makelayer "0" 7 -1 0 "Continuous")
 ;; catch all to make sure everything is set ok if not created by makelayer fuction
 ;; Set current layer to sol
  (command "_.layer" "_set" "D-3D-SOL" "")
  (command "_.layer" "_c" "7" "" "")
  (command "_.layer" "_tr" "0" "" "")
  (command "_.layer" "_lw" "0.3" "" "")
  (command "_.layer" "_l" "Continuous" "" "")
 ;; Set current layer to clm
  (command "_.layer" "_set" "D-3D-CLM" "")
  (command "_.layer" "_c" "5" "" "")
  (command "_.layer" "_lw" "0.18" "" "")
  (command "_.layer" "_l" "Center" "" "")
 ;; Set current layer to clg
  (command "_.layer" "_set" "D-3D-CLG" "")
  (command "_.layer" "_c" "1" "" "")
;; Set current layer to 0
  (command "_.layer" "_set" "0" "")
  (command "_.layer" "_lw" "0.25" "" "")
  ;; Error counters
  (setq	layer-errors   0
	ltype-errors   0
	enttype-errors 0
	prop-errors    0
  ;; Process objects
  (vlax-for ent	ms
    (setq ename	(vla-get-objectname ent)
	  clr	(vla-get-color ent)
	  lt	(vla-get-linetype ent)
	  lyr	(vla-get-layer ent)
    ;; Classification and move to appropriate layer
    (cond
      ((wcmatch ename "AcDb3dSolid,AcDbSurface")
       (vla-put-layer ent "D-3D-SOL")
      ((and (member ename '("AcDbLine" "AcDbPolyline" "AcDbCircle" "AcDbArc"))
	    (not (CheckEntColor (vlax-vla-object->ename ent)))             ;; Was (not (CheckEntColor ent))
       (vla-put-layer ent "D-3D-CLG")
       (vla-put-layer ent "D-3D-CLM")
    ;; Set ByLayer color and linetype
    (if	(/= clr 256)
      (progn (vla-put-color ent 256)
	     (setq prop-errors (1+ prop-errors))
    (if	(/= (strcase lt) "BYLAYER")
      (progn (vla-put-linetype ent "BYLAYER")
    ;; Track invalid types and linetypes
    (if	(not (member ename
		       "AcDbCircle"	  "AcDb3dSolid"
		       "AcDbSurface"      "AcDbArc"
      (setq enttype-errors (1+ enttype-errors))
    (if	(not
	  (member (strcase lt) '("BYLAYER" "CONTINUOUS" "CENTER"))
      (setq ltype-errors (1+ ltype-errors))
  ;; Delete entities on layer "0"
  (vlax-for ent	ms
    (if	(= (strcase (vla-get-layer ent)) "0")
      (vla-delete ent)
  ;; Set layer 0 current
  (vla-put-activelayer
    doc
    (vla-item (vla-get-layers doc) "0")
  ;;Remove duplicates
  (command "-OVERKILL" "ALL" "" "")
  ;; Purge all
  (repeat 3 (command "_.PURGE" "ALL" "*" "N"))
  (repeat 2 (command "_.PURGE" "Regapps" "*" "N"))
  ;; Set UCS/view
  (command "_.UCS" "_W")
  (command "_.-VISUALSTYLES" "C" "_CONCEPTUAL") ;; Fixed
  (command "_.VIEW" "_SWISO")
  (command "_.ZOOM" "_E")
  ;; Final checks
  (setq	layers-ok (and (tblsearch "layer" "0")
		       (tblsearch "layer" "D-3D-SOL")
		       (tblsearch "layer" "D-3D-CLG")
		       (tblsearch "layer" "D-3D-CLM")
  ;; Build CSV output
  (setq	result
	 (strcat (getvar "DWGNAME")
		 (if layers-ok
		   "PASS"
		   "FAIL"
		 (if (= ltype-errors 0)
		   "PASS"
		   "FAIL"
		 (if (= enttype-errors 0)
		   "PASS"
		   "FAIL"
		 (if (= prop-errors 0)
		   "PASS"
		   "FAIL"
		 (itoa layer-errors)
		 (itoa ltype-errors)
		 (itoa enttype-errors)
		 (itoa prop-errors)
  (writecsvheader)
  (append2csv result)
the script i am using to run it is:-
(load "C:/Users/me/LIBRARY/AutoCad/AutocadScripts/dwgprocessor.lsp")
dpsr
qsave
close
and the batch file used to run the scrpit is:-
@echo off
setlocal
:: Set the path to the folder containing your DWG files
set "folderpath=C:\Users\me\ASSETS\DWG\3D\LIGHT"
:: Set the AutoCAD Core Console executable path
set "AutoCADCoreConsole=C:\Program Files\Autodesk\AutoCAD 2026\accoreconsole.exe"
:: Set the path to your LISP file
set "lispFile=C:\Users\me\LIBRARY\AutoCad\AutocadScripts\process.scr"
:: Loop through all DWG files in the folder
for %%f in ("%folderPath%\*.dwg") do (
    echo Processing: %%f
    "%AutoCADCoreConsole%" /i "%%f" /s "%lispFile%" /product ACAD /l en-US
endlocal
when run, dpsr is basically ignored and the next two lines of the script are run:-
is it the VL commands causing the issue ?
Core Console returns nil for (vlax-get-acad-object).
Core console doesn't generally like VLA- commands, if you can do it all in pure LISP then you have more success.
Thank you .
I have set things running on another pc, I was hoping to save some time .
interesting to learn about core console though .
you could try loading the visual lisp functions in your script (never tested it myself thou..)
http://www.theswamp.org/index.php?topic=57471.msg609440#msg609440
Quote from: VovKa on March 29, 2022, 11:45:12 AM
Quote from: jmcshane on March 29, 2022, 09:03:29 AM
I'm thinking it might be based on ActiveX which isn't supported in acoreconsole as far as I know.
(layoutlist) is defined inside acapp.arx which is not loaded by acoreconsole
So simply load it in the Script:
Code: [Select]
_.arx L "acapp.arx"
(setq foo (layoutlist))
Core Console supports loading ARX/.NET assemblies.
Code: [Select]
_.arx L "acapp.arx"
Ha! You quoted everyone but me.
Ow sorry , not intentionally , assumend peoples would click on swamp link and see that this came from
BlackBox BlackBox BlackBox :celebrate:
  • Funny 1
Kind of you to say, now I'm blushing. LoL
I'm just passionate about Core Console, and think it's one of the best 'new' features in the last decade+, that's seemingly underutilized (as I understand it from forum convos, etc).
Cheers
